Home » Archived » Service Oriented Architecture Tools Platform (STP) » BPMN Modeler Annotations
Re: BPMN Modeler Annotations [message #374604 is a reply to message #374603] |
Wed, 12 March 2008 12:03 |
Originally posted by: atoulme.intalio.com
Hi Roland, see comments inline:
Roland Gude wrote:
> my problem with the examples where that i did not really understand what
> they are about and a lot of guess work on my side was involved. I figure
> that i am missing some required knowledge to make sense of them.
> Thanks for the pointer to the other examples, they are a lot more
> accesible to me. Although i am not entirely sure i am on the right track
> here.
> Perhaps i should elaborate what i am trying to do.
> In my use case, we have a repository of predifined processes from which
> one can select those out of which a more complex workflow should be
> composed.
> The processes and its tasks are required to have certain identifiers
> which may vary in complexity.
> i.e. a task corresponds to some "realization" which is an existing
> program wich is identifiable by its name, a version and a location,
> where location may be omitted.
> So what i want to do is:
> have a task in the palette that allows these values to be populated with
> predefined values.
> i.e. you have a palette with to tasks, the first one will have the value
> for "name" set to "someProg" and the "version" set to "X.Y.Z"
> the other one will have "name" set to "somethingOtherProg" and so on...
You will need to override the palette item, and change its tool
(CreationToolEx) to return a command to create the activity as well as
its annotation with the extra values.
> i can put all these information in the name of the task, but i would
> have to do a lot of string manipulation to get this robust. Is there a
> way to store this information in annotations.
> All those annotations are text values, some may be editable some may not.
> It would be sufficient if those annotations that may be edible would be
> edited over the properties view.
The participant view integrates a property tab that does just that. You
might want to look at it.
> Any ideas how i could do that?
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
Re: BPMN Modeler Annotations [message #374605 is a reply to message #374604] |
Wed, 12 March 2008 14:07 |
Originally posted by: the_alien.heimlich-gut.de
I got a question about this participant example.
The property tab is always visible, what do I have to do, to make the
property tab only shows when a task is selected?
thx
Till
> Roland Gude wrote:
>> Hi,
>> what they are about and a lot of guess work on my side was involved. I
>> figure that i am missing some required knowledge to make sense of them.
>> track here.
>> which one can select those out of which a more complex workflow should
>> be composed.
>> with predefined values.
>> value for "name" set to "someProg" and the "version" set to "X.Y.Z"
>> be edited over the properties view.
Re: BPMN Modeler Annotations [message #374606 is a reply to message #374605] |
Wed, 12 March 2008 14:33 |
In the extension point
org.eclipse.ui.views.properties.tabbed.propertySections you can specify
the input for the property tab. For example you can refrain it to
Identifiable objects only.
If you want it only for tasks, just put Acivity instead.
Antoine
Till Essers wrote:
> Hi
> thx
> Till
>> Roland Gude wrote:
>>> Hi,
>>> I figure that i am missing some required knowledge to make sense of
>>> them.
>>> track here.
>>> should be composed.
>>> a way to store this information in annotations.
>>> not.
>> You might want to look at it.
Re: BPMN Modeler Annotations [message #374607 is a reply to message #374606] |
Wed, 12 March 2008 16:14 |
I've set the input just to org.eclipse.stp.bmpn.Activity but the tab
won't show up at all, even the breakpoint in createControls of
ParticipantPropertySection is never reached.
What am I doing wrong?
> Antoine
> Till Essers wrote:
>> Hi
>> thx
>> Till
>>> Roland Gude wrote:
>>>> Hi,
>>>> them.
>>>> track here.
>>>> should be composed.
>>> as its annotation with the extra values.
>>>> not.
Re: BPMN Modeler Annotations [message #374608 is a reply to message #374605] |
Wed, 12 March 2008 17:17 |
Hey Till,
the input element might not work well, but I don't remember why at the
moment.
Can you try using a filter instead ? (in the same extension point, as an
attribute of the propertySection element).
Let us know how it goes, and please feel free to open a bug and give us
a patch over the participantView that would restrain the properties tab
to activities, it would certainly help a lot of people.
Antoine
Till Essers wrote:
> Hi
> thx
> Till
>> Roland Gude wrote:
>>> Hi,
>>> them.
>>> track here.
>>> should be composed.
>>> not.
Re: BPMN Modeler Annotations [message #374609 is a reply to message #374608] |
Wed, 12 March 2008 18:38 |
I wrote a class that implements IFilter. After casting through 3 classes
in the toTest Object, I can access the Activity and check the
ActivityType. Now it's working pretty well, but... is it a normal
behaviour, that my filter is called 3 times everytime something is selected?
