Re: Data Type 'any' not Found in BIRT 2.3.1 [message #366590 is a reply to message #366587] |
Tue, 13 January 2009 18:01 |
Said,
I am not certain why the data type was removed, but have you tried your
reports in 2.3.1?
Jason
Said Taaouati wrote:
> This data type is still exist in BIRT API
> setDataType(DesignChoiceConstants.COLUMN_DATA_TYPE_STRING).
> This means that all mine reports created in BIRT 2.2.2 does not work
> under BIRT 2.3.1 .
> Is this type no more used or is it a bug?
Re: Data Type 'any' not Found in BIRT 2.3.1 [message #366605 is a reply to message #366595] |
Wed, 14 January 2009 15:47 |
Originally posted by: thilo.bruesshaber.gmail.com
I noticed the same behaviour.
I used a search and replace tool to change all occurencies of >any< to
>string<
String should actually suit in all cases otherwise you would have
choosen a more specialiced data type before.
Said Taaouati schrieb:
> If I open my report with report editor in 2.3.1 I get the following error:
> org.eclipse.birt.report.model.metadata.ChoicePropertyType validateXml
> SEVERE: Not allowed choice any
FUDForum. Page generated in 0.04061 seconds
