Home » Archived » GMT (Generative Modeling Technologies) » [xPand]template doesn't recognise metamodel data
Re: [xPand]template doesn't recognise metamodel data [message #376869 is a reply to message #376867] |
Fri, 20 April 2007 07:48 |
Jacques LESCOT Messages: 247 Registered: July 2009 |
I met the same problem a few weeks ago. It seems that the "EMF
Metamodel" property of the oaW plugin only works for Ecore models.
I solved the problem by creating a new extension
"org.openarchitectureware.base.metamodelContributor" that only handle my
own metamodel.
Jacques
Chetan Kumar a écrit :
> Dear all,
> I have a problem in writing xPand template. The situation is as follows:
> 1. i have a model (emf meta model) in a plugin.
> 2. i have an oAW plugin which has the workflow and templates
> 3. model plugin is added as a dependancy to the oAW plugin.
> Now when I try to write template based on my emf meta model, xPand
> editor shows the following errors: "Couldn't find Company", "unknown
> enumeration literal or ... ". the template looks like so:
> «IMPORT com::project::company»
> «DEFINE Root FOR Company»
> «EXPAND expandProject FOR project»
> «ENDDEFINE»
> «DEFINE expandEcu FOR Project»
> «EXPAND expandEmp FOREACH employee»
> «ENDDEFINE».....
> i tried to ignore the errors and ran the workflow, then i got the
> following exceptions:
> workflow-description on line 1 'EXPAND template::Root::Root FOR model'
> org.openarchitectureware.expression.EvaluationException: No Definition
> 'template::Root::Root for com.project.company::Company' found! in
> (ExpandStatement.java:170)
> in properties of the oAW plugin, EMF Meta model is checked. I tried
> reloading the workbench, but still problem persists. Can anyone help me
> out on this.
> Chetan Kumar and Sandeepthi
Re: [xPand]template doesn't recognise metamodel data [message #376870 is a reply to message #376867] |
Sun, 22 April 2007 20:35 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
Hi Chetan,
the *.ecore file must be in a source folder.
regards,
Sven
Chetan Kumar wrote:
> Dear all,
> «ENDDEFINE»
> «ENDDEFINE».....
> out on this.
Re: [xPand]template doesn't recognise metamodel data [message #376874 is a reply to message #376869] |
Tue, 24 April 2007 08:36 |
Sylvain Messages: 40 Registered: July 2009 |
Member |
Hi Jacques,
Can you precise how you did that ? did you extends EmfMetaModel with
your own MM ?
> own metamodel.
> Regards,
> Jacques
>> Dear all,
>> «ENDDEFINE»
>> «ENDDEFINE».....
>> out on this.
>> Thanks,
Sylvain
Re: [xPand]template doesn't recognise metamodel data [message #376875 is a reply to message #376874] |
Tue, 24 April 2007 11:43 |
Yes, here are the two classes I made to contribute my own metamodel :
* This class is then referenced by the
"org.openarchitectureware.base.metamodelContributor" extension
public class DocBookMetamodelContributor implements MetamodelContributor
private DocBookMetaModel docbook = new DocBookMetaModel();
public MetaModel[] getMetamodels(final IJavaProject project, final
TypeSystem builtin)
return new MetaModel[] {docbook};
public class DocBookMetaModel extends EmfMetaModel
public DocBookMetaModel()
super(DocbookPackage.eINSTANCE);
But, as suggested Sven, the solution would be to include the ecore file
in a source folder. But I did not get this working, so I implemented
this solution.
Jacques
Sylvain a écrit :
> Hi Jacques,
> your own MM ?
>> Hi,
>> own metamodel.
>> Regards,
>> Jacques
>>> Dear all,
>>> follows:
>>> «ENDDEFINE»
>>> «ENDDEFINE».....
>>> out on this.
>>> Thanks,
Re: [xPand]template doesn't recognise metamodel data [message #376876 is a reply to message #376875] |
Tue, 24 April 2007 12:28 |
Member |
Thanks for the tips. Currently I have copied my MM in the source
folder..
