Re: SQL Editor and Database Browser - Refresh does not display the newly created schema [message #37807 is a reply to message #37719] |
Mon, 29 October 2007 20:49 |
Hi Brian,
I use:
Derby Embedded Database and Derby v. 10.2.2.0.
The statement I'm running is
create schema sixsigma;
I have the database connected while running the statement. F5 / right mouse
click -> refresh does not show the new schema. After disconnect and connect
the schema is visible.
Best regards, Lars
"Brian Fitzpatrick" <brianf@sybase.com> wrote in message
news:fg557k$pmu$1@build.eclipse.org...
> Hi Lars...
> What are you using as your profile and DBMS to reproduce this? We can take
> a look. But typically if you right-click on the root node under the
> profile in the DSE and select Refresh, it should pick up your changes.
> --Brian Fitzpatrick
> "Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
> news:fft150$agq$1@build.eclipse.org...
>> Hi,
>> If I create a SQL script to create a schema and run it I have to
>> disconnect and connect to the database to get this schema displayed.
>> Is this a bug which I should report via bugzilla?
>> Best regards, Lars
Re: SQL Editor and Database Browser - Refresh does not display the newly created schema [message #40085 is a reply to message #37807] |
Wed, 19 December 2007 16:56 |
Originally posted by: brianf.sybase.com
Hi Lars...
Can you create a BZ entry for this so we can take a look at it for the
Ganymede release?
--Fitz
news:fg5gvv$eau$1@build.eclipse.org...
> Hi Brian,
> I use:
> mouse click -> refresh does not show the new schema. After disconnect and
> connect the schema is visible.
> Best regards, Lars
>> Hi Lars...
>> take a look. But typically if you right-click on the root node under the
>> --Brian Fitzpatrick
>>> Hi,
>>> Best regards, Lars
Re: SQL Editor and Database Browser - Refresh does not display the newly created schema [message #588350 is a reply to message #37719] |
Hi Brian,
I use:
Best regards, Lars
> Hi Lars...
> --Brian Fitzpatrick
>> Hi,
>> Best regards, Lars
FUDForum. Page generated in 0.03614 seconds
