Re: Help with annotations [message #38272 is a reply to message #38174] |
Mon, 08 March 2004 16:02 |
Lance,
The appinfo element can contain any nested XML so you should have a source
attribute to uniquely identify the appinfo as yours and then have some XML
syntax for describing the information, kind of like <hfp:xyz> stuff in the
schema for schemas. You might also consider encoding the information as a
non-schema namespace attribute, kind of like the ecore:xyz annotations we
support for specifying the mapping to Ecore.
Lance Phillips wrote:
> Ed,
> I need some help with annotations. We have several extension properties
> for XSDSimpleTypeDefinitions that we'd like to persist via Annotations.
> What is the best practice for capturing name value pairs in the appInfo?
> The tricky part is that the values may contain all readable characters so we
> can't simply use a delimited string. We'd prefer to use XML, but if I
> remember correctly there are issues with capturing XML in the appInfo value
> field.
> thanks,
> Lance Phillips
Re: Help with annotations [message #38404 is a reply to message #38371] |
Mon, 08 March 2004 22:53 |
Lance,
This sounds fine.
> Ed,
> I actually found a very simple approach that seems to meet our needs.
> Under the appinfo element I've simply added our tags as dom Attr entities.
> It outputs beautifully and seems to meet all our needs. Are there any
> dangers that I should be aware of with this approach?
> thanks,
> lp
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:404C990C.A8F2B6F1@ca.ibm.com...
> > Lance,
> > > Ed,
> properties
> so we
> value
> > > field.
> > > thanks,
> > > Lance Phillips
Re: Help with annotations [message #583932 is a reply to message #38174] |
Ed Merks Messages: 33140 Registered: July 2009 |
Lance,
> Ed,
> field.
> thanks,
> Lance Phillips
Ed Merks
Re: Help with annotations [message #584003 is a reply to message #38371] |
Lance,
This sounds fine.
> Ed,
> thanks,
> lp
> > Lance,
> > > Ed,
> properties
> so we
> value
> > > field.
> > > thanks,
> > > Lance Phillips
Ed Merks
FUDForum. Page generated in 0.03957 seconds
