Home » Archived » GMT (Generative Modeling Technologies) » [TCS] Which one should I choose, TCS or Jet?
Re: [TCS] Which one should I choose, TCS or Jet? [message #380587 is a reply to message #380584] |
Thu, 20 December 2007 09:43 |
Originally posted by: mikael.barbero.gmail.com
Andy,
TCS is also able to pretty print the model of a program without changes
of the .tcs file. Naturally, the printed program is something being able
to be parsed by TCS :) Code generation with Jet & Co. would only be
needed if you only want to generate code and not parse it again afterward.
Then, I would say that TCS do T2M and M2T.
My $0.02
Regards.
Mikael
Andy Carpenter wrote:
> Michael,
> You will probably need both TCS and JET. I guess that
> for your requirements you will need to use TCS to produce
> a model from a 'program' written in your language (think of
> a model as an internal data structure representation of your
> program); this is a text-to-model transformation.
> The code generation would then use this model (internal
> data structure). If the code generation results in code that
> is similar in structure to your input language then what you
> will be performing is a model-to-text transformation for
> which JET is one possible implementation technology.
> If your language does not have a simple relationship to
> the code that you need to generate then the first step will
> be a model-to-model transformation. This transforms the
> original model representation of your program into a form
> closer to the code that you need to generate. Model-to-model
> transformation implementation possibilities include ATL.
> Once you have a model that is sufficiently close to the code
> that you need to generate, you can perform a model-to-text
> transformation; as described above.
> hope this helps
> Andy.
> "Michael" <my25@macs.hw.ac.uk> wrote in message
> news:fkbhv0$6eo$1@build.eclipse.org...
>> Hi,
>> I'd like to develop a code generator for a language, say Java. I know
>> TCS can generate code based on syntactic description attached to the
>> metamodel, and I also know that Jet can produce source code of generator
>> too. I am confused which one I should adopt to build my generator.
>> Please give me some idea. If you recommend one,either TCS or Jet, it
>> will be great if you can tell me the reason.
>> Thanks.
>> Merry Christmas
>> Michael.
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [TCS] Which one should I choose, TCS or Jet? [message #380591 is a reply to message #380589] |
Thu, 20 December 2007 16:54 |
TCS has not been released yet.
Information on how to get it from CVS is available on this wiki page:
http://wiki.eclipse.org/TCS/Language_Project
Samples are available here: http://wiki.eclipse.org/TCS/Zoo
Mikael
Michael wrote:
> Thanks for the help from both of you.
> However, the problem is that the download of TCS is not available on the
> eclipse website. Do you have any idea of that?
> Michael.
> "Mikaël Barbero" <mikael.barbero@gmail.com> wrote in message
> news:fkddfj$nnb$1@build.eclipse.org...
>> Andy,
>> TCS is also able to pretty print the model of a program without changes of
>> the .tcs file. Naturally, the printed program is something being able to
>> be parsed by TCS :) Code generation with Jet & Co. would only be needed if
>> My $0.02
>> Regards.
>> Mikael
>>> Michael,
>>> hope this helps
>>> Andy.
>>>> Hi,
>>>> Thanks.
>>>> Merry Christmas
>>>> Michael.
Re: [TCS] Which one should I choose, TCS or Jet? [message #611080 is a reply to message #380584] |
Andy,
My $0.02
Regards.
Mikael
> Michael,
> hope this helps
> Andy.
>> Hi,
>> Thanks.
>> Merry Christmas
>> Michael.
Re: [TCS] Which one should I choose, TCS or Jet? [message #611083 is a reply to message #380589] |
Mikael
> Michael.
>> Andy,
>> My $0.02
>> Regards.
>> Mikael
>>> Michael,
>>> hope this helps
>>> Andy.
>>>> Hi,
>>>> Thanks.
>>>> Merry Christmas
>>>> Michael.
Current Time: Thu Apr 25 23:15:27 GMT 2024
Powered by FUDForum. Page generated in 0.03746 seconds