> TypeSystem builtin)
> this solution.
> Regards,
> Jacques
> Sylvain a écrit :
>> Hi Jacques,
>> your own MM ?
>>> Hi,
>>> own metamodel.
>>> Regards,
>>> Jacques
>>>> Dear all,
>>>> follows:
>>>> «ENDDEFINE»
>>>> «ENDDEFINE».....
>>>> out on this.
>>>> Thanks,
Sylvain
Re: [xPand]template doesn't recognise metamodel data [message #376878 is a reply to message #376876] |
Wed, 25 April 2007 06:53 |
In fact I forgot to add a dependency to my metamodel project. Now that
works fine without the code below. :-)
Sylvain a écrit :
> Thanks for the tips. Currently I have copied my MM in the source folder..
>> TypeSystem builtin)
>> this solution.
>> Regards,
>> Jacques
>> Sylvain a écrit :
>>> Hi Jacques,
>>> your own MM ?
>>>> Hi,
>>>> handle my
>>>> own metamodel.
>>>> Regards,
>>>> Jacques
>>>>> Dear all,
>>>>> follows:
>>>>> «ENDDEFINE»
>>>>> «ENDDEFINE».....
>>>>> help me
>>>>> out on this.
>>>>> Thanks,
Re: [xPand]template doesn't recognise metamodel data [message #580346 is a reply to message #376867] |
own metamodel.
Jacques
> Dear all,
> «ENDDEFINE»
> «ENDDEFINE».....
> out on this.
Re: [xPand]template doesn't recognise metamodel data [message #580368 is a reply to message #376867] |
Hi Chetan,
regards,
Sven
Chetan Kumar wrote:
> Dear all,
> «ENDDEFINE»
> «ENDDEFINE».....
> out on this.
Re: [xPand]template doesn't recognise metamodel data [message #580531 is a reply to message #376869] |
Member |
Hi Jacques,
your own MM ?
> own metamodel.
> Regards,
> Jacques
>> Dear all,
>> «ENDDEFINE»
>> «ENDDEFINE».....
>> out on this.
>> Thanks,
Sylvain
Re: [xPand]template doesn't recognise metamodel data [message #580578 is a reply to message #376874] |
TypeSystem builtin)
this solution.
Jacques
Sylvain a écrit :
> Hi Jacques,
> your own MM ?
>> Hi,
>> own metamodel.
>> Regards,
>> Jacques
>>> Dear all,
>>> follows:
>>> «ENDDEFINE»
>>> «ENDDEFINE».....
>>> out on this.
>>> Thanks,
Re: [xPand]template doesn't recognise metamodel data [message #580599 is a reply to message #376875] |
Member |
folder..
> TypeSystem builtin)
> this solution.
> Regards,
> Jacques
> Sylvain a écrit :
>> Hi Jacques,
>> your own MM ?
>>> Hi,
>>> own metamodel.
>>> Regards,
>>> Jacques
>>>> Dear all,
>>>> follows:
>>>> «ENDDEFINE»
>>>> «ENDDEFINE».....
>>>> out on this.
>>>> Thanks,
Sylvain
Re: [xPand]template doesn't recognise metamodel data [message #580676 is a reply to message #376876] |
>> TypeSystem builtin)
>> this solution.
>> Regards,
>> Jacques
>> Sylvain a écrit :
>>> Hi Jacques,
>>> your own MM ?
>>>> Hi,
>>>> handle my
>>>> own metamodel.
>>>> Regards,
>>>> Jacques
>>>>> Dear all,
>>>>> follows:
>>>>> «ENDDEFINE»
>>>>> «ENDDEFINE».....
>>>>> help me
>>>>> out on this.
>>>>> Thanks,
Current Time: Wed Apr 24 15:16:28 GMT 2024
Powered by FUDForum. Page generated in 0.04148 seconds
