Re: Birt 2.3.1 - Message "The report contains errors, would you like to continue for previewing [message #365376 is a reply to message #365375] |
Tue, 30 September 2008 18:46 |
Originally posted by: moi.toto.com
moi a écrit :
> Using a runnable report made with Birt 2.3.0, I've got the error message
> "The report contains errors, would you like to continue for previewing?"
> on 2.3.1. Do you know if it is possible to detect the place where this
> error occurs in report ?
> Moi.
Here is the rptdesign which generate the error :
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.3.1.v20080911 Build <2.3.1.v20080922-1151></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.gjt.mm.mysql.Driver</property>
<property
name="odaURL">jdbc:mysql://localhost:3307/datab</property>
<property name="odaUser">root</property>
<encrypted-property name="odaPassword"
encryptionID="base64">cGFzc3dvcmQ=</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="DS1" id="7">
<list-property name="computedColumns">
<structure>
<property name="name">date_mise_en_service</property>
<expression name="expression">if
(row["MISEENSERVICE"] != null) {
new java.lang.Double(row["MISEENSERVICE"])
}</expression>
<property name="dataType">decimal</property>
</structure>
<structure>
<property name="name">netcost_decimal</property>
(row["NETCOSTOFTHEINVESTMENT"] != null) {
new java.lang.Double(row["NETCOSTOFTHEINVESTMENT"])
}</expression>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">WORKFLOW_ID</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">WORKFLOW_FATHER_ID</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">WORKFLOW_SUBJECT</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">4</property>
<property
name="name">WORKFLOW_CREATION_TIME</property>
</structure>
<structure>
<property name="position">5</property>
<property
name="name">WORKFLOW_UPDATE_TIME</property>
</structure>
<structure>
<property name="position">6</property>
<property
name="name">WORKFLOW_LAST_ACCESS_TIME</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">DOCUMENT_TYPE_ID</property>
</structure>
<structure>
<property name="position">8</property>
<property
name="name">DOCUMENT_TYPE_DESIGNER_NAME</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">DOCUMENT_TYPE_NAME</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">PROCESS_TYPE_ID</property>
</structure>
<structure>
<property name="position">11</property>
<property
name="name">PROCESS_TYPE_DESIGNER_NAME</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">PROCESS_TYPE_NAME</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">STATE_ID</property>
</structure>
<structure>
<property name="position">14</property>
<property
name="name">STATE_DESIGNER_NAME</property>
</structure>
<structure>
<property name="position">15</property>
<property name="name">STATE_NAME</property>
</structure>
<structure>
<property name="position">16</property>
<property name="name">TYPE</property>
</structure>
<structure>
<property name="position">17</property>
<property name="name">CLASSIFICATION</property>
</structure>
<structure>
<property name="position">18</property>
<property name="name">BUDGET</property>
</structure>
<structure>
<property name="position">19</property>
<property name="name">SIBUBGETMONTANT</property>
</structure>
<structure>
<property name="position">20</property>
<property name="name">CODEBUDGET</property>
</structure>
<structure>
<property name="position">21</property>
<property name="name">SIREMPLACEMENT</property>
</structure>
<structure>
<property name="position">22</property>
<property name="name">METIER</property>
</structure>
<structure>
<property name="position">23</property>
<property name="name">PAYS</property>
</structure>
<structure>
<property name="position">24</property>
<property name="name">ZONE</property>
</structure>
<structure>
<property name="position">25</property>
<property name="name">SOCIETE</property>
</structure>
<structure>
<property name="position">26</property>
<property name="name">BIDON</property>
</structure>
<structure>
<property name="position">27</property>
<property name="name">BIDON_2</property>
</structure>
<structure>
<property name="position">28</property>
<property name="name">MISEENSERVICE</property>
</structure>
<structure>
<property name="position">29</property>
<property name="name">NEWEQUIPEMENT</property>
