Re: Overlaying (stamping) an image with label, text or data [message #365830 is a reply to message #365828] |
Wed, 05 November 2008 21:29 |
Originally posted by: jasonweathersby.alltel.net
Joachim,
Try adding a grid that is 1x1 and set its height and width. Create a
style with a background image and apply the style to the grid.
Then drop text, label, or data items in grid.
Jason
Joachim Wesenberg wrote:
> Question from a newbie: How do I manage to overlay an image with labels,
> text or data?
> Thanks for taking the time to answer - Jo
Re: Overlaying (stamping) an image with label, text or data [message #365840 is a reply to message #365830] |
Thu, 06 November 2008 14:33 |
Originally posted by: Joachim.Wesenberg.de
Jason Weathersby wrote:
> Joachim,
> Jason
>> labels, text or data?
Jason,
thanks a lot. That worked fine, but how do I accomplish an exact
positioning of text, label, etc. BIRT let me specify top, bottom,
center. Is there any way to drag it to a desired position within the grid?
Best regards - Jo
Re: Overlaying (stamping) an image with label, text or data [message #365845 is a reply to message #365840] |
Thu, 06 November 2008 16:09 |
Joachim,
You can use the margins and the height/width property in the advanced
properties for the label/text element. Make sure to set the report
layout to fixed in the general properties for the report.
Take a look at this example. Edit the background image style to replace
with your image.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.3.1.v20080911 Build <2.3.1.v20080922-1151></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">fixed layout</property>
<property name="bidiLayoutOrientation">ltr</property>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
<style name="backgroundimage" id="10">
<property name="backgroundImage">C:\Documents and
Settings\jweathersby\My Documents\My Pictures\Chartengine.bmp</property>
</style>
<style name="mylabelstyle" id="15">
<property name="backgroundColor">#004080</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
<property name="display">inline</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="6">
<property name="style">backgroundimage</property>
<property name="height">3.625in</property>
<property name="width">7in</property>
<column id="7"/>
<row id="8">
<cell id="9">
<label id="13">
<property name="style">mylabelstyle</property>
<property name="fontSize">medium</property>
<property name="marginTop">1.2in</property>
<property name="marginLeft">1in</property>
<property name="whiteSpace">normal</property>
<property name="width">2in</property>
<text-property name="text">My Label</text-property>
</label>
<label id="14">
<property name="marginTop">3in</property>
<text-property name="text">My Second
</label>
</cell>
</row>
</grid>
</body>
</report>
>> Joachim,
>> Jason
> Jason,
> Best regards - Jo
FUDForum. Page generated in 0.03367 seconds
