Re: Traverse a BPMN diagram [message #375087 is a reply to message #375086] |
Tue, 16 June 2009 17:13 |
Originally posted by: atoulme.intalio.com
Hi Felix,
AFAIK there's no traversal implementation for this.
Given that the Resource is a tree, you can probably read it with a
TreeIterator, keep the elements that are of interest and build an object
model from there, or track the start event and follow its connections.
Antoine
Felix wrote:
> I generated a BPMN diagram and saved it in a file. For my further work I
> only need the *.bpmn file which contains the model without the visual
> information for the editor. This model I've already loaded with the help
> of a resourceSet into an object of BpmnPackage. My question is if there
> are already some methods to traverse this graph which is instantiate in
> an object from the type BpmnPackage.
> In my case I want to follow the process flow from a begin event to an
> end event.
> thx Felix
Re: Traverse a BPMN diagram [message #375089 is a reply to message #375088] |
Wed, 17 June 2009 12:15 |
Felix wrote:
> Thx Antoine,
> It's a pity. So I should code the tracking methode on my own. I've once
> read that you said that your metamodel out of the ecore set was highly
> customized in the source code. Do you have an uml diagram or something
> like that which represents the internal model of how you saved and
> structured the data of an bpmn diagram?
Yeah, of course everything is specified, no worries on that.
The BPMN modeler domain is explained here:
http://eclipse.org/bpmn/model/index.php
Frankly, a traversal parsing is always very specific to your needs and
it's best for you to code it yourself. It won't be too hard I think.
>> Hi Felix,
>> TreeIterator,
>> keep the elements that are of interest and build an object model from
>> there, or
>> Thanks,
>> Antoine
>> Felix wrote:
>> Hi,
>> end event.
>> thx Felix
>> Zum Beitrag:
>> http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.stp/ms g00727.html
Re: Traverse a BPMN diagram [message #621218 is a reply to message #375086] |
Hi Felix,
Antoine
Felix wrote:
> end event.
> thx Felix
Re: Traverse a BPMN diagram [message #621220 is a reply to message #375088] |
Felix wrote:
> Thx Antoine,
>> Hi Felix,
>> TreeIterator,
>> there, or
>> Thanks,
>> Antoine
>> Felix wrote:
>> Hi,
>> end event.
>> thx Felix
>> Zum Beitrag:
FUDForum. Page generated in 0.02628 seconds
