[ATL] how to keep reference to source Model in target model [message #37903] |
Tue, 15 May 2007 13:44 |
Originally posted by: sylvain.maillard.univ-nantes.fr
Hi all,
I have another question: in my generated eCore model I want to create
EAnnotation attached to EClass, that reference the source model.
I have added a called rule like:
rule createAnnotation(elem: mma!Element)
to a: MOF!EAnnotation (
source <- elem.eClass().name,
-- problem here: how to force the selection of element from source
model ???
references <- Sequence {elem}
do
a;
This work, but I get a reference to the generated Element, not the
source one. Is there a tips to avoid the automatic mapping from source
to target ?
Please help !
thanks
Sylvain
Sylvain
Re: [ATL] how to keep reference to source Model in target model [message #38028 is a reply to message #37903] |
Tue, 15 May 2007 15:22 |
Frédéric Jouault Messages: 572 Registered: July 2009 |
> source model ???
> do
> a;
Why not simply create the EAnnotation as an additional target element of
the rule that creates the EClass?
> to target ?
This issue is discussed in [1] at the end of section 2.2.
In your case, this would look like:
do {
a.refSetValue('references', Sequence {elem});
You may use this "do" block in the rule that creates both the EClass and
the EAnnotation. If you still want to use a called rule, you will need
to add "a;" after the assignment.
Frédéric Jouault
[1] Jouault, F : Loosely Coupled Traceability for ATL. In: Proceedings
of the European Conference on Model Driven Architecture (ECMDA) workshop
on traceability, Nuremberg, Germany.
http://www.sciences.univ-nantes.fr/lina/atl/bibliography/ECM DA_05
Re: [ATL] how to keep reference to source Model in target model [message #38092 is a reply to message #38028] |
Tue, 15 May 2007 16:04 |
thanks for your reply,
I've tried this solution but no elements seems to be returned after
refSetValue. I have added a debug like this:
a.refSetValue('references', Sequence {elem}).debug('refers to: ');
but the result is always:
refers to: OUT!<unnamed>
I also tried to put the creation of annotation in the main rule but
I'have the same result.
> Hello,
> > source model ???
> > do
> > a;
> Why not simply create the EAnnotation as an additional target element of the
> > to target ?
> do {
> You may use this "do" block in the rule that creates both the EClass and the
> EAnnotation. If you still want to use a called rule, you will need to add
> Regards,
> Frédéric Jouault
> [1] Jouault, F : Loosely Coupled Traceability for ATL. In: Proceedings of the
> European Conference on Model Driven Architecture (ECMDA) workshop on
Sylvain
Re: [ATL] how to keep reference to source Model in target model [message #38455 is a reply to message #38190] |
Tue, 15 May 2007 17:38 |
> Hello,
> I forgot to tell you that you have to enable cross-model references in the
> advanced tab of the launch config :-).
It was a good advice ;-))
now It works..
thanks
Sylvain
> Best regards,
> Frédéric Jouault
Sylvain
FUDForum. Page generated in 0.03072 seconds