</structure>
<structure>
<property name="position">30</property>
<property
name="name">SIAUTREJUSTIFICATION</property>
</structure>
<structure>
<property name="position">31</property>
<property name="name">JUSTIFICATION</property>
</structure>
<structure>
<property name="position">32</property>
<property
name="name">DESCRIPTIONOFTHEINVESTMENT</property>
</structure>
<structure>
<property name="position">33</property>
<property name="name">NOMDUPROJET</property>
</structure>
<structure>
<property name="position">34</property>
<property name="name">CODE_PROJET</property>
</structure>
<structure>
<property name="position">35</property>
<property name="name">TOTALCOST</property>
</structure>
<structure>
<property name="position">36</property>
<property name="name">TOTALCOST_LOCAL</property>
</structure>
<structure>
<property name="position">37</property>
<property
name="name">NONREFUNDABLESUBSIDIES</property>
</structure>
<structure>
<property name="position">38</property>
<property
name="name">NONREFUNDABLESUBSIDIES_LOCAL</property>
</structure>
<structure>
<property name="position">39</property>
<property
name="name">NETCOSTOFTHEINVESTMENT</property>
</structure>
<structure>
<property name="position">40</property>
<property
name="name">NETCOSTOFTHEINVESTMENT_LOCAL</property>
</structure>
<structure>
<property name="position">41</property>
<property name="name">TEST</property>
</structure>
<structure>
<property name="position">42</property>
<property name="name">CODEMONAIE</property>
</structure>
<structure>
<property name="position">43</property>
<property name="name">TOTALCOST_HIST</property>
</structure>
<structure>
<property name="position">44</property>
<property
name="name">TOTALCOST_LOCAL_HIST</property>
</structure>
<structure>
<property name="position">45</property>
<property name="name">PAYBACK_HISTORY</property>
</structure>
<structure>
<property name="position">46</property>
<property name="name">PAYBACK</property>
</structure>
<structure>
<property name="position">47</property>
<property name="name">MTLTLOAN</property>
</structure>
<structure>
<property name="position">48</property>
<property name="name">MTLTLOAN_2</property>
</structure>
<structure>
<property name="position">49</property>
<property name="name">LEASING</property>
</structure>
<structure>
<property name="position">50</property>
<property name="name">LEASING_2</property>
</structure>
<structure>
<property name="position">51</property>
<property
name="name">REFUNDABLESUBSIDIES</property>
</structure>
<structure>
<property name="position">52</property>
<property
name="name">REFUNDABLESUBSIDIES_2</property>
</structure>
<structure>
<property name="position">53</property>
<property name="name">OVERDRAFTCASH</property>
</structure>
<structure>
<property name="position">54</property>
<property name="name">OVERDRAFTCASH_2</property>
</structure>
<structure>
<property name="position">55</property>
<property
name="name">PIECEJOINTEPRESENTATION</property>
</structure>
<structure>
<property name="position">56</property>
<property name="name">PIECEJOINTE</property>
</structure>
<structure>
<property name="position">57</property>
<property
name="name">PIECEJOINTEFINANCIER</property>
</structure>
<structure>
<property name="position">58</property>
<property name="name">COMMENTAIRES_2</property>
</structure>
<structure>
<property name="position">59</property>
<property name="name">COMMENTAIRES</property>
</structure>
<structure>
<property name="position">60</property>
<property name="name">NUMEROUNIQUE</property>
</structure>
<structure>
<property name="position">61</property>
<property name="name">ASSET_EXPENSES</property>
</structure>
<structure>
<property name="position">62</property>
<property name="name">COMMENTAIRE3</property>
</structure>
<structure>
<property name="position">63</property>
<property name="name">COMMENTAIRE2</property>
</structure>
<structure>
<property name="position">64</property>
<property name="name">COMMENTAIRE1</property>
</structure>
<structure>
<property name="position">65</property>
<property name="name">EMAIL</property>
</structure>
<structure>
<property name="position">66</property>
<property name="name">PARAMETRE</property>
</structure>
<structure>
<property name="position">67</property>
<property name="name">USERNAME</property>
</structure>
<structure>
