Home » Modeling » MDT (Model Development Tools) » uml2 file format
uml2 file format [message #378056] Tue, 12 February 2008 13:36 Go to next message
Jochen Zimmermann is currently offline Jochen ZimmermannFriend
what kind of format is the *.uml-file of a model in Eclipse/EMF? Is there
a schema for it? After extracting information from xml-files of another
XML schema I want to automatically generate such an *.uml-file but I don’t
know which rules to observe in the generation process. Is there an
intuitive way to do this generation starting from a “filled” DocumentRoot
EObject?
Jochen
Re: uml2 file format [message #378059 is a reply to message #378056] Tue, 12 February 2008 13:53 Go to previous messageGo to next message
Kenn Hussey is currently offline Kenn HusseyFriend
Jochen,
This question is more appropriate for the eclipse.modeling.mdt.uml2
newsgroup (copied).
Kenn
"Jochen Zimmermann" <zimmermann@fzi.de> wrote in message
news:6948fbb3f1679c254df7ccd6bab42725$1@www.eclipse.org...
Re: uml2 file format [message #378080 is a reply to message #378056] Tue, 12 February 2008 13:57 Go to previous message
Hi, Jochen,
This is a question for the UML2 newsgroup, included in this reply.
The default resource implementation for *.uml resources is an XMI
serialization with certain EMF-isms for extension data. The schema is
described by the UML.ecore model in the org.eclipse.uml2.uml bundle. UML2
is also capable of loading the standard XMI serialization of UML 2.1.
Concerning the transformation of data from your XML files to the UML2
schema, it might help to see how the UMLUtil::Ecore2UMLConverter class
converts Ecore models to roughly-equivalent UML models.
HTH,
Christian
Jochen Zimmermann wrote:
> EObject?
> Cheers,
> Jochen
Re: uml2 file format [message #581577 is a reply to message #378056] Tue, 12 February 2008 13:53 Go to previous message
Jochen,
newsgroup (copied).
Kenn
Re: uml2 file format [message #584684 is a reply to message #378056] Tue, 12 February 2008 13:57 Go to previous message
Hi, Jochen,
HTH,
Christian
> EObject?
> Cheers,
> Jochen
Previous Topic:uml2 file format
Next Topic:Unable to integrate MDT through update manager in Eclipse3.3.1
Current Time: Fri May 29 06:08:49 GMT 2020
Powered by FUDForum. Page generated in 0.02287 seconds
