Re: Beginners trouble with modeling. [message #378364 is a reply to message #378363] |
Mon, 25 September 2006 15:48 |
Ed Merks Messages: 33140 Registered: July 2009 |
Gaff,
I see you asked the same question on the GMF newsgroup, which is better
than posting to this more general newsgroup. When posting the same
question to multiple newsgroup, please using a single posting to all so
that an answer on one will appear on all (to reduce the workload of
answering the same question multiple times).
Gaff wrote:
> Hey,
> I'm having trouble with building a model for gmf in a xsd file.
> I want to start off with a very simple model that contains only one
> type of element that can then be associated with other elements (a
> directed association) of the same type. The element will have some
> attributes (or should these be elements?) as well but it's doing the
> association I don't understand.
> What I want to model is a simple dialogue that is divided into
> segments. Each node to be a segment in a graph structure.
> So something like:
> <xsd:schema targetNamespace="http://www.example.org/dialoguegraph"
> xmlns:dialoguegraph="http://www.example.org/dialoguegraph"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
> <xsd:complexType name="DialogueSegment">
> <xsd:attribute name="intro_text" type="xsd:string"/> //set to max of one
> <xsd:attribute name="transcript" type="xsd:string"/> //set to max of one
> <xsd:attribute name="outro_text" type="xsd:string"/> //0..*
> </xsd:complexType>
> //set the relatonship between nodes?????
> </xsd:schema>
Ed Merks
Re: Beginners trouble with modeling. [message #582201 is a reply to message #378363] |
Gaff,
Gaff wrote:
> Hey,
> So something like:
> </xsd:complexType>
> </xsd:schema>
Ed Merks
FUDForum. Page generated in 0.03351 seconds
