Re: How build DD Model with UML metamodel [message #380380 is a reply to message #380379] |
Thu, 22 November 2007 11:19 |
Originally posted by: luciananegri81.yahoo.it
Thank you very much for the note, I'm new in this forum.
I'm trying to build a Deployment Diagram in which I represent
two Node (where every Node contains some Artifact that represent
the component)and one Communication Path that it connects them.
Now, I have added the Communication Path, but I don't succeed
in saying what members it connects, that is the property 'Member End'
doesn't allow me to add nothing.
I would want to know if I have added other property to give me the
property 'Member End'.
Thank you.
Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #380449 is a reply to message #380381] |
Thu, 22 November 2007 13:12 |
I explay better my work.
I have extend UML metamodel with Reliability characteristics,
write models conform to my metamodel and transform it in Fault Tree
through ATL.
Initially I wanted to extend the Omondo metamodel to create my diagram
directly via graphic interface. It's not actually possible extend
deployment diagram because only the Class diagram is an MOF/EMF Model,
while deployment diagram is only graphical information.It is not possible
to create deployment diagram and take the XMI generated.
Via 'Sample Ecore Model Editor', I can create an EMF Model compliant
with the metamodel loaded through graphic interface, Epsilon is a good
support for this step.
thanks
Luciana
Re: How build DD Model with UML metamodel [message #609296 is a reply to message #380379] |
Thank you.
Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #609298 is a reply to message #380381] |
through ATL.
thanks
Luciana
FUDForum. Page generated in 0.02366 seconds
