Home » Archived » Service Oriented Architecture Tools Platform (STP) » RCP with stp bpmn editor
RCP with stp bpmn editor [message #374677] |
Tue, 15 April 2008 20:41  |
Originally posted by: fleabetto.libero.it
Hi everybody,
I'm new to the eclipse platform and i'm trying to make an rcp bpmn
editor with the Soa Tools Platform bpmn diagram editor.
My problem is, when i use the file -> "open file.." action to open a
"bpmn_diagram" file in the rcp workspace, the editor opens successfully
but if i try to open it programmatically with:
IFileStore store = EFS.getLocalFileSystem().getStore(file.getLocationURI());
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
IDE.openEditorOnFileStore(page, store);
or even with:
OpenLocalFileAction a = new OpenLocalFileAction();
a.init(PlatformUI.getWorkbench().getActiveWorkbenchWindow()) ;
a.run();
and browsing the same file in the rcp workspace, the editor crashes with
the following error in the log file:
!ENTRY org.eclipse.ui 4 0 2008-04-15 12:33:05.784
!MESSAGE Unable to create editor ID
org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditorID:
org.eclipse.core.runtime.CoreException: ERROR
!STACK 1
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createPartControl(DiagramDocumentEditor. java:1458)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2739)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at
org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2557)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1090)
at
org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:105)
at kbel2.NavigationView.openBPMNdiagramOnTree(NavigationView.ja va:872)
at kbel2.NavigationView$1.run(NavigationView.java:406)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:443)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at kbel2.Application.start(Application.java:20)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
!SUBENTRY 1 org.eclipse.gmf.runtime.diagram.ui.resources.editor 4 1
!MESSAGE ERROR
The same error occurs when i try to open with the "open file.." action a
bpmn_diagram file which is not in the workspace.
Sometimes in the eclipse console appears also this error, even when i
use the "open file..." action, but the editor opens anyway.
org.eclipse.core.runtime.CoreException: Problems encountered while
setting project description.
at
org.eclipse.core.internal.resources.Project.setDescription(P roject.java:983)
at
org.eclipse.core.internal.resources.Project.setDescription(P roject.java:1009)
at
org.eclipse.stp.bpmn.diagram.part.BpmnCreationWizardPage.set upBpmnValidationBuildableNature(BpmnCreationWizardPage.java: 140)
at
org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditor.setupBpm nValidationBuildAbleNature(BpmnDiagramEditor.java:85)
at
org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditor.setDocum entProvider(BpmnDiagramEditor.java:73)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.updateDocumentProvider(DiagramDocumentEd itor.java:359)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.doSetInput(DiagramDocumentEditor.java:41 4)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.setInput(DiagramDocumentEditor.java:389)
at
org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:318)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init( DiagramEditor.java:641)
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.init(DiagramDocumentEditor.java:116)
at
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
at
at
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Thanks to all in advance.
Andrea
Re: RCP with stp bpmn editor [message #374678 is a reply to message #374677] |
Tue, 15 April 2008 20:55   |
Originally posted by: atoulme.intalio.com
Hi Andrea,
the BPMN modeler was not designed to be used within a RCP application.
I think you will need to dive into the code for the first exception, it
seems the core exception occurs in the GMF framework.
Regarding the second one, it occurs when the modeler tries to set up the
validation builder to display problem markers on the diagram. That can
be avoided by tweaking the code a bit.
Please feel free to open bugs and contribute patches :)
Antoine
Andrea Devecchi wrote:
> Hi everybody,
> IFileStore store =
> or even with:
> a.run();
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> !MESSAGE ERROR
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Andrea
Re: RCP with stp bpmn editor [message #374679 is a reply to message #374677] |
Wed, 16 April 2008 12:06   |
Hi Andrea,
Antoine
> Hi everybody,
> IFileStore store =
> or even with:
> a.run();
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE ERROR
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Andrea
Re: RCP with stp bpmn editor [message #614284 is a reply to message #374677] |
Hi Andrea,
Antoine
> Hi everybody,
> IFileStore store =
> or even with:
> a.run();
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE ERROR
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Andrea
Re: RCP with stp bpmn editor [message #614286 is a reply to message #374677] |
Hi Andrea,
Antoine
> Hi everybody,
> IFileStore store =
> or even with:
> a.run();
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE ERROR
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Andrea
Re: RCP with stp bpmn editor [message #614457 is a reply to message #374678] |
Fri, 25 April 2008 13:05   |
Till Essers Messages: 92 Registered: July 2009 |
Member |
Hi Antoine,
I'm also trying to get the Editor running in an RCP application.
