Re: [ATL] Model Copy/Clone [message #374171 is a reply to message #374170] |
Wed, 01 October 2008 19:47 |
Alexandre Torres Messages: 139 Registered: July 2009 |
The error persisted. I think I was able to fix it, commenting the "name"
feature of VariableExp:
fv : ATL!VariableExp (
--name <- 's',
referredVariable <- ipe
v : distinct ATL!NavigationOrAttributeCallExp foreach(sf in sfs) (
name <- sf.name,
source <- src
src : distinct ATL!VariableExp foreach(sf in sfs) (
--name <- 's',
The transformation now works with the Am3-Atl bundle. I could them use the
"extract atl model to file" menu option to generate the atl file, and it
worked.
And the best part is, it works on the new ATL, so I need the old bundle
just to generate the clone maker transformation.
After that I tried the clone with a superimposed transformation and it
worked.
Looks like everything is going to work now!
Thanks for the support.
I suggest someone take a note to update the Zoo with this fix, if it's a
bug (I can file a bugzila)
Alexandre
Re: [ATL] Model Copy/Clone [message #374172 is a reply to message #374171] |
Wed, 01 October 2008 22:14 |
Originally posted by: freddy.allilaire.univ-nantes.fr
--------------060303060508050000080508
I don't know if it is a bug (maybe an update in ATL metamodel). If you
could open a bugzilla entry, this will be great to track this problem.
Freddy.
Alexandre Torres a
Re: [ATL] Model Copy/Clone [message #562994 is a reply to message #374170] |
--name <- 's',
name <- sf.name,
source <- src
--name <- 's',
worked.
worked.
Alexandre
FUDForum. Page generated in 0.03598 seconds
