Home » Archived » BIRT » switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365372 is a reply to message #365365] |
Tue, 30 September 2008 17:22 |
Originally posted by: jasonweathersby.alltel.net
Claus,
Can you set the log level to FINE and then post the log file for the
runtime?
Jason
exquisitus wrote:
> today i updated my birt environment from 2.3.0 to 2.3.1 using eclipse
> update function on WinXP (Client). Execution of the "test.rptdesign" works.
> Then i downloaded the 2.3.1 runtime to deploy it on the jboss webserver
> (version 4.2.3.GA) running on RHEL 5.2 64-bit. (Deployment as described
> for jboss on the BIRT website
> http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php ). (With
> version 2.3.0 the "test.rptdesign" (and other reports) are running
> without that problem).
> Using the link http://192.168.1.1:8081/birt/run?__report=test.rptdesign
> within Internet Explorer 7, the content of the report is returned as
> expected. But the "Processing, please wait..." window is not closed
> (still keeps working).
> The same thing happens with other reports.
> Using the link
> http://192.168.1.1:8081/birt/frameset?__report=test.rptdesig n results in
> the following HTTP Status 500:
> exception
> org.apache.jasper.JasperException: javax.servlet.ServletException:
> java.lang.NoSuchMethodError:
> org.eclipse.birt.report.utility.ParameterAccessor.getEncoded QueryString(Ljavax/servlet/http/HttpServletRequest;Ljava/lan g/String;Ljava/lang/String;)Ljava/lang/String;
> org.apache.jasper.servlet.JspServletWrapper.handleJspExcepti on(JspServletWrapper.java:521)
> org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:397)
> org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:336)
> org.apache.jasper.servlet.JspServlet.service(JspServlet.java :265)
> javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
> org.eclipse.birt.report.presentation.aggregation.AbstractBas eFragment.service(AbstractBaseFragment.java:82)
> org.eclipse.birt.report.presentation.aggregation.AbstractBas eFragment.callBack(AbstractBaseFragment.java:106)
> org.apache.jsp.webcontent.birt.pages.layout.FramesetFragment _jsp._jspService(FramesetFragment_jsp.java:263)
> org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:70)
> org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:373)
> org.eclipse.birt.report.presentation.aggregation.layout.Fram esetFragment.service(FramesetFragment.java:98)
> org.eclipse.birt.report.servlet.ViewerServlet.__doGet(Viewer Servlet.java:181)
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(BirtSoapMessageDispatcherServlet.java:146)
> javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
> org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:112)
> org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF ilter.java:68)
> org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:96)
> root cause
> javax.servlet.ServletException: java.lang.NoSuchMethodError:
> org.apache.jasper.runtime.PageContextImpl.doHandlePageExcept ion(PageContextImpl.java:850)
> org.apache.jasper.runtime.PageContextImpl.handlePageExceptio n(PageContextImpl.java:779)
> org.apache.jsp.webcontent.birt.pages.control.ToolbarFragment _jsp._jspService(ToolbarFragment_jsp.java:220)
> root cause
> org.apache.jsp.webcontent.birt.pages.control.ToolbarFragment _jsp._jspService(ToolbarFragment_jsp.java:82)
> Any ideas how to solve the problem?
> Thanks in advance
> claus
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365384 is a reply to message #365372] |
Wed, 01 October 2008 07:07 |
claus Messages: 6 Registered: July 2009 |
Good morning,
following the BIRT logfile from ../birt.war/logs after accessing the
following link:
There is one thing i forgot in the first post. I'm using jdk1.6.0_07 on
the linux server.
