Home » Archived » GMT (Generative Modeling Technologies) » [TCS] Case sensitive keywords
[TCS] Case sensitive keywords [message #378110] Tue, 12 June 2007 16:16 Go to next message
Hi all,
Just a little problem with keywords.
How to make them not case sensitive ?
Re: [TCS] Case sensitive keywords [message #378112 is a reply to message #378110] Tue, 12 June 2007 17:11 Go to previous messageGo to next message
ANTLR has some case sensitivity options:
http://www.antlr2.org/doc/lexer.html#Case_sensitivity
Please, let us know how well it works ;-).
Frédéric Jouault
Re: [TCS] Case sensitive keywords [message #378118 is a reply to message #378112] Wed, 13 June 2007 05:57 Go to previous messageGo to next message
I've add the option caseSensitive=false in the lexer option in the tcs
file.
The jar build works well but when parsing a file, it still remains error
if there is different case sensitivity.
I'll look closer to ANTLR to see how i can fix it.
Re: [TCS] Case sensitive keywords [message #378120 is a reply to message #378118] Wed, 13 June 2007 06:08 Go to previous messageGo to next message
> file.
Ok.
By the way, the TCS extractor already supports case insensitive keywords
via its kwCheckIgnoreCase parameter.
Frédéric Jouault
Re: [TCS] Case sensitive keywords [message #378122 is a reply to message #378120] Wed, 13 June 2007 06:22 Go to previous messageGo to next message
Is it a parameter for the ant file i guess ?
Does it works for an injector ?
Re: [TCS] Case sensitive keywords [message #378124 is a reply to message #378122] Wed, 13 June 2007 06:28 Go to previous message
>> keywords via its kwCheckIgnoreCase parameter.
It is a parameter of the TCS extractor.
You can use it in an ant file, or programmatically.
It is a parameter of the TCS *extractor* ;-).
Frédéric Jouault
Re: [TCS] Case sensitive keywords [message #601778 is a reply to message #378110] Tue, 12 June 2007 17:11 Go to previous message
Frédéric Jouault
Re: [TCS] Case sensitive keywords [message #601795 is a reply to message #378112] Wed, 13 June 2007 05:57 Go to previous message
file.
Re: [TCS] Case sensitive keywords [message #601801 is a reply to message #378118] Wed, 13 June 2007 06:08 Go to previous message
> file.
Ok.
Frédéric Jouault
Re: [TCS] Case sensitive keywords [message #601809 is a reply to message #378120] Wed, 13 June 2007 06:22 Go to previous message
Re: [TCS] Case sensitive keywords [message #601813 is a reply to message #378122] Wed, 13 June 2007 06:28 Go to previous message
Frédéric Jouault
Previous Topic:[TCS] Case sensitive keywords
Next Topic:Re: Cannot get MOFScript Editor or Pref Pages to Appear
Current Time: Sat May 24 12:58:29 EDT 2025
Powered by FUDForum. Page generated in 0.04246 seconds
