Creating a Web Service using WTP [message #37729] |
Tue, 10 August 2004 01:30  |
Just playing with the WTP contributions...
Firstly followed instructions verbatim in the docs...
1. Set up Tomcat 4.1 (in preference to 5.0)
2. Created Convertor Project (Dynamic Web Project)
3. Selected Create Web Services
4. Selected the Tomcat 4.1 installation etc etc.
Then get an error
at
com.ibm.etools.webservice.axis.creation.ui.widgets.bean.Vali dateObjectSelectionCommand.execute(Va
lidateObjectSelectionCommand.java:93)
at
com.ibm.env.command.fragment.CommandFragmentEngine.runComman d(CommandFragmentEngine.j
ava:312)
at
com.ibm.env.command.fragment.CommandFragmentEngine.visitTop( CommandFragmentEngine.java:
278)
at
com.ibm.env.command.fragment.CommandFragmentEngine.moveForwa rdToNextStop(CommandFrag
mentEngine.java:198)
at
com.ibm.env.widgets.SimpleCommandEngineManager$4.run(SimpleC ommandEngineManager.java:
196)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:303)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:253)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 752)
at
com.ibm.env.widgets.SimpleCommandEngineManager.runForwardToN extStop(SimpleCommandEngine
Manager.java:165)
at
com.ibm.env.internal.widgets.WizardPageManager.runForwardToN extStop(WizardPageManager.java:
59)
at
com.ibm.env.internal.widgets.WizardPageManager.getNextPage(W izardPageManager.java:81)
at
com.ibm.env.internal.widgets.SimpleWizardPage.getNextPage(Si mpleWizardPage.java:113)
at
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:674)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:300)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:506)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1196)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1220)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1205)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2865)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2535)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
at
com.ibm.env.widgets.popup.DynamicPopupWizard.run(DynamicPopu pWizard.java:112)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:276)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:
915)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:866)
at
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:785)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
This is different from other posted problems (mainly due to Tomcat 5.0 and
arrangement of
directories.
Any ideas???
I will mention that the system is on a mac OS-X - latest version and
updates and uses 1.4.2 java
I use that mac as it is the only system that I do not have to reboot and
reload every 3 months!!!
Jeff
FUDForum. Page generated in 0.05987 seconds
