Finding difficult to select an context menu [message #37934] |
Sat, 30 May 2009 16:07 |
Anand Kumar Gupta Messages: 14 Registered: July 2009 |
I have defined some menu declaratively in plugin.xml. And i want to select
menu at first level.
I am getting following error when i use below mentioned stt.
treeNode.select().contextMenu("<Name>").click(); stack trace:
org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundExcep tion: The
widget {(an instance of org.eclipse.swt.widgets.MenuItem and with mnemonic
'<Menu Name>')} was disposed.
at
org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.<init>(AbstractSWTBot.java:96)
at
org.eclipse.swtbot.swt.finder.widgets.SWTBotMenu.<init>(SWTBotMenu.java:42)
at
org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.context Menu(AbstractSWTBot.java:383)
at
org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.context Menu(AbstractSWTBot.java:356)
at
TestDeregisterMountArtifact.testDeregister(TestDeregisterMou ntArtifact.java:75)
at
at
at junit.framework.TestCase.runTest(TestCase.java:164)
at junit.framework.TestCase.runBare(TestCase.java:130)
at
org.eclipse.swtbot.swt.finder.SWTBotTestCase.runBare(SWTBotT estCase.java:228)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:130)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.main( RemotePluginTestRunner.java:64)
at
org.eclipse.swtbot.eclipse.core.UITestApplication.runTests(U ITestApplication.java:123)
at
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:68)
at java.lang.Thread.run(Thread.java:619)
FUDForum. Page generated in 0.02537 seconds