Till
PS:
Maybe you want to add this lines to your tutorial:
package mypropertiesplugin.participant.properties;
import org.eclipse.gmf.runtime.notation.impl.NodeImpl;
import org.eclipse.jface.viewers.IFilter;
import org.eclipse.stp.bpmn.Activity;
import org.eclipse.stp.bpmn.ActivityType;
import org.eclipse.stp.bpmn.diagram.edit.parts.ActivityEditPart;
public class PropertySectionFilter implements IFilter {
public boolean select(Object toTest) {
// TODO Auto-generated method stub
if(toTest instanceof ActivityEditPart) {
ActivityEditPart act = (ActivityEditPart) toTest;
if(((NodeImpl)act.getModel()).getElement() instanceof Activity){
Activity task = (Activity)((NodeImpl)act.getModel()).getElement();
if(task.getActivityType() == ActivityType.get(ActivityType.TASK)) {
return true;
return false;
> Hey Till,
> moment.
> Antoine
Re: BPMN Modeler Annotations [message #374610 is a reply to message #374609] |
Wed, 12 March 2008 18:47 |
Till,
I don't know, this code is part of platform I think.
I need you to attach the code here as a patch to a bugzilla entry to be
able to accept it.
Also you can access the semantic element directly from the edit part
through this method:
((IGraphicalEditPart) part).resolveSemanticElement();
Antoine
Till Essers wrote:
> Hi
> selected?
> Till
> PS:
> @Override
> Activity){
> Activity task =
> return true;
> return false;
>> Hey Till,
>> moment.
>> an attribute of the propertySection element).
>> us a patch over the participantView that would restrain the properties
>> tab to activities, it would certainly help a lot of people.
>> Thanks,
>> Antoine
Re: BPMN Modeler Annotations [message #374611 is a reply to message #374610] |
Wed, 12 March 2008 19:04 |
A bugzilla entry to change the tutorial?
Sorry I don't get it. This is not a patch, just an enhancement for the
tutorial for people like me and Roland Gude ;)
Sorry, I'm new to the eclipse community...
> Till,
> able to accept it.
> Antoine
Re: BPMN Modeler Annotations [message #374612 is a reply to message #374611] |
Wed, 12 March 2008 19:20 |
The Eclipse Foundation is very careful of the IP of its projects, which
is normal.
We need to track everything that gets committed to the SVN, so that we
can establish that the IP is clean.
When creating a profile in Bugzilla, you accept that all patches are
donated to the Eclipse Foundation under the EPL.
Have a look at the diagram I made here:
http://dev.eclipse.org/svnroot/stp/org.eclipse.stp.bpmn/trun k/samples/bpmn_samples/eclipse%20IP%20process/due%20diligenc e.jpg
Antoine
>> Till,
>> be able to accept it.
>> Thanks,
>> Antoine
Re: BPMN Modeler Annotations [message #613283 is a reply to message #374603] |
Roland Gude wrote:
> here.
> composed.
> predefined values.
Re: BPMN Modeler Annotations [message #613286 is a reply to message #374604] |
Till Essers Messages: 92 Registered: July 2009 |
Member |
thx
Till
> Roland Gude wrote:
>> Hi,
>> track here.
>> be composed.
Re: BPMN Modeler Annotations [message #613835 is a reply to message #374605] |
Antoine
Till Essers wrote:
> Hi
> thx
> Till
>> Roland Gude wrote:
>>> Hi,
>>> them.
>>> track here.
>>> should be composed.
>>> not.
Re: BPMN Modeler Annotations [message #613837 is a reply to message #374606] |
Member |
> Antoine
> Till Essers wrote:
>> Hi
>> thx
>> Till
>>> Roland Gude wrote:
>>>> Hi,
>>>> them.
>>>> track here.
>>>> should be composed.
>>>> not.
Re: BPMN Modeler Annotations [message #613839 is a reply to message #374605] |
Hey Till,
moment.
Antoine
Till Essers wrote:
> Hi
> thx
> Till
>> Roland Gude wrote:
>>> Hi,
>>> them.
>>> track here.
>>> should be composed.
>>> not.
Re: BPMN Modeler Annotations [message #613841 is a reply to message #374608] |
Member |
Till
PS:
return true;
return false;
> Hey Till,
> moment.
> Antoine
Re: BPMN Modeler Annotations [message #613843 is a reply to message #374609] |
Till,
able to accept it.
Antoine
Till Essers wrote:
> Hi
> selected?
> Till
> PS:
> @Override
> Activity){
> Activity task =
> return true;
> return false;
>> Hey Till,
>> moment.
>> Thanks,
>> Antoine
Re: BPMN Modeler Annotations [message #613847 is a reply to message #374611] |
is normal.
Antoine
>> Till,
>> Thanks,
>> Antoine
Current Time: Thu Apr 25 04:23:06 GMT 2024
Powered by FUDForum. Page generated in 0.05191 seconds
