Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374796] |
Thu, 21 August 2008 08:08 |
Originally posted by: dali.xxxx.com
Hello Everybody,
i'm trying to integrate the bpmn modeler into my RCP plugin project.
my problem is that when i call the bpmn editor from my main class :
page.openEditor(new myeditinput("name"),BpmnEditor.ID,true);
it through a core exception :
org.eclipse.core.runtime.CoreException: ERROR
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createPartControl(DiagramDocumentEditor. java:1458)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at
org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2565)
at
ekipbpmodeler.ApplicationWorkbenchAdvisor.postStartup(Applic ationWorkbenchAdvisor.java:25)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2327)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at ekipbpmodeler.Application.start(Application.java:20)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
i read a recent topic that tells that it's possible to integrate it into
RCP.
Please Help,
Best Regards,
Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374800 is a reply to message #374799] |
Thu, 21 August 2008 14:53 |
Hi everybody ,
i'm still trying to integrate the bpmn modeler into my RCP Plugin project.
my question is it necessary that the editor input be based on an IFile.
please help me fixing this bug when i'm calling the editor :
IWorkspaceRoot myWorkspaceRoot = ResourcesPlugin.getWorkspace().getRoot();
IProject myWebProject =
myWorkspaceRoot.getProject("EkipBPModeler");
IFolder bpmnFolder = myWebProject.getFolder("BpmnFiles");
IFile file = bpmnFolder.getFile("test.bpmn_diagram");
FileEditorInput fileEditorInput = new FileEditorInput(file);
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
page.openEditor(fileEditorInput,BpmnEditor.ID,true);
I obtain this exception :
!STACK 1
org.eclipse.core.runtime.CoreException: Resource
'/EkipBPModeler/BpmnFiles/test.bpmn_diagram' does not exist.
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil.load(DiagramIOUtil.java:219)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil.load(DiagramIOUtil.java:145)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDiagramDocumentProvider.setDocumentContentFromStora ge(FileDiagramDocumentProvider.java:154)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.StorageDocumentProvider.setDocumentContent(StorageDocum entProvider.java:152)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDiagramDocumentProvider.setDocumentContent(FileDiag ramDocumentProvider.java:273)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.StorageDocumentProvider.createDocument(StorageDocumentP rovider.java:76)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDocumentProvider.createElementInfo(FileDocumentProv ider.java:476)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider.connect(AbstractDocumentProvider.j ava:387)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.doSetInput(DiagramDocumentEditor.java:42 6)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.setInput(DiagramDocumentEditor.java:389)
at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:318)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init( DiagramEditor.java:638)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.init(DiagramDocumentEditor.java:116)
at
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
ekipbpmodeler.ApplicationWorkbenchAdvisor.postStartup(Applic ationWorkbenchAdvisor.java:44)
at
at
at
at
at
at
at
org.eclipse.core.runtime.CoreException[1]:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Resource
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl$Workben chHelper.createPlatformResourceInputStream(URIConverterImpl. java:199)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createP latformResourceInputStream(URIConverterImpl.java:540)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:449)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:897)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil$FileLoader.load(DiagramIOUtil.java:83)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil.load(DiagramIOUtil.java:160)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.eclipse.core.internal.resources.ResourceException: Resource
at
org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:310)
at
org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:193)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:285)
at org.eclipse.core.internal.resources.File.getContents(File.ja va:276)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl$Workben chHelper.createPlatformResourceInputStream(URIConverterImpl. java:195)
... 68 more
!SUBENTRY 1 org.eclipse.gmf.runtime.diagram.ui.resources.editor 4 1
2008-08-21 16:52:49.642
!MESSAGE Resource '/EkipBPModeler/BpmnFiles/test.bpmn_diagram' does not
exist.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
!ENTRY org.eclipse.ui 4 0 2008-08-21 16:52:49.658
!MESSAGE org.eclipse.gef.DefaultEditDomain
!STACK 0
java.lang.ClassCastException: org.eclipse.gef.DefaultEditDomain
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.getDi agramEditDomain(DiagramEditor.java:576)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.getAc tionManager(DiagramEditor.java:1027)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.getOp erationHistory(DiagramEditor.java:1050)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.stopL istening(DiagramEditor.java:997)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFl yOutPalette.stopListening(DiagramEditorWithFlyOutPalette.jav a:585)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.setIn put(DiagramEditor.java:914)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.dispose(DiagramDocumentEditor.java:179)
at
org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditor.dispose( BpmnDiagramEditor.java:149)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:689)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!MESSAGE Unable to create editor ID ekipbpmodeler.BpmnEditor: An exception
was thrown during initialization
!STACK 0
at
org.eclipse.emf.transaction.util.TransactionUtil.getEditingD omain(TransactionUtil.java:50)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .DiagramModificationListener. <init>(DiagramModificationListener.java:55)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDiagramModificationListener. <init>(FileDiagramModificationListener.java:54)
at
org.eclipse.stp.bpmn.diagram.part.BpmnDocumentProvider$Custo mModificationListener. <init>(BpmnDocumentProvider.java:164)
at
org.eclipse.stp.bpmn.diagram.part.BpmnDocumentProvider.creat eFileInfo(BpmnDocumentProvider.java:114)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDocumentProvider.createElementInfo(FileDocumentProv ider.java:486)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Thanx for help,
Best regards ,
Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374801 is a reply to message #374800] |
Thu, 21 August 2008 15:22 |
Till Essers Messages: 92 Registered: July 2009 |
Member |
Hi Dali,
Test if your project exists and is open
if(myWebProject.exists() && myWebProject.isOpen())
The only reason I see is, that ... yeah, the file doesn't exist.
