Home » Archived » GMT (Generative Modeling Technologies) » [UMLX] Problem lookingup ambiguous classifiers qualified with its EPackage name
[UMLX] Problem lookingup ambiguous classifiers qualified with its EPackage name [message #379906] |
Mon, 08 October 2007 14:02 |
Originally posted by: alu2526.etsii.ull.es
Hi Ed,
Taking a look to your implementation of classifier 's lookup, i have
detected some problems.
QVTEnvironment has a method which detects the ambiguity in the classifier
lookup, is tryLookupMetaModelClassifier, which delegates the search to the
method lookupMetaModelClassifiers. The problem is that this method only find
unqualified classifiers, or classifiers qualified by a metaModel ID, but It
does not take into account that a classifier could be qualified by package
name.
The problem is partly solved because try lookupMetaModelClassifier would
fail, and a classifier would be found in a normal
EcoreEnvironment.lookupClassifier. But ambiguous classifiers qualified by
its package name would not be detected. For example:
PackageNameA
+CommonPackageName
+AClassifier
PackageNameB
+CommonPackageName
+AClassifier
If we lookup comonPackageName::AClassifier we have an undetected ambiguity
of classifier's names.
Besides, when qualifying with a metaModel ID which represents a set of
packages, you could not find a nested package name, since the
QVTEnvironment.getPackagedClassifier implementation is not as complete as
EcoreEnvironment.lookupClassifier implementation is. Instead of having a map
<metaModelID, EPackages> (in QVTrTopLevelEnvironment or
QVTrTransformationEnvironment) and functions (lookupMetamodelClassifier,
getMetaModelContents, etc) to manage them, I encourage you to use
environments (QVTrTransformationEnvironments nest QVTrMetaModelEnvironments
which nest a set of QVTEnvironment which have a package context associated)
and exploit the use of EcoreEnvironment.lookupClassifier.
I have implemented a hierarchical set of environments for my QVTo
implementation, that perhaps it could be applied at a QVTEnvironment and
QVTrEnvironment abstraction level and shared for all QVTo, QVTr, QVTc
implementation to have a better classifier's lookup.
Adolfo.
Re: [UMLX] Problem lookingup ambiguous classifiers qualified with its EPackage name [message #379921 is a reply to message #379906] |
Wed, 10 October 2007 06:42 |
Ed Willink Messages: 7655 Registered: July 2009 |
[The OCL background to this thread is https://bugs.eclipse.org/bugs/show_bug.cgi?id=176110]
Hi Adolfo
Now that MDT OCL lookup is evolving to accommodate lookup ambiguity in more
than just UML States, it is well worth revisiting all derived Environment
classes to provide consistent overrides of tryLookupXXXX that support the
Environment contract and 'return' an ambiguous result via a LookupException.
I'll do this once Christian has decided how to spell 'tryLookup' and whether
to support it by an adapter or a mix-in.
Failure to accommodate implicit wildcard meta-model, explicit package qualified
lookup is an oversight. At the time the QVT spec was very unclear about details
such as names, and so it was necessary to be intuitive as to what it meant for
standard OCL lookups to work in the presence of meta-model names.
Contrasting the various QVTrXxxEnvironment classes that I originally developed
with the QVTcXxxEnvironment classes that followed reveals a major refactoring
opportunity that could be very helpful for QVToXxxEnvironment. I'll look into this.
Ed Willink
Adolfo Sánchez-Barbudo Herrera wrote:
> Hi Ed,
> name.
> PackageNameA
> +CommonPackageName
> +AClassifier
> PackageNameB
> +CommonPackageName
> +AClassifier
> Regards,
> Adolfo.
Re: [UMLX] Problem lookingup ambiguous classifiers qualified with its EPackage name [message #608136 is a reply to message #379906] |
Hi Adolfo
Ed Willink
> Hi Ed,
> name.
> PackageNameA
> +CommonPackageName
> +AClassifier
> PackageNameB
> +CommonPackageName
> +AClassifier
> Regards,
> Adolfo.
Current Time: Thu Apr 18 04:20:22 GMT 2024
Powered by FUDForum. Page generated in 0.01874 seconds