Can you give me a hind where to search for the Problem so I can provide
a patch?
Did Andrea open a bug?
Thanks in advance,
Till
Antoine Toulme schrieb:
> Hi Andrea,
> Antoine
>> Hi everybody,
>> successfully but if i try to open it programmatically with:
>> IFileStore store =
>> or even with:
>> a.run();
>> with the following error in the log file:
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> !MESSAGE ERROR
>> a bpmn_diagram file which is not in the workspace.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Andrea
Re: RCP with stp bpmn editor [message #614459 is a reply to message #614457] |
Fri, 25 April 2008 13:30   |
AFAIK Andrea didn't open a bug.
Since we are not developing the modeler as a RCP product we have no
knowledge of this information.
For now supporting RCP is not a goal of the component, but if you can
provide a patch to make it happen, we will take it.
Antoine
Till Essers wrote:
> Hi Antoine,
> a patch?
> Thanks in advance,
> Till
>> Hi Andrea,
>> it seems the core exception occurs in the GMF framework.
>> the validation builder to display problem markers on the diagram. That
>> can be avoided by tweaking the code a bit.
>> Thanks,
>> Antoine
>>> Hi everybody,
>>> IFileStore store =
>>> or even with:
>>> a.run();
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !MESSAGE ERROR
>>> action a bpmn_diagram file which is not in the workspace.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Andrea
Re: RCP with stp bpmn editor [message #614462 is a reply to message #614459] |
Fri, 25 April 2008 13:37   |
Member |
I'm confused. Intalio is selling the BPMS Designer, which is a RCP
application and is using the modeller. So there have to be a workaround,
right?
> Antoine
> Till Essers wrote:
>> Hi Antoine,
>> provide a patch?
>> Thanks in advance,
>> Till
>>> Hi Andrea,
>>> That can be avoided by tweaking the code a bit.
>>> Thanks,
>>> Antoine
>>>> Hi everybody,
>>>> IFileStore store =
>>>> or even with:
>>>> a.run();
>>>> !STACK 1
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !MESSAGE ERROR
>>>> i use the "open file..." action, but the editor opens anyway.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Andrea
Re: RCP with stp bpmn editor [message #614464 is a reply to message #614462] |
Fri, 25 April 2008 13:43   |
Till,
Intalio distributes its product as an Eclipse based product using the
Eclipse platform project. So we are reusing the workspace, having the
ability to call builders, markers, etc.
Antoine
> right?
>> Thanks,
>> Antoine
>> Till Essers wrote:
>>> Hi Antoine,
>>> provide a patch?
>>> Thanks in advance,
>>> Till
>>>> Hi Andrea,
>>>> Thanks,
>>>> Antoine
>>>>> Hi everybody,
>>>>> a "bpmn_diagram" file in the rcp workspace, the editor opens
>>>>> IFileStore store =
>>>>> or even with:
>>>>> a.run();
>>>>> !STACK 1
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !MESSAGE ERROR
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Andrea
Re: RCP with stp bpmn editor [message #614466 is a reply to message #614457] |
Fri, 25 April 2008 21:53   |
Member |
I managed to open the modeller after I added a project to the workspace.
Now I can receive an IFile to pass it to the editor. Now it works.
Not what I would like to have, but I'll try to figure out more.
So you can say it works in a RCP application :)
Will keep you updated.
best regards
Till
Till Essers schrieb:
> Hi Antoine,
> a patch?
> Thanks in advance,
> Till
>> Hi Andrea,
>> Thanks,
>> Antoine
>>> Hi everybody,
>>> IFileStore store =
>>> or even with:
>>> a.run();
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !MESSAGE ERROR
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Andrea
Current Time: Tue Mar 09 05:23:20 GMT 2021
Powered by FUDForum. Page generated in 0.03054 seconds
