Home » Archived » BIRT » page number formatting in footer
Re: page number formatting in footer [message #366569 is a reply to message #366568] |
Mon, 12 January 2009 12:57 |
Originally posted by: thilo.bruesshaber.gmail.com
I've seen this behaviour first time in BIRT 2.3.1.
It seem that this happens when an automatic pagebreak occurs.
Jason?
PC schrieb:
> In my pdf report (using BIRT 2.3.1) I am displaying (master page -
> footer) page number.
> For that I am using grid with 1 row and 4 cells (Page, Page Number, / ,
> Total Page). Idea is to display like this:
> Page 1 / 3
> Page 2 / 3
> Page word is internationalised, so comes from properties file.
> But formatting is not not good, one is there is gap in values (even
> after removing margins) and formatting gets lost in next page (I am not
> sure why as this is in footer of master page so should be consistent,
> any thoughts?), Please see attached images.
> Is there a better way to do this?
> Thanks.
> - Parvez
Re: page number formatting in footer [message #366576 is a reply to message #366572] |
Mon, 12 January 2009 18:11 |
Can you post the report?
Jason
PC wrote:
> So it could be a Bug in BIRT 2.3.1 ?
> Is there other/better way to achieve the same?
> Thanks.
>> Jason?
>> PC schrieb:
>>> Hi,
>>> , Total Page). Idea is to display like this:
>>> Page 1 / 3
>>> Page 2 / 3
>>> not sure why as this is in footer of master page so should be
>>> consistent, any thoughts?), Please see attached images.
>>> Thanks.
>>> - Parvez
Re: page number formatting in footer [message #366626 is a reply to message #366576] |
Thu, 15 January 2009 11:40 |
Parvez Messages: 181 Registered: July 2009 |
--------------010404070900040507000709
Hi Jason,
Please find enclosed report. You won't be able to run it as it uses
number of java handlers which in turn uses number of other plugins. I
just renamed it to xml.
Thanks for your help.
- Parvez
> Jason
>> Thanks.
>>> Jason?
>>> PC schrieb:
>>>> Hi,
>>>> / , Total Page). Idea is to display like this:
>>>> Page 1 / 3
>>>> Page 2 / 3
>>>> Thanks.
>>>> - Parvez
Content-Type: text/xml;
name="reportdesign.xml"
Content-Disposition: inline;
filename="reportdesign.xml"
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17" id="1">
<property name="author">pchauhan</property>
<property name="createdBy">Eclipse BIRT Designer Version 2.3.1.v20080911 Build <2.3.1.v20080917-1340></property>
<property name="units">in</property>
<simple-property-list name="includeResource">
<value>localization/pas_reports</value>
</simple-property-list>
<text-property name="title">Project_1</text-property>
<property name="comments">Copyright (c) 2007 <<Your Company Name here>></property>
<html-property name="description">Creates a blank report with no predefined content.</html-property>
<property name="theme">pas.PASTheme</property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<list-property name="libraries">
<structure>
<property name="fileName">libraries/pas.rptlibrary</property>
<property name="namespace">pas</property>
</structure>
</list-property>
<data-sources>
<script-data-source name="iec1131_DS" id="344"/>
</data-sources>
<data-sets>
<script-data-set name="iec1131_POUsDataSet" id="345">
<property name="eventHandlerClass"> com.pilz.pas.iec1131.report.eventhandler.POUsDataSetEventHan dler </property>
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">Name</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CreationDate</property>
<property name="dataType">date-time</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">TaskProperties</property>
<property name="dataType">any</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">Author</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">Name</property>
</structure>
<structure>
<property name="columnName">CreationDate</property>
</structure>
<structure>
<property name="columnName">TaskProps</property>
</structure>
<structure>
<property name="columnName">Code</property>
</structure>
<structure>
<property name="columnName">TaskProperties</property>
</structure>
<structure>
<property name="columnName">Author</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">iec1131_DS</property>
</script-data-set>
</data-sets>
<styles>
<style name="crosstab-cell" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="PASHeaderFooter" id="183" extends="pas.PASHeaderFooter">
