Home » Archived » M2M (model-to-model transformation) » [ATL] how to find an already generated element in non-declarative rules ?
[ATL] how to find an already generated element in non-declarative rules ? [message #37805] |
Tue, 15 May 2007 08:46 |
Originally posted by: sylvain.maillard.univ-nantes.fr
Hi All,
I'm stuck with a simple (?) problem: I want to transform a model (MA)
that conforms to a home-made metamodel (MMA) into another model that
conforms to eCore.
In my MMA, I have an element that can be combined with itself (i.e.
Element has a collection of <Element> called 'elements').
I want to transform these elements into EClass, so I have a declarative
rule that takes a Element in its 'from' clause and produce a EClass in
its 'to' clause.
But now I want the collection 'elements' to become a EReference in the
target model.
Because there is no corresponding entity in my source model, I can not
create a declarative rule for this transformation.
So I have added a called rule that create the new EReference, but I
can't see how to find the target of my EReference, which must be an
already generated EClass...
I understand that ATL can find target elements from the input elements,
but I think this can work only for declarative rules ??
Please Help !
Thanks in advance,
Sylvain
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #37935 is a reply to message #37805] |
Tue, 15 May 2007 13:58 |
Ok forget it,
In my called rule that create EReference, I'have added a parameter that
is the eType of eReference. As the rule is called from a declarative
rule, ATL is able to find the correct target element.
> Hi All,
> I'm stuck with a simple (?) problem: I want to transform a model (MA) that
> conforms to a home-made metamodel (MMA) into another model that conforms to
> eCore.
> In my MMA, I have an element that can be combined with itself (i.e. Element
> I want to transform these elements into EClass, so I have a declarative rule
> that takes a Element in its 'from' clause and produce a EClass in its 'to'
> clause.
> But now I want the collection 'elements' to become a EReference in the target
> model.
> Because there is no corresponding entity in my source model, I can not create
> So I have added a called rule that create the new EReference, but I can't see
> how to find the target of my EReference, which must be an already generated
> EClass...
> I understand that ATL can find target elements from the input elements, but I
> Please Help !
> Thanks in advance,
> Sylvain
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #37969 is a reply to message #37805] |
Tue, 15 May 2007 14:00 |
Originally posted by: rchevrel.sodius.com
--------------030309010002050208030700
Hi Sylvain,
I cannot completely understand your problem but I think this code could
help you.
rule root {
from
in_elm1 : MMa!Element
to
out_elm1 : ECore!EClass ()
rule elements {
from
-- you match a relation
e1 : MMa!Element,
e2 : MMA!Element (
e1.elements->includes(e2)
to
out_elm1 : ECore!EReference (
-- you attach this element with its parent
eContainer <- e1
out_elm2 : ECore!EReference (
eContainer <- e2,
-- you set the opposite
eOpposite <- out_elm1
You could also use a lazy rule.
Please send a concrete example if you have some problems.
*R
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #37999 is a reply to message #37969] |
Tue, 15 May 2007 14:17 |
Hi Regis,
With your code I think I can remove the called rule ! I did not see
this tips to match the relation.
thanks
Sylvain
> Hi Sylvain,
> I cannot completely understand your problem but I think this code could help
> you.
> rule root {
> from
> to
> rule elements {
> from
> e1 : MMa!Element,
> e2 : MMA!Element (
> to
> eContainer <- e1
> eContainer <- e2,
> *Régis CHEVREL* <mailto:rchevrel@sodius.com>
> SODIUS*
> *6, rue Cornouaille
> 44319 Nantes - France
> Phone: +33 (0)2 28 23 54 34
> ***www.mdworkbench.com* <http://www.mdworkbench.com/>* *
> Draw more value from your model
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #38059 is a reply to message #37969] |
Tue, 15 May 2007 15:48 |
Hi Régis
> Hi Sylvain,
> you.
> rule root {
> from
> to
> rule elements {
> from
> e1 : MMa!Element,
> e2 : MMA!Element (
> to
> eContainer <- e1
Unfortunately this doesn't work as eContainingClass from MOF is not
modifiable. It seems that a newly created EReference cannot be attached
to another EClassifier like that. I must explicitly add it to
eStructuralFeatures features of the EClass :-(
> eContainer <- e2,
> SODIUS*
> *6, rue Cornouaille
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #38157 is a reply to message #38125] |
Tue, 15 May 2007 16:30 |
Hi again,
> Hello Sylvain,
> >> rule elements {
> >> from
> >> e1 : MMa!Element,
> >> e2 : MMA!Element (
> >> to
> >> eContainer <- e1
> Being able to navigate and set references in both directions is *very* useful
> in model transformation, especially when using a declarative style.
> Here is an excerpt of a slide on metamodeling hints that I give to students:
> * Define bidirectional associations (i.e., pairs of references)
> => Makes the model easier to navigate and populate
> It seems that Ecore was not designed by model transformation developers :-).
I agree with you on that point ;-)
> A quick and dirty (i.e., imperative) way to solve your problem would be to
> add an action block to rule "elements" to perform the setting in the opposite
> direction:
> do {
> e1.eStructuralFeatures <- out_elm1;
well, I dont understand that: e1 refers to my input model, so it
doesn't have the eStructuralFeatures ! In order to do this I must get
the generated target eClass and I think it's bad ;-)
do
giveMeTheGeneratedEClassFor(e1).eStructuralFeatures <- out_elm1;
should solve my problem ;-)
> Best regards,
> Frédéric Jouault
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #38324 is a reply to message #38258] |
Tue, 15 May 2007 17:10 |
> Hello again,
> >> be to add an action block to rule "elements" to perform the setting in
> >> the opposite direction:
> >> do {
> > well, I dont understand that: e1 refers to my input model, so it doesn't
> > have the eStructuralFeatures ! In order to do this I must get the
> > do
> Of course, you are right. I so much focused on the reverse setting part of
> the issue that I missed this ;-).
> giveMeTheGenerated<something>For is called resolveTemp in ATL.
> This case is one of the rare cases when we are going to actually use
> resolveTemp to resolve to the default target element (because we are doing it
> in an imperative block):
> do {
> thisModule.resolveTemp(e1, 'out_elm1').eStructuralFeatures <- out_elm1;
Well I tried this and I get an EmptyStackException... I dont understand
why: every elements should have been created at this time ?
> Best regards,
> Frédéric Jouault
Sylvain
Re: [ATL] how to find an already generated element in non-declarative rules ? [message #38422 is a reply to message #38324] |
Tue, 15 May 2007 17:21 |
>> Hello again,
>> >> do {
>> > do
>> it in an imperative block):
>> do {
> Well I tried this and I get an EmptyStackException... I dont understand why:
OK my mistake: the second parameter of resolveTemp should be set to the
same name as the one specified in the rule used to create the parent
element ! in my case it was 'class' rather than 'out_elm1'.
Thanks for your help Frédéric ;-)
>> Best regards,
>> Frédéric Jouault
Sylvain
Current Time: Tue Apr 23 09:30:55 GMT 2024
Powered by FUDForum. Page generated in 0.04406 seconds