claus
Startlog ===>
01.10.2008 08:53:44 org.eclipse.birt.report.engine.api.impl.ReportEngine
<init>
FEIN: ReportEngine created. EngineConfig: EngineConfig:
org.eclipse.birt.report.engine.api.EngineConfig.scriptObject s={PARENT_CLASSLOADER=WebappClassLoader
delegate: false
repositories:
----------> Parent Classloader:
java.net.FactoryURLClassLoader@741378ec
webapplication.projectclasspath=};maxRowsPerQuery=-1;BIRT_HO ME=;logLevel=FINE;PLATFORM_CONTEXT=org.eclipse.birt.core.framework.PlatformServletContext@7f0b8d03 ;org.eclipse.birt.report.engine.api.EngineConfig.emitterConf igs={html=org.eclipse.birt.report.engine.api.HTMLRenderOption@4f57011e };logDest=/opt/jboss/jboss-4.2.3.GA/server/default/./deploy/ birt.war/logs;
01.10.2008 08:53:44
org.eclipse.birt.report.engine.extension.internal.ExtensionM anager
getExtensions
FEIN: Start load extension point:
org.eclipse.birt.report.engine.reportitemGeneration
01.10.2008 08:53:44
loadGenerationExtensionDefns
FEIN: Load generation extension: Chart
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.reportitemPresentation
01.10.2008 08:53:44
loadPresentationExtensionDefns
FEIN: Load prsentation extension: Chart
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.reportitemQuery
01.10.2008 08:53:44
loadQueryExtensionDefns
FEIN: Load query extension: Chart
01.10.2008 08:53:44
getExtensions
FEIN: Start load extension point: org.eclipse.birt.report.engine.emitters
01.10.2008 08:53:44
loadEmitterExtensionDefns
FEIN: Load postscript emitter
org.eclipse.birt.report.engine.emitter.postscript
01.10.2008 08:53:44
FEIN: Load ppt emitter org.eclipse.birt.report.engine.emitter.ppt
01.10.2008 08:53:44
FEIN: Load html emitter org.eclipse.birt.report.engine.emitter.html
01.10.2008 08:53:44
FEIN: Load doc emitter org.eclipse.birt.report.engine.emitter.word
01.10.2008 08:53:44
FEIN: Load pdf emitter org.eclipse.birt.report.engine.emitter.pdf
01.10.2008 08:53:44
FEIN: Load xls emitter
org.eclipse.birt.report.engine.emitter.prototype.excel
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.reportEventHandler
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.reportItemPreparation
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.dataExtraction
01.10.2008 08:53:44
loadDataExtractionExtensions
FEIN: Load data extraction extension:
org.eclipse.birt.report.engine.dataextraction.csv
01.10.2008 08:53:44
getExtensions
org.eclipse.birt.report.engine.extendedItemFactory
01.10.2008 08:53:44
loadExtendedItems
FEIN: Load extendedItem extension: Crosstab
01.10.2008 08:53:44
loadExtendedItems
FEIN: Load extendedItem extension: CrosstabCell
01.10.2008 08:53:44
loadExtendedItems
FEIN: Load extendedItem extension: AggregationCell
01.10.2008 08:54:41 org.eclipse.birt.report.engine.api.impl.ReportEngine
openReportDocument
FEIN: ReportEngine.openReportDocument:
systemId=/opt/jboss/jboss-4.2.3.GA/server/default/./deploy/b irt.war/test.rptdesign,
file=/opt/jboss/jboss-4.2.3.GA/server/default/./deploy/birt. war/documents/BIRTDOCEF0F62E9CAF8C65A5C23A71D6F5341AF/9d4fb9 49/test.rptdocument,
options={resourceFolder=/opt/jboss/jboss-4.2.3.GA/server/def ault/./deploy/birt.war,
semanticCheck=false}
openReportDesign
FEIN: ReportEngine.openReportDesign:
name=file:/opt/jboss/jboss-4.2.3.GA/server/default/./deploy/ birt.war/test.rptdesign,
designStream=java.io.FileInputStream@7d94a8eb, options={3}
01.10.2008 08:54:41
org.eclipse.birt.report.model.metadata.ChoicePropertyType validateXml
FEIN: return internal name for choice eq
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice asc
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice DataSet
01.10.2008 08:54:41
FEIN: return internal name for choice hide
01.10.2008 08:54:41
FEIN: return internal name for choice string
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice any
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice if-realized
01.10.2008 08:54:41
FEIN: return internal name for choice auto
01.10.2008 08:54:41
FEIN: return internal name for choice hyperlink
01.10.2008 08:54:41
FEIN: return internal name for choice inner
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice auto layout
01.10.2008 08:54:41
FEIN: return internal name for choice ltr
01.10.2008 08:54:41
FEIN: return internal name for choice NoChange
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice static
01.10.2008 08:54:41
FEIN: return internal name for choice simple
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice single
01.10.2008 08:54:41
FEIN: return internal name for choice normal
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice none
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice scroll
01.10.2008 08:54:41
org.eclipse.birt.report.model.metadata.DimensionPropertyType validateXml
FEIN: return dimension value with default unit 0.0
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice repeat
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice block
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with default unit 1.0
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with default unit 1.25
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with default unit 0.5
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice size-to-image
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice horizontal
