Class Identity [message #377187] |
Fri, 09 June 2006 16:18 |
Originally posted by: pedram.corticon.com
Does EMF intend for only a single EAttribute of an EClass to have its ID
property set to true? If more than one EAttribute has its ID property set
to true, does this mean that the combination of the two forms a composite
key for the EClass?
Re: Class Identity [message #377189 is a reply to message #377187] |
Fri, 09 June 2006 17:22 |
Ed Merks Messages: 33140 Registered: July 2009 |
--------------010804040809030801020905
Pedram,
Please direct EMF questions to the EMF newsgroup. Yes, when we
implement 75933 <https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933>,
which we are working on now for the next release, we will validate that
there is at most one attribute with isID true (just as XML Schema
restricts there to be at most one element/attribute of type xsd:ID). In
119586 <https://bugs.eclipse.org/bugs/show_bug.cgi?id=119586> there is a
patch for changes to Ecore that would allow an EReference to specify
which EAttributes of the referenced EClass represent a key with respect
to that particular reference; this would allow us to generate fragment
paths such as //@eNamedElement[name='xyz'] that are based on keys rather
than on position.
> key for the EClass?
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Pedram,<br>
<br>
implement <a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933">75933</a>,
<a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=119586">119586</a>
there is a patch for changes to Ecore that would allow an EReference to
specify which EAttributes of the referenced EClass represent a key with
respect to that particular reference; this would allow us to generate
fragment paths such as //@eNamedElement[name='xyz'] that are based on
keys rather than on position.<br>
<br>
<blockquote cite="mide6c70g$525$1@utils.eclipse.org" type="cite">
<pre wrap="">Does EMF intend for only a single EAttribute of an EClass to have its ID
key for the EClass?
</pre>
</blockquote>
<br>
</body>
</html>
--------------010804040809030801020905--
Ed Merks
Re: Class Identity [message #573567 is a reply to message #377187] |
Pedram,
than on position.
> key for the EClass?
<html>
<head>
</head>
Pedram,<br>
<br>
<br>
key for the EClass?
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
FUDForum. Page generated in 0.03523 seconds
