Home » Archived » GMT (Generative Modeling Technologies) » Re: How build DD Model with UML metamodel
Re: How build DD Model with UML metamodel [message #380379] Thu, 22 November 2007 05:00 Go to next message
Hi Luciana,
Please note that questions about Epsilon should be posted to the
eclipse.modeling.gmt newsgroup (which I've added to the "to" list of
this reply).
Could you please provide some more details on what you are trying to do?
Dimitrios
Luciana wrote:
> Hello,
> I must build a Epsilon Model that represents the Deployment Diagram, but
> I don't succeed in inserting the Communication Path.
> Can someone help me?
> Thanks for any help.
> Luciana
Re: How build DD Model with UML metamodel [message #380380 is a reply to message #380379] Thu, 22 November 2007 06:19 Go to previous messageGo to next message
Originally posted by: luciananegri81.yahoo.it
Thank you very much for the note, I'm new in this forum.
I'm trying to build a Deployment Diagram in which I represent
two Node (where every Node contains some Artifact that represent
the component)and one Communication Path that it connects them.
Now, I have added the Communication Path, but I don't succeed
in saying what members it connects, that is the property 'Member End'
doesn't allow me to add nothing.
I would want to know if I have added other property to give me the
property 'Member End'.
Thank you.
Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #380381 is a reply to message #380380] Thu, 22 November 2007 06:54 Go to previous messageGo to next message
Hi Luciana,
Just to establish a common point of reference: which tool are you using
to specify your deployment diagram? (I don't see support for deployment
diagrams in the UML2 Tools)
Also, from what you've said so far, this seems to be a UML2 question
(for which the eclipse.modeling.mdt.uml2 may be more appropriate). How
does it relate to Epsilon?
Dimitrios
> two Node (where every Node contains some Artifact that represent the
> Now, I have added the Communication Path, but I don't succeed in saying
> Thank you.
> Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #380449 is a reply to message #380381] Thu, 22 November 2007 08:12 Go to previous messageGo to next message
I explay better my work.
I have extend UML metamodel with Reliability characteristics,
write models conform to my metamodel and transform it in Fault Tree
through ATL.
Initially I wanted to extend the Omondo metamodel to create my diagram
directly via graphic interface. It's not actually possible extend
deployment diagram because only the Class diagram is an MOF/EMF Model,
while deployment diagram is only graphical information.It is not possible
to create deployment diagram and take the XMI generated.
Via 'Sample Ecore Model Editor', I can create an EMF Model compliant
with the metamodel loaded through graphic interface, Epsilon is a good
support for this step.
thanks
Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #380452 is a reply to message #380449] Thu, 22 November 2007 08:27 Go to previous messageGo to next message
So if I understand correctly you have a customized version of the UML2
metamodel and you are using the "Register EPackages" action that Epsilon
provides so that you can then edit instances using the Sample Ecore
Model Editor. Is that correct?
I think your question is related to the UML2 metamodel - rather than to
Epsilon itself - but if you can send me your custom metamodel and a
sample model that conforms to it I may be able to help.
Dimitrios
> I have extend UML metamodel with Reliability characteristics, write
> models conform to my metamodel and transform it in Fault Tree through ATL.
> thanks
> Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #380454 is a reply to message #380381] Thu, 22 November 2007 08:34 Go to previous messageGo to next message
Hi Dimitrios,
I think that you are right,
I ask the question on eclipse.modeling.mdt.uml2 newsgroups.
Thank you very much.
Re: [Epsilon] How build DD Model with UML metamodel [message #380458 is a reply to message #380452] Thu, 22 November 2007 09:58 Go to previous messageGo to next message
Hi Dimitrios,
it's all correct.
Where I send you my metamodel and a sample model?
thanks
Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #380460 is a reply to message #380452] Thu, 22 November 2007 10:06 Go to previous messageGo to next message
You can use dskolovos.gmail.com (replacing the first . with @)
Dimitrios
> Cheers,
> Dimitrios
>> ATL.
>> thanks
>> Luciana
Re: How build DD Model with UML metamodel [message #609296 is a reply to message #380379] Thu, 22 November 2007 06:19 Go to previous messageGo to next message
Thank you.
Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #609297 is a reply to message #380380] Thu, 22 November 2007 06:54 Go to previous messageGo to next message
Hi Luciana,
Dimitrios
> Thank you.
> Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #609298 is a reply to message #380381] Thu, 22 November 2007 08:12 Go to previous messageGo to next message
through ATL.
thanks
Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #609299 is a reply to message #380449] Thu, 22 November 2007 08:27 Go to previous messageGo to next message
Dimitrios
> thanks
> Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #609300 is a reply to message #380381] Thu, 22 November 2007 08:34 Go to previous messageGo to next message
Hi Dimitrios,
Re: [Epsilon] How build DD Model with UML metamodel [message #609302 is a reply to message #380452] Thu, 22 November 2007 09:58 Go to previous messageGo to next message
Hi Dimitrios,
it's all correct.
thanks
Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #609303 is a reply to message #380452] Thu, 22 November 2007 10:06 Go to previous messageGo to next message
Dimitrios
> Cheers,
> Dimitrios
>> ATL.
>> thanks
>> Luciana
Re: [Epsilon] How build DD Model with UML metamodel [message #1333205 is a reply to message #380449] Sun, 04 May 2014 21:37 Go to previous message
Dear luciana,
May I ask what UML2 diagrams you have used for this transformation?
Thanks.
Previous Topic:[ECL] How to exclude matches / how to run module
Next Topic:GMF Tooling: GWT generation issue
Current Time: Sun Nov 02 12:13:36 EST 2025
Powered by FUDForum. Page generated in 0.06984 seconds