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice sum
01.10.2008 08:54:41
FEIN: return internal name for choice decimal
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 0%
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 0em
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 0pt
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 1pt
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 1in
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 1.25in
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 0.5in
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return dimension value with user defined unit 0.5pt
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice over then down
01.10.2008 08:54:41
validateInputString
FEIN: Return internal name of the choice solid
01.10.2008 08:54:41
validateInputString
FEIN: return dimension with user-defined unit 1pt
01.10.2008 08:54:41
org.eclipse.birt.report.model.metadata.ColorPropertyType validateValue
FEIN: the validated color value 13421772
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
validateInputString
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
FEIN: return internal name for choice after
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:41
01.10.2008 08:54:42
01.10.2008 08:54:42
FEIN: return internal name for choice text-box
01.10.2008 08:54:42
FEIN: return dimension value with user defined unit 100%
01.10.2008 08:54:42
FEIN: return internal name for choice bold
01.10.2008 08:54:42
FEIN: return internal name for choice center
01.10.2008 08:54:42
01.10.2008 08:54:42
FEIN: return internal name for choice html
01.10.2008 08:54:42
FEIN: return internal name for choice right
01.10.2008 08:54:42
FEIN: return internal name for choice page-number
01.10.2008 08:54:42
01.10.2008 08:54:42
01.10.2008 08:54:42
FEIN: return dimension value with user defined unit 1.354in
01.10.2008 08:54:42
FEIN: return dimension value with user defined unit 5.083in
01.10.2008 08:54:42 org.eclipse.birt.report.engine.api.impl.ReportEngine
createGetParameterDefinitionTask
FEIN: ReportEngine.createGetParameterDefinitionTask:
reportRunnable=org.eclipse.birt.report.engine.api.impl.ReportRunnable@1ac8210
01.10.2008 08:54:42 org.eclipse.birt.report.engine.api.impl.EngineTask
setAppContext
FEIN: EngineTask.setAppContext: context=PARENT_CLASSLOADER=WebappClassLoader
delegate: false
repositories:
;webapplication.projectclasspath=;
setLocale
FEIN: EngineTask.setLocale: locale=Deutsch
setAppContext
delegate: false
repositories:
;CHART_RESOLUTION=null;org.eclipse.birt.data.engine.dataset. cache.option=false;org.eclipse.birt.data.engine.cube.inmemor y.size=0;webapplication.projectclasspath=;BIRT_VIEWER_HTTPSE RVET_REQUEST=org.apache.catalina.connector.RequestFacade@1051f982 ;birt.viewer.resource.path=/opt/jboss/jboss-4.2.3.GA/server/ default/./deploy/birt.war;
setAppContext
delegate: false
repositories:
;webapplication.projectclasspath=;BIRT_VIEWER_HTTPSERVET_REQ UEST=org.apache.catalina.connector.RequestFacade@1051f982;
setAppContext
delegate: false
repositories:
setLocale
setAppContext
delegate: false
repositories:
setAppContext
delegate: false
repositories:
<=== Endlog
Jason Weathersby schrieb:
> Claus,
> runtime?
> Jason
> exquisitus wrote:
>> Hi,
>> works.
>> webserver (version 4.2.3.GA) running on RHEL 5.2 64-bit. (Deployment
>> as described for jboss on the BIRT website
>> Using the link
>> http://192.168.1.1:8081/birt/run?__report=test.rptdesign within
>> Using the link
>> in the following HTTP Status 500:
>> exception
>> root cause
>> root cause
>> Thanks in advance
>> claus
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365390 is a reply to message #365384] |
Wed, 01 October 2008 13:09 |
the same error occurs using java version jdk1.5.0_16 .
claus
exquisitus schrieb:
> Good morning,
> following link:
> the linux server.
> Regards
> claus
> Startlog ===>
> <init>
> delegate: false
> repositories:
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> 01.10.2008 08:53:44
> getExtensions
> 01.10.2008 08:53:44
> loadExtendedItems
> 01.10.2008 08:53:44
> loadExtendedItems
> 01.10.2008 08:53:44
> loadExtendedItems
> openReportDocument
> openReportDesign
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> validateInputString
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:41
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> 01.10.2008 08:54:42
> setAppContext
> delegate: false
> repositories:
> setLocale
> setAppContext
> delegate: false
> repositories:
> setAppContext
> delegate: false
> repositories:
> setAppContext
> delegate: false
> repositories:
> setLocale
> setAppContext
> delegate: false
> repositories:
> setAppContext
> delegate: false
> repositories:
> <=== Endlog
>> Claus,
>> runtime?
>> Jason
>> exquisitus wrote:
>>> Hi,
>>> works.
>>> Using the link
>>> Using the link
>>> exception
>>> root cause
>>> root cause
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365396 is a reply to message #365390] |
Wed, 01 October 2008 15:09 |
Claus,
You may need to log a bug for this, but can you try to war the
WebViewerExample directory and use it instead of the birt.war?
Jason
exquisitus wrote:
> claus
> exquisitus schrieb:
>> Good morning,
>> following link:
>> on the linux server.
