Re: How to updated the Generated web service? [message #374705] |
Thu, 01 May 2008 13:26 |
Originally posted by: ohurley.iona.com
Hi Arman,
Arman wrote:
> 1) STP has added annotations to the source of the defined Interface which
> is a littile starnge for developer. Now if developer wants to add a
> method, he have to not only define the signiture of the method (like the
> definition of the first method), but also should add approperiate
> annotations to the method. It is because STP generates the annotation only
> in the first time and in futher changes, it does not generate any
> annotation.
The STP service creation code "gets you started" by injecting
the relevant annotations when you choose your interface. It's
true that it does not continue to watch you as you extend the
interface. Do you think this would be a good feature? If so,
the best thing to do is to file an enhancement request at the
STP bugzilla! [0]
> 2) The generated WSDL file is not changed automatically after changing the
> definition of the Web Service in the Interface and developer must change
> it mannually. Therefore, he must know WSDL syntax which is not the case
> usually.
Well, that sounds like a bug to me. STP should be helping the
developer to keep as far away as they want from WSDL :) Can you
file a bug for it? [0]
best regards
Oisin
[0] https://bugs.eclipse.org/bugs/enter_bug.cgi?classification=S TP
Oisin Hurley at IONA
http://blogs.iona.com/ohurley/
FUDForum. Page generated in 0.03098 seconds
