Home » Eclipse Projects » BIRT » HTML Table rendering in PDF, DOC
HTML Table rendering in PDF, DOC [message #366184] Fri, 05 December 2008 10:23 Go to next message
François is currently offline FrançoisFriend
I'm using Birt 2.3.1 but have noticed the same behaviour with 2.2.2.
When i do the following :
- create a new report design ;
- insert a "Text" item ;
- change its value to "<VALUE-OF format="HTML"><table
border="1"><tr><td>column 1</td><td>column 2</td></tr></table></VALUE-OF>"
The HTML output render is correct (the frame of the table is displayed).
However, no line is displayed with PDF and DOC formats (i haven't tested
with others).
I have tried using CSS properties but the result is the same :
<table style="border:1px solid #000000;"><tr><td>column 1</td><td>column
2</td></tr></table>
It seems to be a more general problem as the width is not rendered either.
The following displays two 50% width columns :
<table width="100%"><tr><td width="20%">column 1</td><td
width="80%">column 2</td></tr></table>
Is this a bug? Is this not implemented yet? Am i forgetting something?
François
Re: HTML Table rendering in PDF, DOC [message #366188 is a reply to message #366184] Fri, 05 December 2008 16:25 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
François,
I believe this is a known issue with Text elements. Can you not use a
grid and the style mechanisms built into BIRT to do the same thing?
Jason
> 2</td></tr></table></VALUE-OF>" ;
> with others).
> 2</td></tr></table>
> either. The following displays two 50% width columns :
> François
Re: HTML Table rendering in PDF, DOC [message #366191 is a reply to message #366188] Fri, 05 December 2008 17:09 Go to previous messageGo to next message
Thanks for your answer.
Unfortunately i cannot do that as i use Birt to render user generated HTML.
Is there any workaround for this issue?
Jason Weathersby wrote:
> François,
> Jason
>> with others).
>> 2</td></tr></table>
>> François
Re: HTML Table rendering in PDF, DOC [message #366193 is a reply to message #366191] Fri, 05 December 2008 20:30 Go to previous messageGo to next message
I logged a bug for this before:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256746
I do not know of a work around.
Jason
>> François,
>> Jason
>>> tested with others).
>>> François
Re: HTML Table rendering in PDF, DOC [message #366195 is a reply to message #366193] Fri, 05 December 2008 20:54 Go to previous messageGo to next message
BTW some html will be passed through. As an example look at the sample
db. If you enter a select statement like:
select CLASSICMODELS.PRODUCTLINES.HTMLDESCRIPTION
from CLASSICMODELS.PRODUCTLINES
Add a table and bind it to that dataset and then put a dynamic text
element in that binds to HTMLDESCRIPTION you will see that html works in
html and pdf.
Or open a blank report and drop a dynamic text element in it with the
following expression:
var htmlvar = "";
htmlvar = htmlvar + "<ul>";
htmlvar = htmlvar + "<li><font face='Times New Roman'>No Toxic
Materials</font></li>"
htmlvar = htmlvar + "<li><font face='Times New Roman'>Monogram Service
Available</font></li>"
htmlvar = htmlvar + "<li><font face='Times New Roman'>Batteries Not
Required</font></li>"
htmlvar = htmlvar + "<li><font color='#FF0000' face='Times New
Roman'><i><b>90 Day Money Back Guarantee</b></i></font></li>"
htmlvar = htmlvar + "</ul>";
I believe the issue is with tables.
Jason
> Jason
>> HTML.
>>> François,
>>> a grid and the style mechanisms built into BIRT to do the same thing?
>>> Jason
>>>> displayed).
>>>> François
Re: HTML Table rendering in PDF, DOC [message #1774767 is a reply to message #366195] Thu, 19 October 2017 13:43 Go to previous message
Moshe Jacobs is currently offline Moshe JacobsFriend
Does anyone know if this issue was resolved and if so in which version? Thanks.
Previous Topic:Eclipse birt prints another character instead of superscript three
Next Topic:Birt Viewer Exception
Current Time: Sat Jul 24 22:13:44 GMT 2021
Powered by FUDForum. Page generated in 0.02564 seconds