<property name="footerHeight">0.5in</property>
</simple-master-page>
<simple-master-page name="PASHeaderFooterLandscape" id="289" extends="pas.PASHeaderFooterLandscape"/>
</page-setup>
<body>
<grid name="pformProjectOuterGrid" id="217">
<property name="pageBreakAfter">auto</property>
<property name="width">100%</property>
<column id="218"/>
<row id="295">
<cell id="296">
<property name="paddingTop">50pt</property>
<property name="textAlign">left</property>
<image id="294">
<property name="height">83px</property>
<property name="width">80px</property>
<property name="source">file</property>
<expression name="uri">"images/pas_logo.jpg"</expression>
</image>
</cell>
</row>
<row id="297">
<cell id="298">
<property name="paddingTop">20pt</property>
<property name="textAlign">center</property>
<label name="pformProjectDetails" id="300">
<property name="fontSize">14pt</property>
<property name="fontWeight">bold</property>
<text-property name="text" key="projectDetails"></text-property>
</label>
</cell>
</row>
<row id="219">
<cell id="220">
<grid name="pformProjectInfoGrid" id="221">
<property name="marginTop">20pt</property>
<property name="marginBottom">auto</property>
<property name="width">65%</property>
<column id="222"/>
<column id="223"/>
<row id="224">
<cell id="225">
<property name="paddingTop">5pt</property>
<property name="paddingLeft">5pt</property>
<label name="pfromProjectNameLbl" id="244">
<property name="style">large-bold</property>
<property name="fontSize">12pt</property>
<property name="marginTop">0pt</property>
<text-property name="text" key="project"></text-property>
</label>
</cell>
<cell id="226">
<property name="paddingBottom">1pt</property>
<property name="paddingRight">5pt</property>
<text name="pfromProjectName" id="245">
<property name="eventHandlerClass"> com.pilz.pas.platform.report.logic.eventhandlers.ProjectInfo EventHandler </property>
</text>
</cell>
</row>
<row id="230">
<cell id="231">
<property name="paddingTop">1pt</property>
<property name="paddingBottom">5pt</property>
<label name="pformProjectAuthorLbl" id="268">
<text-property name="text" key="author"></text-property>
</label>
</cell>
<cell id="232">
<property name="paddingLeft">1pt</property>
<text name="pformProjectAuthor" id="276">
</text>
</cell>
</row>
<row id="301">
<cell id="302">
<label name="pformVersionLbl" id="310">
<text-property name="text" key="version"></text-property>
</label>
</cell>
<cell id="303">
<text name="pformVersion" id="311">
</text>
</cell>
</row>
<row id="307">
<cell id="308">
<label name="pformCreationDateLbl" id="312">
<text-property name="text" key="creationDate"></text-property>
</label>
</cell>
<cell id="309">
<text name="pformCreationDate" id="313">
</text>
</cell>
</row>
<row id="304">
<cell id="305">
<label name="pformLastModifiedDateLbl" id="314">
<text-property name="text" key="lastModifiedDate"></text-property>
</label>
</cell>
<cell id="306">
<text name="pformLastModifiedDate" id="315">
</text>
</cell>
</row>
</grid>
</cell>
</row>
</grid>
<grid name="pformCompanyAddressGrid" id="318">
<property name="marginTop">300pt</property>
<property name="pageBreakAfter">always</property>
<column id="319"/>
<row id="320">
<cell id="321">
<label name="pformCompanyAddress1Lbl" id="336">
<property name="fontSize">small</property>
<text-property name="text">Pilz GmbH & Co. KG Sichere Automation</text-property>
</label>
</cell>
</row>
<row id="322">
<cell id="323">
<label name="pformCompanyAddress2Lbl" id="337">
<text-property name="text">Felix-Wankel-Straße 2</text-property>
</label>
</cell>
</row>
<row id="324">
<cell id="325">
<label name="pformCompanyAddress3Lbl" id="338">
<text-property name="text">73760 Ostfildern</text-property>
</label>
</cell>
</row>
<row id="326">
<cell id="327">
<label name="pformCompanyAddress4Lbl" id="339">
<text-property name="text">Germany</text-property>
</label>
</cell>
</row>
<row id="328">
<cell id="329">
<label name="pformCompanyAddress5Lbl" id="340">
<text-property name="text">Tel.: +49 711 3409-0</text-property>
</label>
</cell>
</row>
<row id="330">
<cell id="331">
<label name="pformCompanyAddress6Lbl" id="341">
<text-property name="text">Fax: +49 711 3409-133</text-property>
</label>
</cell>
</row>
<row id="332">
<cell id="333">
<label name="pformCompanyAddress7Lbl" id="342">
<text-property name="text">E-Mail: pilz.gmbh@pilz.de</text-property>
