User-defined datatypes [message #377159] |
Wed, 31 May 2006 23:07 |
Originally posted by: pedram.corticon.com
It appears that UML user-defined datatypes are only supported when there
is a single property of the datatype with stereoptype <<javaclass>> and
the property refers to a fully qualified Java class that implements the
data type.
This means that the typical UML datatype definition doesn't get imported
into EMF properly. For example:
<<datatype>>
Date
now : Date
isBefore( t:Date ) : Boolean
isAfter( t:Date ) : Boolean
The above data type is rejected. Is this correct? Is this by design?
Re: User-defined datatypes [message #377167 is a reply to message #377164] |
Mon, 05 June 2006 20:11 |
Ed
I'm not concerned about the UML2 project. I am interested in the
functionality of the base EMF. Can you answer the question within the
context of EMF design?
Pedram
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:e5miep$esh$1@utils.eclipse.org...
> Pedram,
> This is a question about UML2 to Ecore conversion so is best asked on the
> UML2 newsgroup.
>> data type.
>> <<datatype>>
>> Date
>> now : Date
Re: User-defined datatypes [message #377170 is a reply to message #377167] |
Mon, 05 June 2006 20:13 |
BTW, I tried the same thing in UML2 and for a scenario described it also
chokes when trying to convert a .uml model to a .ecore model.
"Pedram Abrari" <pedram@corticon.com> wrote in message
news:e6235u$cgc$1@utils.eclipse.org...
> Ed
> Thanks
> Pedram
>> Pedram,
>> UML2 newsgroup.
>>> data type.
>>> <<datatype>>
>>> Date
>>> now : Date
Re: User-defined datatypes [message #377173 is a reply to message #377167] |
Tue, 06 June 2006 11:43 |
Ed Merks Messages: 33140 Registered: July 2009 |
--------------040700050103060908040707
Pedram,
In that case you are better to ask on the EMF newsgroup. Yes,
EDataTypes (except for dynamic EEnums) should have an instance class
name set.
>Ed
>Thanks
>Pedram
>>Pedram,
>>UML2 newsgroup.
>>>data type.
>>> <<datatype>>
>>> Date
>>>now : Date
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Pedram,<br>
<br>
name set.<br>
<br>
<br>
<blockquote cite="mide6235u$cgc$1@utils.eclipse.org" type="cite">
<pre wrap="">Ed
Pedram
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:e5miep$esh$1@utils.eclipse.org">news:e5miep$esh$1@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Pedram,
UML2 newsgroup.
</pre>
<pre wrap="">It appears that UML user-defined datatypes are only supported when there
data type.
<<datatype>>
Date
now : Date
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------040700050103060908040707--
Ed Merks
Re: User-defined datatypes [message #573203 is a reply to message #377159] |
Thu, 01 June 2006 11:19 |
Pedram,
the UML2 newsgroup.
> there is a single property of the datatype with stereoptype
> <<javaclass>> and the property refers to a fully qualified Java class
> that implements the data type.
> imported into EMF properly. For example:
> <<datatype>>
> Date
> now : Date
Ed Merks
Re: User-defined datatypes [message #573271 is a reply to message #377164] |
Ed
Pedram
> Pedram,
> UML2 newsgroup.
>> data type.
>> <<datatype>>
>> Date
>> now : Date
Re: User-defined datatypes [message #573309 is a reply to message #377167] |
> Ed
> Thanks
> Pedram
>> Pedram,
>> UML2 newsgroup.
>>> data type.
>>> <<datatype>>
>>> Date
>>> now : Date
Re: User-defined datatypes [message #573338 is a reply to message #377167] |
Pedram,
name set.
>Ed
>Thanks
>Pedram
>>Pedram,
>>UML2 newsgroup.
>>>data type.
>>> <<datatype>>
>>> Date
>>>now : Date
<html>
<head>
</head>
Pedram,<br>
<br>
name set.<br>
<br>
<br>
<pre wrap="">Ed
Pedram
</pre>
UML2 newsgroup.
</pre>
data type.
<<datatype>>
Date
now : Date
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
FUDForum. Page generated in 0.03891 seconds
