Re: How to invoke MOFSCRIPT from java code.. [message #375596 is a reply to message #375594] |
Thu, 02 November 2006 12:50 |
Jon Oldevik Messages: 17 Registered: July 2009 |
This is documented by an example in the latest MOFScript documentation
(see http://www.eclipse.org/gmt/mofscript/doc/ or
http://www.modelbased.net/mofscript/docs/MOFScript-User-Guid e.pdf).
Example code for parsing and executing is given below:
ParserUtil parserUtil = new ParserUtil();
ExecutionManager execMgr = ExecutionManager.getExecutionManager();
// The parserutil parses and sets the input transformation model
// for the execution manager.
File f = new File ("EcoreTest.m2t");
MOFScriptSpecification spec = parserUtil.parse(f, true);
// check for errors:
int errorCount = ParserUtil.getModelChecker().getErrorCount();
Iterator errorIt = ParserUtil.getModelChecker().getErrors(); // Iterator
of MofScriptParseError objects
System.out.println ("Parsing result: " + errorCount + " errors");
if (errorCount > 0) {
for (;errorIt.hasNext();) {
MofScriptParseError parseError = (MofScriptParseError) errorIt.next();
System.out.println("\t \t: Error: " + parseError.toString());
return;
// load source model
XMIResourceFactoryImpl _xmiFac = new XMIResourceFactoryImpl();
EObject sourceModel = null;
File sourceModelFile = new File ("SM.ecore");
ResourceSet rSet = new ResourceSetImpl ();
rSet.getResourceFactoryRegistry().getExtensionToFactoryMap() .put( "*",
_xmiFac);
URI uri = URI.createFileURI(sourceModelFile.getAbsolutePath());
Resource resource = rSet.getResource(uri, true);
if (resource != null) {
if (resource.getContents().size() > 0) {
sourceModel = (EObject) resource.getContents().get(0);
// set the source model for the exeution manager
execMgr.addSourceModel(sourceModel);
// sets the root output directory, if any is desired (e.g. "c:/temp")
execMgr.setRootDirectory("");
// if true, files are not generated to the file systsm, but populated
into a filemodel
// which can be fetched afterwards. Value false will result in standard
file generation
execMgr.setUseFileModel(false);
// Turns on/off system logging
execMgr.setUseLog(false);
// Adds an output listener for the transformation execution.
execMgr.getExecutionStack().addOutputMessageListener(this);
try {
execMgr.executeTransformation();
} catch (MofScriptExecutionException mex) {
mex.printStackTrace();
Gabriel Merin Cubero wrote:
> Hi! I have several MOFSCRIPT transformations but I would like to invoke
> them directly form my Java code, instead of using MOFSCRIPT interface.
> Hence, the user of my plug-in would be able to accomplish a
> transformation by means of right-click or just a button-click.
> Does anyone know how to accomplish this? Any hint? I've seen another
> post with the same problem but it does not have any reply.
> Thanks in advance,
> Gabriel Merin
Re: How to invoke MOFSCRIPT from java code.. [message #375598 is a reply to message #375596] |
Thu, 02 November 2006 15:27 |
Gabriel Merin Cubero Messages: 12 Registered: July 2009 |
Thank you very much Jon! It's been a great help.
Jon Oldevik escribió:
> Iterator of MofScriptParseError objects
> errors");
> errorIt.next();
> return;
> XMIResourceFactoryImpl(); EObject sourceModel = null;
> _xmiFac);
> "c:/temp")
> populated into a filemodel
> standard file generation
> // Turns on/off system logging execMgr.setUseLog(false);
> try {
>> invoke them directly form my Java code, instead of using MOFSCRIPT
>> interface. Hence, the user of my plug-in would be able to accomplish a
>> Thanks in advance,
>> Gabriel Merin
Re: How to invoke MOFSCRIPT from java code.. [message #560461 is a reply to message #375594] |
return;
_xmiFac);
into a filemodel
file generation
try {
> Thanks in advance,
> Gabriel Merin
Re: How to invoke MOFSCRIPT from java code.. [message #560474 is a reply to message #375596] |
> errors");
> errorIt.next();
> return;
> _xmiFac);
> "c:/temp")
> try {
>> Thanks in advance,
>> Gabriel Merin
FUDForum. Page generated in 0.02653 seconds
