Add multiple Detail Columns (Birt Engine) [message #366694] |
Wed, 21 January 2009 21:46 |
Originally posted by: sadsdfd.asds.com
I am trying to write an application that adds 2 cloumns to a table. It works
fine with the first one:
table = elementFactory.newTableItem( null, 3, 1, 1, 1 );
PropertyHandle computedSet = table.getColumnBindings( );
DataItemHandle data = null;
RowHandle detail = null;
ComputedColumn cs1, cs2 = null;
// Create Detail for first column.
cs1 = StructureFactory.createComputedColumn( );
cs1.setName("firstName");
cs1.setExpression( "dataSetRow[\"firstName\"]" );//$NON-NLS-1$
computedSet.addItem( cs1 ); //Add an item to the end of a list property
// Create Detail for second column.
cs2 = StructureFactory.createComputedColumn( );
cs2.setName("lastName");
cs2.setExpression( "dataSetRow[\"lastName\"]" );//$NON-NLS-1$
computedSet.addItem( cs2 ); //Add an item to the end of a list property
// Add first column to report.
detail = (RowHandle) table.getDetail( ).get( 0 ); //returns the first
slot.
tcell = (CellHandle) detail.getCells( ).get( 0 );
data = elementFactory.newDataItem( null );
data.setResultSetColumn( cs1.getName( ) );
tcell.getContent( ).add( data );
// Add second column to report (ERROR!)
detail = (RowHandle) table.getDetail( ).get( 1 ); //returns the first
slot.
tcell = (CellHandle) detail.getCells( ).get( 1 );
data.setResultSetColumn( cs2.getName( ) );
// Finally add the updated table to the report design.
reportDesignHandle.getBody( ).add( table );
But that give a nullpointer exception. It assume that its because I do
..get(1) but how do I add more than one details column?
Re: Add multiple Detail Columns (Birt Engine) [message #366697 is a reply to message #366694] |
Wed, 21 January 2009 23:17 |
Originally posted by: jasonweathersby.alltel.net
Do you have 2 detail rows?
this returns a second detail row.
> slot.
try
> slot.
Jason
> works fine with the first one:
> slot.
> slot.
Re: Add multiple Detail Columns (Birt Engine) [message #366702 is a reply to message #366697] |
Thu, 22 January 2009 11:50 |
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:gl8af2$5uf$2@build.eclipse.org...
> > slot.
> try
> > slot.
> Jason
No I have one details row, but would like to access/write-to the second
column of that details row. To access the second column I just needed to do:
// Add Second Column to report.
slot.
tcell = (CellHandle) detail.getCells( ).get( 1 ); // access second column.
FUDForum. Page generated in 0.03351 seconds
