Home » Archived » GMT (Generative Modeling Technologies) » [TCS] Problem building TCS Language project
[TCS] Problem building TCS Language project [message #379932] |
Wed, 10 October 2007 23:08 |
Andy Carpenter Messages: 145 Registered: July 2009 |
I've been attempting to build a TCS language project and have
a problem that I have managed to solve, but now have
one that, at the moment I cannot solve.
My current situation is this. I've created a TCS language
project as described on the TCS wiki, including checking
out the AMMACore and AMMAScripts.
Having done this, while compiling the generated java of the parser,
the class org.eclipse.gmt.tcs.injector.TCSInjector is not found.
Checking out the org.eclipse.gmt.tcs.injector project and exporting
that into a jar that was included on the classpath of the TCS
language project solved this.
Next during the building of the megamodel phase, the class
org.atl.engine.injectors.ebnf.AM3_ANTLR3Lexer is not found.
I have tried to solve this by checking out the AM3 dsl from
org.eclipse.gmt/AM3/dsls/AM3. However, when I build this I
get the class org/eclipse/gmt/tcs/injector/AM3_ANTLR3Lexer,
so, this does not solve my problem.
Any thoughts would be appreciated.
Andy.
Dr Andy Carpenter
School of Computer Science,
University of Manchester, Manchester M13 9PL, UK
Email: Andy.Carpenter@manchester.ac.uk
Tel: +44 161 275 6168
Fax: +44 161 275 6280
Re: [TCS] Problem building TCS Language project [message #379936 is a reply to message #379932] |
Thu, 11 October 2007 07:58 |
Originally posted by: mikael.barbero.gmail.com
Hi Andy,
Which version of ATL do you have on your eclipse? TCS need the last CVS
version to work (and you don't need the org.eclipse.gmt.tcs project).
Have fun.
Mikael
> Andy.
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [TCS] Problem building TCS Language project [message #379939 is a reply to message #379938] |
Thu, 11 October 2007 12:38 |
You should try to re-build your parser.
Mikael
> Mikael,
> Thanks for the information. I was using ATL 2.0.0 from the
> update site on eclipse 3.3. I have now checked out ATL from
> cvs and installed the plugins into my extension location. Now
> the class not found error is for
> org/atl/engine/injectors/ebnf/EBNFInjector2
> is there another plugin that I should check out and install?
> Andy.
> "Mikaël Barbero" <mikael.barbero@gmail.com> wrote in message
> news:fekl28$tvg$1@build.eclipse.org...
>> Hi Andy,
>> Have fun.
>> Regards,
>> Mikael
>>> Andy.
Re: [TCS] Problem building TCS Language project [message #380157 is a reply to message #380153] |
Fri, 12 October 2007 16:12 |
Did you take AM3 project from the CVS ? New TCS also work with this
version (not only ATL CVS).
Mikael
> I'm getting the following error in the eclipse log when
> starting eclipse
> !ENTRY org.eclipse.gmt.am3.dsls.km3 4 0 2007-10-11 20:55:11.281
> !MESSAGE Unable to execute early startup code for an extension
> !STACK 0
> java.lang.NoClassDefFoundError: org/atl/engine/extractors/ebnf/EBNFExtractor
> at org.eclipse.gmt.am3.dsls.km3.Startup.earlyStartup(Startup.ja va:12)
> at
> org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup (EarlyStartupRunnable.java:87)
> at
> org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:66)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at org.eclipse.ui.internal.Workbench$54.run(Workbench.java:2190 )
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Andy.
> news:fel5g4$k7h$1@build.eclipse.org...
>> Regards,
>> Mikael
>>> Mikael,
>>> Andy.
>>>> Hi Andy,
>>>> Have fun.
>>>> Regards,
>>>> Mikael
>>>>> Andy.
Re: [TCS] Problem building TCS Language project [message #608143 is a reply to message #379932] |
Hi Andy,
Have fun.
Mikael
> Andy.
Re: [TCS] Problem building TCS Language project [message #608146 is a reply to message #379938] |
Mikael
> Mikael,
> Andy.
>> Hi Andy,
>> Have fun.
>> Regards,
>> Mikael
>>> Andy.
Re: [TCS] Problem building TCS Language project [message #608163 is a reply to message #380153] |
Mikael
> starting eclipse
> !STACK 0
> at
> at
> Andy.
>> Regards,
>> Mikael
>>> Mikael,
>>> Andy.
>>>> Hi Andy,
>>>> Have fun.
>>>> Regards,
>>>> Mikael
>>>>> Andy.
Current Time: Thu Mar 28 20:46:52 GMT 2024
Powered by FUDForum. Page generated in 0.03812 seconds