</label>
</cell>
</row>
<row id="334">
<cell id="335">
<label name="pformCompanyAddress8Lbl" id="343">
<text-property name="text">Web: www.pilz.de</text-property>
</label>
</cell>
</row>
</grid>
<label name="iec1131_title" id="156">
<property name="style">tool-title</property>
<structure name="toc">
<expression name="expressionValue">reportContext.getMessage('iec1131', reportContext.getLocale())</expression>
</structure>
<text-property name="text" key="pous"></text-property>
</label>
<table name="iec1131_pousTbl" id="346">
<property name="canShrink">true</property>
<property name="dataSet">iec1131_POUsDataSet</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["Name"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["CreationDate"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["Author"]</expression>
</structure>
<structure>
<property name="name">Code</property>
<expression name="expression">dataSetRow["Code"]</expression>
</structure>
<structure>
<property name="name">TaskProps</property>
<expression name="expression">dataSetRow["TaskProperties"]</expression >
</structure>
</list-property>
<property name="pageBreakInterval">50</property>
<column id="370">
<property name="width">1.2083333333in</property>
</column>
<column id="371"/>
<detail>
<row id="390">
<property name="borderBottomColor">#C0C0C0</property>
<property name="borderBottomStyle">dotted</property>
<property name="borderBottomWidth">1px</property>
<property name="borderLeftColor">#C0C0C0</property>
<property name="borderLeftWidth">1px</property>
<property name="borderRightColor">#C0C0C0</property>
<property name="borderRightWidth">1px</property>
<property name="borderTopColor">#C0C0C0</property>
<property name="borderTopWidth">1px</property>
<cell id="391">
<label id="393"/>
</cell>
<cell id="392">
<label id="394"/>
</cell>
</row>
<row id="395">
<cell id="396">
<label name="iec1131_pouNameLbl" id="397">
<property name="style">light-color-label</property>
<text-property name="text" key="name"></text-property>
</label>
</cell>
<cell id="398">
<data name="iec1131_pouName" id="347">
<property name="resultSetColumn">Name</property>
</data>
</cell>
</row>
<row id="360">
<cell id="399">
<label name="iec1131_pouCreationDateLbl" id="400">
</label>
</cell>
<cell id="348">
<data name="iec1131_pouCreationDate" id="349">
<property name="resultSetColumn">CreationDate</property>
</data>
</cell>
</row>
<row id="361">
<cell id="401">
<label name="iec1131_pouAuthorLbl" id="402">
</label>
</cell>
<cell id="350">
<data name="iec1131_pouAuthor" id="351">
<property name="resultSetColumn">Author</property>
</data>
</cell>
</row>
<row id="428">
<cell id="429">
<label id="431">
<property name="color">#626262</property>
<text-property name="text" key="taskProperties">Task Properties</text-property>
</label>
</cell>
<cell id="430">
<text name="iec1131_TaskPropsText" id="590">
<property name="eventHandlerClass"> com.pilz.pas.iec1131.report.eventhandler.TaskDataEventHandle r </property>
<property name="contentType">html</property>
</text>
</cell>
</row>
<row id="362">
<cell id="591">
<label name="iec1131_pouCodeLbl" id="592">
<text-property name="text" key="code"></text-property>
</label>
</cell>
<cell id="352">
<text name="iec1131_CodeText" id="593">
<property name="eventHandlerClass"> com.pilz.pas.iec1131.report.eventhandler.POUDataHTMLEventHan dler </property>
</text>
</cell>
</row>
</detail>
</table>
</body>
</report>
--------------010404070900040507000709--
Re: page number formatting in footer [message #366630 is a reply to message #366626] |
Thu, 15 January 2009 18:56 |
For some reason this did not come in with a master page. Can you just
post the xml to the reply?
Jason
PC wrote:
> Hi Jason,
> - Parvez
>> Jason
>>> Thanks.
>>>> Jason?
>>>> PC schrieb:
>>>>> Hi,
>>>>> Page 1 / 3
>>>>> Page 2 / 3
>>>>> Thanks.
>>>>> - Parvez
Re: page number formatting in footer [message #366650 is a reply to message #366630] |
Mon, 19 January 2009 13:35 |
--------------070106050504090102080305
Content-Type: text/plain; charset=windows-1252; format=flowed
Hi Jason,
Master page is in library, forgot to attach it, sorry.
Please find enclosed. Master page name is: PASHeaderFooter, id 156
Thanks.
- Parvez
> Thanks
> Jason
> PC wrote:
>> Hi Jason,
>> - Parvez
>>> Jason
>>>> Thanks.
>>>>> Jason?
>>>>> PC schrieb:
>>>>>> Hi,
>>>>>> - footer) page number.
