Re: performance issue when sorting a group [message #368371 is a reply to message #368353] |
Tue, 26 May 2009 15:09 |
Originally posted by: jasonweathersby.windstream.net
Mike,
Can you open a bugzilla entry for this and provide your test case?
Jason
Mike wrote:
> We have found that several of our reports take increasingly long to
> complete as the data set size increases, but the time is more
> exponential than linear. The common attributes of these reports are
> groups on a table that have a sort key.
> In one of our reports with a data set of 200k rows it will complete in
> under 10 minutes without sorting. This time includes rendering the
> report to a PDF. However adding a sort key will increase that time to
> over 18 hours to complete!
> While profiling my Java application (with the BIRT engine) we have found
> that the majority of the time is spent in
> GroupInformationUtil.mergeTwoGroupBoundaryInfoGroups()
> I have a very simple test case that I can provide. It includes a flat
> file that is used as a datasource and two .rptdesign files, one with a
> sort key and one without. In my Eclipse environment, viewing the
> unsorted report as a PDF takes approximately 30 seconds. Attempting to
> view the sorted report runs indefinitely.
> This seems to indicate a performance issue in BIRT with sorting data
> sets. Has anyone else experienced similar performance problems?
Re: performance issue when sorting a group [message #368454 is a reply to message #368444] |
Fri, 29 May 2009 20:29 |
Mike,
Wenfeng has responded to both bugs.
Jason
Mike wrote:
> Jason, thanks for your reply. I did find that increasing the memory
> buffer by adding an entry in the appContext with the key
> org.eclipse.birt.data.query.ResultBufferSize and a value higher than the
> default of 10 MB does allow us to prevent BIRT from using the disk cache
> in some cases. But there will always be an even larger resultset that
> will cause BIRT to use the disk.
> However this particular setting does not seem to have any impact on my
> problem. It does help delay the inevitable with very large resultsets,
> and we have this bug opened for the large resultset problem:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=277908
> The problem seems to be how the DiskCache moves the cursor through the
> resultset. In that bug post you can see the exponential nature by
> looking at the call stack in the report named DiskCache.html. The 654
> invocations of DiskCache.moveTo() result in nearly 31 million calls to
> DiskCache.next()!
> It seems like, at least in our test case, that DiskCache is attempting
> to move the cursor to the end of the resultset each time it is called.
> This causes a ton of disk IO thereby taking a very long time to complete.
> The bug I entered - https://bugs.eclipse.org/bugs/show_bug.cgi?id=277885
> - is also a problem with BIRT accessing the disk millions of times. In
> this case it is when it is grouping/sorting data. We can attempt to
> "workaround" the problem by increasing the number of elements BIRT keeps
> in memory in BasicCachedList.java. It is hard coded to 4000, and if we
> increase this to 500,000 then my test cases that use to take several
> hours will complete in around a minute.
> We do not feel that either of these workarounds can be delivered because
> we are bumping up against memory limitations. These are critical issues
> for us and therefore I would think that other users in the BIRT
> community have experienced these same issues. Is it possible to get
> these bugs into the 2.3.2.2 release that is still in development?
Re: performance issue when sorting a group [message #542677 is a reply to message #542460] |
Fri, 25 June 2010 15:09 |
On 6/24/2010 6:22 PM, Ryan wrote:
> It looks like the 2 links you posted are no longer working.
> I tried to search around and find the links, but have not yet been able
> to find any.
> Could you post a new set of lines on cache configuration?
> Ryan
Look at:
http://www.eclipse.org/forums/index.php?t=msg&th=120380& amp;
The cache configuration message I can not locate, but the contents of it
are listed below:
Performance have been improved via a combination of memory and disk
cache ( http://www.eclipse.org/birt/phoenix/project/notable2.0.php#j ump_11).
But I can't find how to configure this; for exemple, disable it, use
only memory cache, etc...
Nicolas
Nicolas,
You can set the memory cache size by using the following.
task.getAppContext().put("org.eclipse.birt.data.query.ResultBufferSize ",
new Integer(20));
Size is specified in MB.
You should be able to set this for the viewer using:
http://wiki.eclipse.org/Adding_an_Object_to_the_Application_ Context_for_the_Viewer_%28BIRT%29
Jason
Hi Jason,
can you please explain the other constants defined in
org.eclipse.birt.data.engine.api.DataEngine too:
DATA_SET_CACHE_ROW_LIMIT = "org.eclipse.birt.data.cache.RowLimit"
DATA_SET_CACHE_DELTA_FILE = "org.eclipse.birt.data.cache.DeltaFile"
MEMORY_DATA_SET_CACHE = "org.eclipse.birt.data.cache.memory"
How can I use them to improve the performance?
Thanks in advance!
Spunk
I believe the other settings have to do with setting the cache
configuration while in the designer. In 2.2.1 there is suppose to be
a project to improve the caching of datasets between containers.
Jason
Hello (again),
I looked how to use DataEngine.MEMORY_DATA_SET_CACHE, but I can't get it
working.
I can set it to 0 or 10 000, it doesn't seem to change anything.
The logs indicates that the memory cache is always used and it takes
always 0 sec (even on big reports)
That's why I'm wondering if this option is really working...
Also I found in DataEngineContext several constants to configure the
cache (CACHE_MODE_IN_DISK, CACHE_MODE_IN_MEMORY, CACHE_USE_DISABLE), but
I don't know how to use them, how to set a DataEngineContext and set it
to my EngineTask.
Nicolas
Nicolas,
What version of BIRT are you using?
Jason
I'm using Birt 2.2.0 (and waiting for the 2.2.1 ... :-)
Nicolas
Nicolas,
I thought this was working properly in 2.2. I do not believe you can
set it below 1 MB. Create a bugzilla entry if you want to get more details.
Jason
Jason
FUDForum. Page generated in 0.03683 seconds