>> Regards
>> claus
>> Startlog ===>
>> 01.10.2008 08:53:44
>> org.eclipse.birt.report.engine.api.impl.ReportEngine <init>
>> delegate: false
>> repositories:
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> 01.10.2008 08:53:44
>> getExtensions
>> 01.10.2008 08:53:44
>> loadExtendedItems
>> 01.10.2008 08:53:44
>> loadExtendedItems
>> 01.10.2008 08:53:44
>> loadExtendedItems
>> 01.10.2008 08:54:41
>> org.eclipse.birt.report.engine.api.impl.ReportEngine openReportDocument
>> 01.10.2008 08:54:41
>> org.eclipse.birt.report.engine.api.impl.ReportEngine openReportDesign
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> validateInputString
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:41
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> 01.10.2008 08:54:42
>> setAppContext
>> delegate: false
>> repositories:
>> setLocale
>> setAppContext
>> delegate: false
>> repositories:
>> setAppContext
>> delegate: false
>> repositories:
>> 01.10.2008 08:54:42
>> setAppContext
>> delegate: false
>> repositories:
>> setLocale
>> setAppContext
>> delegate: false
>> repositories:
>> setAppContext
>> delegate: false
>> repositories:
>> <=== Endlog
>>> Claus,
>>> runtime?
>>> Jason
>>> exquisitus wrote:
>>>> Hi,
>>>> eclipse update function on WinXP (Client). Execution of the
>>>> Using the link
>>>> Using the link
>>>> results in the following HTTP Status 500:
>>>> exception
>>>> root cause
>>>> org.ec
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365398 is a reply to message #365396] |
Wed, 01 October 2008 15:47 |
Hi Jason,
as in the install / deployment documentation for jboss mentioned,
war'ing the WebViewerExample is what i did.
I will try to deploy the "pure" birt.war and doublecheck that.
As a workaround, I installed jboss-web and copied the birt.war folder
from the jboss application server. There the test report and some others
work fine.
claus
> Claus,
> Jason
> exquisitus wrote:
>> Hi,
>> claus
>> exquisitus schrieb:
>>> Good morning,
>>> following link:
>>> Regards
>>> claus
>>> Startlog ===>
>>> 01.10.2008 08:53:44
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> 01.10.2008 08:53:44
>>> getExtensions
>>> 01.10.2008 08:53:44
>>> loadExtendedItems
>>> 01.10.2008 08:53:44
>>> loadExtendedItems
>>> 01.10.2008 08:53:44
>>> loadExtendedItems
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> validateInputString
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:41
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> org.eclipse.birt.report.engine.api.impl.EngineTask setAppContext
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:54:42
>>> org.eclipse.birt.report.engine.api.impl.EngineTask setLocale
>>> 01.10.2008 08:54:42
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:54:42
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:54:42
>>> 01.10.2008 08:54:42
>>> delegate: false
>>> repositories:
>>> 01.10.2008 08:54:42
>>> delegate: false
>>> repositories:
>>> <=== Endlog
>>>> Claus,
>>>> runtime?
>>>> Jason
>>>> exquisitus wrote:
>>>>> Hi,
>>>>> (Deployment as described for jboss on the BIRT website
>>>>> Using the link
>>>>> Using the link
>>>>> exception
Re: switch from 2.3.0 to 2.3.1, "Processing please wait" never ends in jboss birt runtime [message #365420 is a reply to message #365398] |
Thu, 02 October 2008 09:09 |
tested the delivered birt.war. The same error occurs.
claus
exquisitus schrieb:
> Hi Jason,
> work fine.
> claus
>> Claus,
>> Jason
>> exquisitus wrote:
>>> Hi,
>>> claus
>>> exquisitus schrieb:
>>>> Good morning,
>>>> following link:
>>>> Regards
>>>> claus
>>>> Startlog ===>
>>>> 01.10.2008 08:53:44
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> 01.10.2008 08:53:44
>>>> getExtensions
>>>> 01.10.2008 08:53:44
>>>> loadExtendedItems
>>>> 01.10.2008 08:53:44
>>>> loadExtendedItems
>>>> 01.10.2008 08:53:44
>>>> loadExtendedItems
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateXml
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> validateInputString
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:41
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> validateXml
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> validateXml
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> validateXml
>>>> 01.10.2008 08:54:42
>>>> validateXml
>>>> 01.10.2008 08:54:42
>>>> validateXml
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:54:42
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> 01.10.2008 08:54:42
>>>> delegate: false
>>>> repositories:
>>>> <=== Endlog
>>>>> Claus,
Current Time: Tue Apr 23 08:39:32 GMT 2024
Powered by FUDForum. Page generated in 0.03635 seconds
