Re: XML Data Source does not work with https URLs? [message #367579 is a reply to message #367570] |
Mon, 23 March 2009 15:18 |
Simon,
I believe this is a known limitation
https://bugs.eclipse.org/bugs/show_bug.cgi?id=265969
I have not tried to use a custom class to work around this issue, but it
may be worth a try. Take a look at this article
http://www.birt-exchange.com/devshare/designing-birt-reports /461-birt-web-service-oda-article/#description
There is a section on using a custom class.
Jason
Simon Godden wrote:
> I am using a RESTful web service to return XML for a XML Data Source.
> The web service is protected by Basic HTTP Authentication.
> When I use regular http scheme, it works fine. An authentication dialog
> is popped up and the data retrieved.
> When I attempt to use https scheme, I always get the following error:
> "org.eclipse.datatools.connectivity.oda.OdaException: XML data source
> cannot be retrieved.XML data source file is invalid or the file doesn't
> exist."
> Does XML Data Source support https?
FUDForum. Page generated in 0.01674 seconds