<property name="position">68</property>
<property name="name">UID</property>
</structure>
<structure>
<property name="position">69</property>
<property name="name">CODE_SOCIETE</property>
</structure>
<structure>
<property name="position">70</property>
<property name="name">IDSAL</property>
</structure>
<structure>
<property name="position">71</property>
<property name="name">PRENOM_LDAP</property>
</structure>
<structure>
<property name="position">72</property>
<property name="name">NOM_LDAP</property>
</structure>
<structure>
<property name="position">73</property>
<property name="name">RTT</property>
</structure>
<structure>
<property name="position">74</property>
<property name="name">CPSUP</property>
</structure>
<structure>
<property name="position">75</property>
<property name="name">TEXTE_COMPTEURS</property>
</structure>
<structure>
<property name="position">76</property>
<property name="name">DATE_COMPTEURS</property>
</structure>
<structure>
<property name="position">77</property>
<property name="name">MAT</property>
</structure>
<structure>
<property name="position">78</property>
<property name="name">PRENOM_DEMANDEUR</property>
</structure>
<structure>
<property name="position">79</property>
<property name="name">NOM_DEMANDEUR</property>
</structure>
<structure>
<property name="position">80</property>
<property name="name">ETAB</property>
</structure>
<structure>
<property name="position">81</property>
<property name="name">DEPT</property>
</structure>
<structure>
<property name="position">82</property>
<property name="name">SERV</property>
</structure>
<structure>
<property name="position">83</property>
<property name="name">PRENOM_RESPONSABLE</property>
</structure>
<structure>
<property name="position">84</property>
<property name="name">NOM_RESP</property>
</structure>
<structure>
<property name="position">85</property>
<property name="name">CP</property>
</structure>
<structure>
<property name="position">86</property>
<property name="name">RECHERCHE_RESP1</property>
</structure>
<structure>
<property name="position">87</property>
<property name="name">PARAM_RESP1</property>
</structure>
<structure>
<property name="position">88</property>
<property name="name">CONTRAINTE_1</property>
</structure>
<structure>
<property name="position">89</property>
<property name="name">RECHERCHE_RESP2</property>
</structure>
<structure>
<property name="position">90</property>
<property name="name">PARAM_RESP2</property>
</structure>
<structure>
<property name="position">91</property>
<property name="name">CONTRAINTE_2</property>
</structure>
<structure>
<property name="position">92</property>
<property
name="name">PRENOM_RESPONSABLE_2</property>
</structure>
<structure>
<property name="position">93</property>
<property name="name">NOM_RESP_2</property>
</structure>
<structure>
<property name="position">94</property>
<property name="name">NIVEAU1</property>
</structure>
<structure>
<property name="position">95</property>
<property name="name">DUREE_F</property>
</structure>
<structure>
<property name="position">96</property>
<property name="name">DUREE</property>
</structure>
<structure>
<property name="position">97</property>
<property name="name">JOUR1</property>
</structure>
<structure>
<property name="position">98</property>
<property name="name">NB_JRS_ABS</property>
</structure>
<structure>
<property name="position">99</property>
<property name="name">TEXTE_DATE</property>
</structure>
<structure>
<property name="position">100</property>
<property
name="name">DERNIER_JR_TRAVAILLE</property>
</structure>
<structure>
<property name="position">101</property>
<property name="name">JR_REPRISE</property>
</structure>
<structure>
<property name="position">102</property>
<property name="name">POUR_INFORMATION</property>
</structure>
<structure>
<property name="position">103</property>
<property name="name">DATE_DEMANDE</property>
</structure>
<structure>
<property name="position">104</property>
<property
name="name">COMMENTAIRE_DEMANDEUR</property>
</structure>
<structure>
<property name="position">105</property>
<property name="name">DATE_DEB_AAAAMMJJ</property>
</structure>
<structure>
<property name="position">106</property>
<property name="name">DATE_FIN_AAAAMMJJ</property>
</structure>
<structure>
<property name="position">107</property>
<property name="name">DATE_DEB_ABSENCE</property>
