Home » Modeling » MDT (Model Development Tools) » Using UML Standard profile with static profile
Using UML Standard profile with static profile [message #378291] Fri, 11 April 2008 10:32 Go to next message
Yann Tanguy is currently offline Yann TanguyFriend
Member
I try to build a static profile that use (inheritance) some of the
stereotypes defined in UML Standard profile.
When I create the genmodel file the "referenced generator model" are
correctly detected for UML and ECORE, not for the Standard profile.
I assume that this is due to the fact that the Standard profile is not
yet a Static profile. Have I missed something ?
Is a static version of the standard profile planned in coming releases ?
regards
Yann
Re: Using UML Standard profile with static profile [message #378292 is a reply to message #378291] Fri, 11 April 2008 10:56 Go to previous message
Yann,
I see you've reposted to the UML2 newsgroup. That's the best place to ask.
> regards
> Yann
Re: Using UML Standard profile with static profile [message #592477 is a reply to message #378291] Fri, 11 April 2008 10:56 Go to previous message
Yann,
> regards
> Yann
Previous Topic:Using UML Standard profile with static profile
Next Topic:[SBVR] Interest in UML/OCL to SBVR metamodel transformation
Current Time: Tue Nov 19 00:02:05 GMT 2019
Powered by FUDForum. Page generated in 0.02056 seconds
