[TCS]:Error with TCS Wizard [message #380338] |
Mon, 12 November 2007 17:39 |
Originally posted by: youssedek.gmail.com
hi,
I used the Plugin Builder to create My project TCS.
the first steps ,I installed the plugings "TCS Builder plugin" and "TCS
Wizard plugin" (checkout in the TCS plugigns And Copy - Paste in
Eclipse/plugings Folder)
the next I'm checkout the AMMACore project in my workspace.
But when I start the TCS Wizard (File->New->Project...->ATL->TCS Language
Project)
I find the problem following:
The select wizard could not be started.
Reason:
Pluging org.eclipse.gmt.tcs.wizard was enable to load a class
org.eclipse.gmt.tcs.wizard.TcsProjectWizard.
what is the problem? (installation of wizard??)
thank You
Youssef
Re: [TCS]:Error with TCS Wizard [message #380467 is a reply to message #380373] |
Fri, 23 November 2007 21:58 |
Frédéric Jouault wrote:
Could you please check if there are other (more detailed) error messages
(e.g., in the Error Log)?
In my case I didn't have any error message in the Error Log;except the
error which I announced in my first message.
One possibility is that you miss a required dependency (e.g., AM3, or
ATL), or that you are using a version that is too old.
I use the plugings AM3 0.2 et ATL feature 2.0 in my project
but i have the same problem
Could you please indicate the link for download ATL and KM3 plugings?
youssef
Re: [TCS]:Error with TCS Wizard [message #380470 is a reply to message #380467] |
Sat, 24 November 2007 01:33 |
Frédéric Jouault Messages: 572 Registered: July 2009 |
Please use the latest version of ATL, AM3, and TCS. Not simply the
latest binary builds, but CVS HEAD.
Documentation to do this is available on the Eclipse wiki:
http://wiki.eclipse.org/ATL/How_Install_ATL_From_CVS/
http://wiki.eclipse.org/ATL/CVS_Repositories/
Frédéric Jouault
> Regards,
> youssef
Re: [TCS]:Error with TCS Wizard [message #609662 is a reply to message #380373] |
youssef
Re: [TCS]:Error with TCS Wizard [message #609665 is a reply to message #380467] |
Frédéric Jouault
> Regards,
> youssef
FUDForum. Page generated in 0.03422 seconds
