Re: authorPerson metadata not in XCN format [message #38735 is a reply to message #38139] |
Mon, 10 December 2007 18:42 |
Jesse Pangburn Messages: 166 Registered: July 2009 |
Hi all,
Just an update on this. Due to various points of view on this currently
being discussed, Bill has relaxed this restriction on the public registry
again. For now, you should be able to run the provide and registry
transaction with the current version of the bridge just fine. I haven't
tried myself, but Bill says it's done.
thanks,
Jesse
Jesse Pangburn wrote:
> Hi all,
> According to an email Bill just sent, the public registry is now changing
> the way the authorPerson attribute must be formatted. From his email:
> 2) There has been a problem discovered with the formatting of the
> authorPerson attribute (Submission Set and DocumentEntry). The XDS profile
> requires this attribute to be in XCN format. See 4.1.7 Document Definition
> Metadata for the definition of XCN. The update affects these things
> The metadata validator has been updated (in xdstest2, the Public Registry,
> and the web tool)
> The metadata in the testkit has been updated
> Test data loaded into the Public Registry
> This change has been made to the Public Registry!!!
> I tried a provide and register from the bridge and it is indeed failing
> now. The registry returns:
> <rs:RegistryError codeContext="ExtrinsicObject urn:uuid:727134ec-
> b26a-42ae-d4ad-000f1f9e1110 has a author type classification
> (classificationScheme=urn:uuid:93606bcf-9494-43ec-9b4e-a7748 d1a838d)
> with authorPerson slot that is not in XCN format. The value found was
> 11111111^Wiseman^Bernard^^Sr.^Dr.^^^&1.3.5.35.1.4436 .7&ISO "
> errorCode="XDSRegistryMetadataError" location="MetadataValidator.java"
> severity="Error" />
> thanks,
> Jesse
Re: authorPerson metadata not in XCN format [message #38767 is a reply to message #38735] |
Mon, 10 December 2007 23:41 |
No real name Messages: 292 Registered: July 2009 |
yep. And guess who is the lucky soul that gets to write the change
proposal edit to IHE for this ;-)
- Sarah
> Hi all,
> registry again. For now, you should be able to run the provide and
> registry transaction with the current version of the bridge just fine.
> I haven't tried myself, but Bill says it's done.
> thanks,
> Jesse
>> Hi all,
>> changing the way the authorPerson attribute must be formatted. From
>> his email:
>> profile requires this attribute to be in XCN format. See 4.1.7
>> Document Definition Metadata for the definition of XCN. The update
>> Registry, and the web tool) The metadata in the testkit has been
>> updated Test data loaded into the Public Registry This change has been
>> failing now. The registry returns:
>> severity="Error" />
>> thanks,
>> Jesse
Re: authorPerson metadata not in XCN format [message #583758 is a reply to message #38139] |
Hi all,
thanks,
Jesse
> Hi all,
> and the web tool)
> severity="Error" />
> thanks,
> Jesse
Re: authorPerson metadata not in XCN format [message #583779 is a reply to message #38735] |
- Sarah
> Hi all,
> thanks,
> Jesse
>> Hi all,
>> his email:
>> severity="Error" />
>> thanks,
>> Jesse
FUDForum. Page generated in 0.03279 seconds