The methods like getProject, getFolder etc. doesn't test if the
requested resources are present, they only give you a link. The first
"test" of the resource is made when the editor is opened.
Greets
Till
Dali schrieb:
> Hi everybody ,
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Resource '/EkipBPModeler/BpmnFiles/test.bpmn_diagram' does not exist.
> at
> at
> at
> ... 68 more
> exist.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> exception was thrown during initialization
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanx for help,
> Best regards ,
> Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374806 is a reply to message #374805] |
Fri, 22 August 2008 09:24 |
Hi till ,
i create the project from
file->newProject->PluginDevelopment->Pluginproject.
i tryed to create it from code but it still through me this exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
ekipbpmodeler.ApplicationWorkbenchAdvisor.postStartup(Applic ationWorkbenchAdvisor.java:56)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
2008-08-22 11:17:38.074
exist.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
!ENTRY org.eclipse.ui 4 0 2008-08-22 11:17:38.105
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 2008-08-22 11:17:58.185
!MESSAGE The proxied handler for
'org.eclipse.gmf.runtime.diagram.ui.actions.internal.Duplica teActionDelegate'
could not be loaded
!ENTRY org.eclipse.ui 4 0 2008-08-22 11:17:58.185
could not be loaded
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.gmf.runtime.diagram.ui was unable to load class
org.eclipse.gmf.runtime.diagram.ui.actions.internal.Duplicat eActionDelegate.
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(Ha ndlerProxy.java:293)
at
org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(Hand lerProxy.java:262)
at org.eclipse.core.commands.Command.isEnabled(Command.java:831 )
at org.eclipse.core.commands.Command.setHandler(Command.java:93 8)
at
org.eclipse.ui.internal.handlers.HandlerAuthority.updateComm and(HandlerAuthority.java:535)
at
org.eclipse.ui.internal.handlers.HandlerAuthority.deactivate Handler(HandlerAuthority.java:256)
at
org.eclipse.ui.internal.handlers.HandlerService.deactivateHa ndler(HandlerService.java:144)
at
org.eclipse.ui.internal.handlers.HandlerService.deactivateHa ndlers(HandlerService.java:153)
at
org.eclipse.ui.internal.handlers.HandlerPersistence.clearAct ivations(HandlerPersistence.java:101)
at
org.eclipse.ui.internal.handlers.HandlerPersistence.dispose( HandlerPersistence.java:107)
at
org.eclipse.ui.internal.handlers.HandlerService.dispose(Hand lerService.java:159)
at
org.eclipse.ui.internal.services.ServiceLocator.dispose(Serv iceLocator.java:95)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:27 30)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:9 17)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:8 34)
at org.eclipse.ui.internal.Workbench$22.run(Workbench.java:1078 )
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1076)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1048)
at
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:696)
at
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:675)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:790)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:788)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:736)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:68 2)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:91)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:301)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1621)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3674 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:291)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1554)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:1753)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4351 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2260 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:456)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3760 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at
at
at
at
at
at
at
java.lang.ClassNotFoundException:
at java.lang.ClassLoader.findClass(Unknown Source)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:429)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2008-08-22 11:17:58.185
!MESSAGE Plug-in org.eclipse.gmf.runtime.diagram.ui was unable to load
class
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best Regards,
Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618493 is a reply to message #374799] |
Hi everybody ,
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
exist.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Thanx for help,
Best regards ,
Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618496 is a reply to message #374800] |
Member |
Hi Dali,
Greets
Till
Dali schrieb:
> Hi everybody ,
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> exist.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanx for help,
> Best regards ,
> Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618511 is a reply to message #374805] |
Hi till ,
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
exist.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
could not be loaded
could not be loaded
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
class
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best Regards,
Dali.
FUDForum. Page generated in 0.06212 seconds
