Home » Archived » Service Oriented Architecture Tools Platform (STP) » service discovery in bpmn designer
Re: service discovery in bpmn designer [message #374056 is a reply to message #374055] |
Fri, 06 April 2007 18:28 |
Originally posted by: atoulme.intalio.com
Hi Kagan,
the version 4 is based on a different modeler, an iLog one.
We are working towards the release of the version 5 of our modeler,
which should embed the BPMN designer.
If you have questions regarding the community edition of Intalio's
designer, you should consult our community website:
http://bpms.intalio.com
Otherwise I think you got the spirit of our modeler. We do the mapping
to WSDLs by drag and dropping the ports to the pools, then the messages
over the messaging flows.
A lot more is to come.
Antoine
Kagan Turgut wrote:
> disclaimer: i am just getting warned up with the bpmn designer.
> i went through the first few tutorials where it describes importing a
> wsdl to bring it to the diagrammer.
> our mda platform generates a bunch of plugins with Java classes which we
> plan to expose as services, preferably using SCA to give us flexibility
> in binding.
> (i could also generate wsdl if that is the only way to go at this point?)
> i want to be able to pre-configure process definitions that talk to my
> generated services to drastically minimize the work that otherwise the
> user will have to do.
> what is the best way to expose these services automatically in the bpmn
> designer?
> reading ismael's blog
> (http://itredux.com/blog/2007/04/04/get-your-bpmn-schema- today/) i
> understand that there is now a model file that is saved that is purely
> about the process definitions. but in the version (4.0.0.8) i downloaded
> from intalio web site, I can't locate such a file.
> Ideally these process definitions are modeled in EMF and saved as XML
> file. That would make our life a lot easier.
> Thanks in advance,
> Kagan Turgut
> www.brane.com
Re: service discovery in bpmn designer [message #374057 is a reply to message #374056] |
Fri, 06 April 2007 18:48 |
Kagan Turgut Messages: 12 Registered: July 2009 |
Antoine,
More questions:
When is version 5 due? Does the CVS repository reflect the latest and
greatest of the development of version 5, or are you going to check-it
in in one batch?
Our MDA platform is itself bootstrapped from models, highly leveraging
EMF representing platform specific models. I am hoping that we can get a
tight integration at the model level, in addition to publishing wsdls
for you to consume.
How far are you in defining your EMF model? Do you have a UML
representation of it?
Will the process models saved as xml files (independent of the graphical
layout) with version 5.0?
Will we be able to generate these process files to get our users started
faster?
Do you interact with SCA at all?
Is "drag and drop" the only way to bring-in existing wsdls to the
diagrammar. Do you have the concept of reading registered service
definitions from a directory?
Kagan
Antoine Toulme wrote:
> Hi Kagan,
> Regards,
> Antoine
>> we plan to expose as services, preferably using SCA to give us
>> flexibility in binding.
>> bpmn designer?
>> downloaded from intalio web site, I can't locate such a file.
>> Thanks in advance,
>> Kagan Turgut
>> www.brane.com
Re: service discovery in bpmn designer [message #374058 is a reply to message #374057] |
Fri, 06 April 2007 19:07 |
Hi Kagan,
Kagan Turgut wrote:
> Antoine,
> More questions:
> in in one batch?
We tend to work by batches, though the development over the modeler is
being more and more stable. We should do a commit batch hopefully next week.
> for you to consume.
We are trying to have a good modeler. We have a generation API, and you
can extend it very significantly by using annotations.
Yes, it's here.
http://www.eclipse.org/stp/bpmn/model/index.php
Yes. The semantic model will be saved in a bpmn file, while the
graphical model is saved in a bpmn_diagram file. Just like in the
Eclipse modeler.
> faster?
There is a generation API that you can use to generate the process.
I don't think so.
This is more related to our commercial product. We will provide you some
pointers directly.
> Kagan
>> Hi Kagan,
>> messages over the messaging flows.
>> Regards,
>> Antoine
>>> point?)
>>> my generated services to drastically minimize the work that otherwise
>>> the user will have to do.
>>> bpmn designer?
>>> purely about the process definitions. but in the version (4.0.0.8) i
>>> Thanks in advance,
>>> Kagan Turgut
>>> www.brane.com
Re: service discovery in bpmn designer [message #374068 is a reply to message #374055] |
Fri, 25 May 2007 18:05 |
Originally posted by: carrasco.ModelDrivenDevelopment.co.uk
I believe Ismael is talking about BPDM,
the semantic foundation now in adoption at the OMG,
to suppy to BPMN notation a solid underlying process semantics,
adding SOA and choreography support to BPMN.
You may find some info at
http://www.modeldriven.org/
and
http://www.omg.org/docs/bmi/06-09-12.pdf
or
http://www.omg.org/archives/bpmn-ftf/pptj9lw9aW6qL.ppt
As there is usually a struggle between process specific specs,
and the Unique Modeling Language camp,
you may directly see a classic attack and response at:
http://bpmfocus.wordpress.com/2007/04/22/loosing-touch-with- reality/
By the way, Eclipse SCA is derived from the same original work from 8 years
ago.
"Kagan Turgut" <kagan.turgut@brane.com> wrote in message
news:ev62om$qn7$1@build.eclipse.org...
> i went through the first few tutorials where it describes importing a wsdl
> plan to expose as services, preferably using SCA to give us flexibility in
> binding.
> designer?
> Thanks in advance,
> Kagan Turgut
> www.brane.com
Re: service discovery in bpmn designer [message #587436 is a reply to message #374055] |
Hi Kagan,
Antoine
> in binding.
> designer?
> Thanks in advance,
> Kagan Turgut
> www.brane.com
Re: service discovery in bpmn designer [message #587447 is a reply to message #374056] |
Antoine,
More questions:
in in one batch?
for you to consume.
faster?
Kagan
> Hi Kagan,
> Regards,
> Antoine
>> bpmn designer?
>> Thanks in advance,
>> Kagan Turgut
>> www.brane.com
Re: service discovery in bpmn designer [message #587458 is a reply to message #374057] |
Hi Kagan,
Kagan Turgut wrote:
> Antoine,
> More questions:
> in in one batch?
> for you to consume.
Yes, it's here.
Eclipse modeler.
> faster?
I don't think so.
pointers directly.
> Kagan
>> Hi Kagan,
>> Regards,
>> Antoine
>>> point?)
>>> bpmn designer?
>>> Thanks in advance,
>>> Kagan Turgut
>>> www.brane.com
Re: service discovery in bpmn designer [message #589255 is a reply to message #374055] |
and
or
ago.
> binding.
> designer?
> Thanks in advance,
> Kagan Turgut
> www.brane.com
Current Time: Thu Apr 25 12:40:37 GMT 2024
Powered by FUDForum. Page generated in 0.03900 seconds