</structure>
<structure>
<property name="position">108</property>
<property name="name">AMPM_DEBUT</property>
</structure>
<structure>
<property name="position">109</property>
<property name="name">DATE_FIN_ABSENCE</property>
</structure>
<structure>
<property name="position">110</property>
<property name="name">AMPM_FIN</property>
</structure>
<structure>
<property name="position">111</property>
<property name="name">MOTIF_IRIS</property>
</structure>
<structure>
<property name="position">112</property>
<property name="name">MOTIF</property>
</structure>
<structure>
<property name="position">113</property>
<property name="name">AMPM_DEB_IRIS</property>
</structure>
<structure>
<property name="position">114</property>
<property name="name">AMPM_FIN_IRIS</property>
</structure>
<structure>
<property name="position">115</property>
<property name="name">DEB_AAAAMMJJ</property>
</structure>
<structure>
<property name="position">116</property>
<property name="name">FIN_AAAAMMJJ</property>
</structure>
<structure>
<property name="position">117</property>
<property name="name">COMM_PAIE</property>
</structure>
<structure>
<property name="position">118</property>
<property name="name">NOMDELACTEUR</property>
</structure>
<structure>
<property name="position">119</property>
<property name="name">CHAMPZONE</property>
</structure>
<structure>
<property name="position">120</property>
<property
</structure>
<structure>
<property name="position">121</property>
</structure>
</list-property>
</structure>
<property name="rowFetchLimit">0</property>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">WORKFLOW_ID</property>
</structure>
<structure>
<property
name="nativeName">WORKFLOW_FATHER_ID</property>
</structure>
<structure>
<property name="nativeName">WORKFLOW_SUBJECT</property>
</structure>
<structure>
<property name="name">WORKFLOW_CREATION_TIME</property>
<property
name="nativeName">WORKFLOW_CREATION_TIME</property>
</structure>
<structure>
<property name="name">WORKFLOW_UPDATE_TIME</property>
<property
name="nativeName">WORKFLOW_UPDATE_TIME</property>
</structure>
<structure>
<property
<property
name="nativeName">WORKFLOW_LAST_ACCESS_TIME</property>
</structure>
<structure>
<property name="nativeName">DOCUMENT_TYPE_ID</property>
</structure>
<structure>
<property
<property
name="nativeName">DOCUMENT_TYPE_DESIGNER_NAME</property>
</structure>
<structure>
<property
name="nativeName">DOCUMENT_TYPE_NAME</property>
</structure>
<structure>
<property name="nativeName">PROCESS_TYPE_ID</property>
</structure>
<structure>
<property
<property
name="nativeName">PROCESS_TYPE_DESIGNER_NAME</property>
</structure>
<structure>
<property
name="nativeName">PROCESS_TYPE_NAME</property>
</structure>
<structure>
<property name="nativeName">STATE_ID</property>
</structure>
<structure>
<property name="name">STATE_DESIGNER_NAME</property>
<property
name="nativeName">STATE_DESIGNER_NAME</property>
</structure>
<structure>
<property name="nativeName">STATE_NAME</property>
</structure>
<structure>
<property name="nativeName">TYPE</property>
</structure>
<structure>
<property name="nativeName">CLASSIFICATION</property>
</structure>
<structure>
<property name="nativeName">BUDGET</property>
</structure>
<structure>
<property name="nativeName">SIBUBGETMONTANT</property>
</structure>
<structure>
<property name="nativeName">CODEBUDGET</property>
</structure>
<structure>
<property name="nativeName">SIREMPLACEMENT</property>
</structure>
<structure>
<property name="nativeName">METIER</property>
</structure>
<structure>
<property name="nativeName">PAYS</property>
</structure>
<structure>
<property name="nativeName">ZONE</property>
</structure>
<structure>
<property name="nativeName">SOCIETE</property>
</structure>
<structure>
<property name="nativeName">BIDON</property>
</structure>
<structure>
<property name="nativeName">BIDON_2</property>
</structure>
<structure>
<property name="nativeName">MISEENSERVICE</property>
</structure>
<structure>
<property name="nativeName">NEWEQUIPEMENT</property>
</structure>
<structure>
<property name="name">SIAUTREJUSTIFICATION</property>
<property
name="nativeName">SIAUTREJUSTIFICATION</property>
</structure>
<structure>
<property name="nativeName">JUSTIFICATION</property>
</structure>
<structure>
<property
FUDForum. Page generated in 0.02549 seconds