>>>>>> Number, / , Total Page). Idea is to display like this:
>>>>>> Page 1 / 3
>>>>>> Page 2 / 3
>>>>>> (even after removing margins) and formatting gets lost in next
>>>>>> page (I am not sure why as this is in footer of master page so
>>>>>> should be consistent, any thoughts?), Please see attached images.
>>>>>> Thanks.
>>>>>> - Parvez
name="pas.rptlibrary"
filename="pas.rptlibrary"
<library xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17" id="1">
<value>localization/pas_reports_en</value>
<property name="comments">Copyright (c) 2008 Pilz</property>
<property name="theme">PASTheme</property>
<themes>
<theme name="PASTheme" id="2">
<list-property name="cssStyleSheets">
<structure>
<property name="fileName">css/pas.css</property>
</structure>
</list-property>
</theme>
</themes>
<page-setup>
<simple-master-page name="PASHeaderFooter" id="156">
<property name="type">a4</property>
<property name="topMargin">0.25in</property>
<property name="leftMargin">0.25in</property>
<property name="bottomMargin">0.02in</property>
<property name="rightMargin">0.25in</property>
<property name="headerHeight">0.5in</property>
<property name="footerHeight">0.3in</property>
<page-header>
<grid name="headerMainGrid" id="146">
<property name="backgroundAttachment">scroll</property>
<property name="backgroundPositionX">0%</property>
<property name="backgroundPositionY">0%</property>
<property name="borderBottomColor">#000000</property>
<property name="borderBottomWidth">thin</property>
<column id="147">
<property name="width">4.96875in</property>
</column>
<column id="148"/>
<row id="149">
<property name="backgroundColor">#FEAA02</property>
<cell id="11">
<property name="backgroundRepeat">repeat</property>
<property name="verticalAlign">middle</property>
</cell>
<cell id="13">
<property name="textAlign">right</property>
<image name="pilzLogo" id="14">
<property name="height">30px</property>
<property name="width">52px</property>
<expression name="uri">"images/pilz_logo3.jpg"</expression>
<text-property name="altText">Company Logo</text-property>
<structure name="action">
<property name="linkType">none</property>
</structure>
</image>
</cell>
</row>
</grid>
</page-header>
<page-footer>
<grid name="NewGrid" id="185">
<property name="borderTopColor">#000000</property>
<property name="borderTopWidth">thin</property>
<column id="186"/>
<column id="187"/>
<column id="188"/>
<row id="189">
<cell id="190">
<grid name="toolAndModifiedGrid" id="193">
<column id="194"/>
<row id="195">
<cell id="196">
<label name="toolNameAndVersionLabel" id="200">
<text-property name="text" key="toolNameAndVersion"></text-property>
</label>
</cell>
</row>
</grid>
</cell>
<cell id="191">
<text name="projectName" id="12">
<property name="eventHandlerClass"> com.pilz.pas.platform.report.core.eventhandlers.ProjectNameE ventHandler </property>
<property name="fontWeight">normal</property>
</text>
</cell>
<cell id="192">
<grid name="pageNumberGrid" id="212">
<property name="width">55%</property>
<column id="213"/>
<column id="214"/>
<column id="215"/>
<column id="216"/>
<row id="217">
<cell id="218">
<property name="paddingRight">0pt</property>
<label name="pageNumberLbl" id="222">
<text-property name="text" key="page"></text-property>
</label>
</cell>
<cell id="219">
<property name="paddingLeft">0pt</property>
<auto-text name="pageNumberTxt" id="207">
<property name="paddingTop">0pt</property>
<property name="type">page-number</property>
</auto-text>
</cell>
<cell id="220">
<text name="pageNumberSepTxt" id="209">
<property name="contentType">plain</property>
<text-property name="content"><![CDATA[/]]></text-property>
</text>
</cell>
<cell id="221">
<auto-text name="totalPageNoTxt" id="211">
<property name="type">total-page</property>
</auto-text>
</cell>
</row>
</grid>
</cell>
</row>
</grid>
</page-footer>
<simple-master-page name="PASHeaderFooterLandscape" id="157">
<property name="orientation">landscape</property>
<page-header>
<grid name="headerMainGrid_2" id="158">
<column id="159">
</column>
<column id="160"/>
<row id="161">
<cell id="162">
<text name="projectName_2" id="163">
</text>
</cell>
<cell id="164">
<image name="pilzLogo_2" id="165">
</structure>
</image>
</cell>
</row>
</grid>
</page-header>
<page-footer>
<grid name="footerMainGrid_2" id="166">
<column id="167">
<property name="width">9.90625in</property>
</column>
<column id="168">
</column>
<row id="169">
<cell id="170">
<property name="paddingRight">1pt</property>
<text name="todatyDate_2" id="171">
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</cell>
<cell id="172">
<grid name="pageNumberGrid_2" id="173">
<column id="174">
<property name="width">0.5416666667in</property>
</column>
<column id="175">
<property name="width">0.2083333333in</property>
</column>
<column id="176"/>
<row id="177">
<cell id="178">
<auto-text name="pageNumberTxt_2" id="179">
</auto-text>
</cell>
<cell id="180">
<text name="pageNumberSepTxt_2" id="181">
</text>
</cell>
<cell id="182">
<auto-text name="totalPageNoTxt_2" id="183">
</auto-text>
</cell>
</row>
</grid>
</cell>
</row>
</grid>
</page-footer>
</page-setup>
</library>
--------------070106050504090102080305--
Re: page number formatting in footer [message #366657 is a reply to message #366650] |
Mon, 19 January 2009 23:50 |
Parvez,
Does changing the footer margin make a difference?
