Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SashForm not really visible
SashForm not really visible [message #375237] Mon, 06 October 2003 17:52 Go to next message
Originally posted by: Chris.TheFreyers.net
I'm working with a SashForm control, and it looks flat, not raised. I see
a plain grey line where I though I would see a raised bar. Does the
raised appearance happen because the surrounding controls use SWT.BORDER,
or do I need to do something in particular.
Note: I started with the snippet at
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -swt-home/dev.html
Thanks--
Chris
Re: SashForm not really visible [message #375254 is a reply to message #375237] Tue, 07 October 2003 14:05 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika IrvineFriend
Two things appear to be happening:
1) SashForm creates the Sash widgets without the style SWT.BORDER
2) SashForm has a default width of 3 pixels - on Windows XP, at this width
no border is drawn (event if the SWT.BORDER is applied to the Sashes). A
minimum width of 4 is required.
I entered the following bug report to track this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=44301
"Chris Freyer" <Chris@TheFreyers.net> wrote in message
news:blsa53$dcc$1@eclipse.org...
> Thanks--
> Chris
Re: SashForm not really visible [message #375327 is a reply to message #375254] Fri, 10 October 2003 01:04 Go to previous messageGo to next message
Thanks Veronika, but the problem still happens when I set the width to a
larger number. In order for the sash to appear raised, all my widgets
need to be placed on a composite, and it goes on into the SashForm.
Thanks--
Chris
> > Thanks--
> > Chris
Re: SashForm not really visible [message #375337 is a reply to message #375327] Fri, 10 October 2003 13:31 Go to previous message
That is because of point 1 in my reply - the Border style is not being
applied to the Sash objects created.
news:bm50ia$lts$1@eclipse.org...
> Thanks--
> Chris
width
A
see
SWT.BORDER,
> > > Thanks--
> > > Chris
Previous Topic:integration with outlook
Next Topic:How to add pluses near the TreeItem even it have not children
Current Time: Sat Jan 23 12:33:47 GMT 2021
Powered by FUDForum. Page generated in 0.01991 seconds
