SWT on Irix? [message #371283] |
Thu, 26 June 2003 20:24 |
Originally posted by: jima.alumni.rice.edu
I have unfortunately found myself among many machines running IRIX. Has
anyone successfully built the motif version of SWT on SGI Irix? Also,
would trying to get eclipse to run on Irix be a waste of time because of
performance and graphics problems?
Re: SWT on Irix? [message #371394 is a reply to message #371295] |
Wed, 02 July 2003 04:47 |
Thanks Grant. I think I've successfully built the SWT-motif library on
Irix 6.5. It requires some futzing if Motif 2.1 is not the default
environment. Irix has the feature of having both 1.2 and 2.1.
I haven't been able to find the CDE headers. Is cde.c necessary for
running Eclipse on Motif 2.1?
Jim
Grant Gayed wrote:
> Hi Jim,
> I haven't heard of anyone trying this, but it shouldn't be too different
> from building for any other platform with motif, as long as the available
> motif version is >= 2.1. The extra work that I can think of is writing a
> make_irix.mak (probably based on an existing make_*.mak file) and updating
> build.sh to invoke it. Doing these will be required for both the swt
> library and the launcher.
> FAQ links, in case you haven't seen them yet:
> http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#howbuilddll
> http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#buildeclipseexe
> Grant
Re: SWT on Irix? [message #371551 is a reply to message #371430] |
Tue, 08 July 2003 11:43 |
Originally posted by: wayneh.adacel.com
Hi Grant, Jim,
(sorry can't reply to Jims post, don't see it listed anymore?)
I have been successful in building SWT (and the launcher) on Irix,
but I would be interested in what problems Jim had with Motif1.2 vs 2.1,
cause it didn't seem much on an issue for me.
What is an issue for me is that eclipse doesn't run, it starts but I get
an error from the launcher when it tries to "StartJVM". Seems I have
an issue with the the JNI call to Motif.
Either running:
eclipse (irix launcher)
or
java -cp ./startup.jar org.eclipse.core.launcher.Main -ws motif
(which is basically what the launcher does)
I get:
Assertion failed: y1 <= y2, file Region.c, line 1238, pid i83417
Abort (core dumped)
and
A dialog with stating the jvm didn't start and the call (including args)
that was made.
The call at the top of the stack which creates this assertion is
XmManageChild (I think).
Short of debugging motif (which I started, but haven't found anything yet),
I am sort of lost as to where to go from here. And also as to what the
problem
really is and what is causing it. Has anyone seen something like this
before?
Any suggestions as to where to go next?
BTW I am using JDK1.4.
WayneH
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:bdutff$nkv$1@rogue.oti.com...
> Hi Jim,
> cde isn't necessary; its primary use is for opening Eclipse resources in
> system editors (ie.- select a resource, right-click, Open With -> System
> Editor) instead of the default Eclipse editor. This isn't core to using
> Eclipse unless you're really attached to using specific editors on irix.
> Grant
> > Jim
> > Grant Gayed wrote:
> > > Hi Jim,
different
available
writing a
updating
q.html#howbuilddll
> > > Grant
Has
of
FUDForum. Page generated in 0.02383 seconds