Jason
PC wrote:
> Hi Jason,
> Thanks.
> - Parvez
>> Thanks
>> Jason
>> PC wrote:
>>> Hi Jason,
>>> - Parvez
>>>> Jason
>>>>> Thanks.
>>>>>> Jason?
>>>>>> PC schrieb:
>>>>>>> Hi,
>>>>>>> Page 1 / 3
>>>>>>> Page 2 / 3
>>>>>>> Thanks.
>>>>>>> - Parvez
Re: page number formatting in footer [message #366670 is a reply to message #366657] |
Tue, 20 January 2009 11:46 |
Hi Jason,
I just tried changing footer height and bottom margin.
But didn't make any difference.
- Parvez
> Parvez,
> Jason
> PC wrote:
>> Hi Jason,
>> Thanks.
>> - Parvez
>>> just post the xml to the reply?
>>> Thanks
>>> Jason
>>> PC wrote:
>>>> Hi Jason,
>>>> I just renamed it to xml.
>>>> - Parvez
>>>>> Jason
>>>>>> Thanks.
>>>>>>> Jason?
>>>>>>> PC schrieb:
>>>>>>>> Hi,
>>>>>>>> page - footer) page number.
>>>>>>>> Page 1 / 3
>>>>>>>> Page 2 / 3
>>>>>>>> Thanks.
>>>>>>>> - Parvez
Re: page number formatting in footer [message #366671 is a reply to message #366670] |
Tue, 20 January 2009 15:18 |
Parvez,
I am having a hard time reproducing this error. I took your footer and
added it to one of my reports. I had to delete the one event field, but
the pagination worked fine in html and pdf.
Jason
PC wrote:
> Hi Jason,
> - Parvez
>> Parvez,
>> Jason
>> PC wrote:
>>> Hi Jason,
>>> Thanks.
>>> - Parvez
>>>> Thanks
>>>> Jason
>>>> PC wrote:
>>>>> Hi Jason,
>>>>> - Parvez
>>>>>> Jason
>>>>>>> Thanks.
>>>>>>>> Jason?
>>>>>>>> PC schrieb:
>>>>>>>>> Hi,
>>>>>>>>> Page 1 / 3
>>>>>>>>> Page 2 / 3
>>>>>>>>> Thanks.
>>>>>>>>> - Parvez
Re: page number formatting in footer [message #366673 is a reply to message #366671] |
Tue, 20 January 2009 16:40 |
Thats fine Jason.
I think I can leave it, it is not that critical to have page word in
footer (at least for now :-))
Thanks for your time.
- Parvez
> Parvez,
> Jason
> PC wrote:
>> Hi Jason,
>> - Parvez
>>> Parvez,
>>> Jason
>>> PC wrote:
>>>> Hi Jason,
>>>> Thanks.
>>>> - Parvez
>>>>> Thanks
>>>>> Jason
>>>>> PC wrote:
>>>>>> Hi Jason,
>>>>>> uses number of java handlers which in turn uses number of other
>>>>>> plugins. I just renamed it to xml.
>>>>>> - Parvez
>>>>>>> Jason
>>>>>>>> Thanks.
>>>>>>>>> Jason?
>>>>>>>>> PC schrieb:
>>>>>>>>>> Hi,
>>>>>>>>>> Page 1 / 3
>>>>>>>>>> Page 2 / 3
>>>>>>>>>> Thanks.
>>>>>>>>>> - Parvez
Current Time: Thu Apr 25 12:08:52 GMT 2024
Powered by FUDForum. Page generated in 0.04598 seconds
