Home » Archived » BIRT » Web Service Data Sources
Re: Web Service Data Sources [message #365368 is a reply to message #365330] |
Tue, 30 September 2008 14:50 |
Originally posted by: jasonweathersby.alltel.net
Jim,
If you preview the report does it retrieve your data?
Also did you get anything in the workspace log file when you got the 400
error?
Jason
jnorris wrote:
> Hi All,
> I've been trying to get a web service to work as a data source but I've have
> had a number of issues trying to get it to work. I've posted in
> birt-exchange but haven't received any response so I'm trying this news
> group before I give up on using birt for reporting in my application.
> I've gone through the weather service demo and it works fine. I first tried
> creating an axis2 web service using WTP and it worked as expected with a
> java client. However in BIRT it connects ok as a data source but has issues
> when defining a dataset. The input parameters show up but the table mapping
> only shows "return" and not the xml data so the columns can't be mapped. So
> I designed the web service in C#/ASP.NET and installed in on IIS. In this
> case the table mapping page showed the xml structure and I was able to map
> the output columns. I was able to open the service in a browser, enter
> parameters and on clicking invoke it returned the xml response data set as
> expected. However clicking on preview results in the data set editor fails
> with a birt exception with the server returning HTTP 400.
> So my question to the group is - has anyone successfully created a web
> service and used it as a data source? If so could you please outline the
> steps you took to create the web service so it works with birt?
> Thanks in advance,
> Jim
Re: Web Service Data Sources [message #365397 is a reply to message #365389] |
Wed, 01 October 2008 15:26 |
Jim,
I am not sure why this is failing. A 400 error points to a syntax
issue. Do you have BIRT setup to debug? If not can you send me the
axis service you built? Just email it to me.
Jason
jnorris wrote:
> Hi Jason,
> I did try a preview and got the same error information which is what is
> shown in the log file included below. The request in the data source looks
> to be the same as the sample post request shown on the asp.net page:
> <?xml version="1.0"? encoding="utf-8">
> <SOAP-ENV:Envelope
> xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"
> xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema">
> <SOAP-ENV:Body>
> <m:getNPTDataItems xmlns:m="http://com.test/services/2008/09">
> <m:startDate xsi:type="xsd:dateTime">&?startDate?&</m:startDate >
> <m:endDate xsi:type="xsd:dateTime">&?endDate?&</m:endDate>
> <m:siteId xsi:type="xsd:string">&?siteId?&</m:siteId>
> <m:machineId xsi:type="xsd:string">&?machineId?&</m:machineId>
> <m:operatorId xsi:type="xsd:string">&?operatorId?&</m:operatorId >
> </m:getNPTDataItems>
> </SOAP-ENV:Body>
> </SOAP-ENV:Envelope>
> At this point I can't rule out some .net permission problem although the
> ping test succeeds and the wsdl is retrieved.
> Jim
> log file info:
> !ENTRY org.eclipse.birt.data 4 1001 2008-09-26 09:14:59.096
> !MESSAGE A BIRT exception occurred.
> !STACK 0
> org.eclipse.birt.data.engine.core.DataException: Cannot execute the
> statement.
> Server returned HTTP response code: 400 for URL:
> http://localhost:1095/NPTDataService.asmx
> at
> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:570)
> at
> org.eclipse.birt.data.engine.executor.DataSourceQuery.execut e(DataSourceQuery.java:549)
> at
> org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:331)
> at
> org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:801)
> at
> org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:233)
> at
> org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:160)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.populateRecords(ResultSetPreviewPage.java:524)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.access$2(ResultSetPreviewPage.java:518)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage$5.run(ResultSetPreviewPage.java:474)
> at
> org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
> Caused by: org.eclipse.datatools.connectivity.oda.OdaException: Server
> at
> org.eclipse.datatools.enablement.oda.ws.util.RawMessageSende r.getSOAPResponse(RawMessageSender.java:107)
> at
> org.eclipse.datatools.enablement.oda.ws.impl.Query.getInputS tream(Query.java:183)
> at
> org.eclipse.datatools.enablement.oda.ws.impl.Query.initXMLQu ery(Query.java:135)
> at
> org.eclipse.datatools.enablement.oda.ws.impl.Query.executeQu ery(Query.java:127)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.doExecuteQuery(OdaQuery.java:443)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.executeQuery(OdaQuery.java:408)
> at
> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:556)
> ... 9 more
> "Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
> news:gbteer$s1s$1@build.eclipse.org...
>> Jim,
>> error?
>> Jason
>> jnorris wrote:
>>> Hi All,
>>> have had a number of issues trying to get it to work. I've posted in
>>> tried creating an axis2 web service using WTP and it worked as expected
>>> with a java client. However in BIRT it connects ok as a data source but
>>> has issues when defining a dataset. The input parameters show up but the
>>> table mapping only shows "return" and not the xml data so the columns
>>> can't be mapped. So I designed the web service in C#/ASP.NET and
>>> installed in on IIS. In this case the table mapping page showed the xml
>>> structure and I was able to map the output columns. I was able to open
>>> the service in a browser, enter parameters and on clicking invoke it
>>> returned the xml response data set as expected. However clicking on
>>> preview results in the data set editor fails with a birt exception with
>>> Thanks in advance,
>>> Jim
Re: Web Service Data Sources [message #365472 is a reply to message #365466] |
Fri, 03 October 2008 15:53 |
Jim,
Good to hear. Using the web service dataset parameter should pass the
date as a string. Post if you have an issue with this.
Jason
jnorris wrote:
> Hi Jason,
> After some debugging where I added some other services that worked I found
> that the original web service was not even being hit. The main difference
> was that the original service used DateTime input parameters. Removing the
> dates as inputs solved the issue with the service. Now my next step is to
> figure out how to map a date input on the report to a string value that I
> can pass to the service.
> Jim
> news:gc04u3$78m$1@build.eclipse.org...
>> Jim,
>> I am not sure why this is failing. A 400 error points to a syntax issue.
>> Do you have BIRT setup to debug? If not can you send me the axis service
>> Jason
>> jnorris wrote:
>>> Hi Jason,
>>> looks to be the same as the sample post request shown on the asp.net
>>> page:
>>> <SOAP-ENV:Envelope
>>> <SOAP-ENV:Body>
>>> </SOAP-ENV:Body>
>>> Jim
>>> log file info:
>>> !STACK 0
>>> statement.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 9 more
>>>> Jim,
>>>> error?
>>>> Jason
>>>> jnorris wrote:
>>>>> Hi All,
>>>>> but has issues when defining a dataset. The input parameters show up
>>>>> but the table mapping only shows "return" and not the xml data so the
>>>>> columns can't be mapped. So I designed the web service in C#/ASP.NET
>>>>> and installed in on IIS. In this case the table mapping page showed
>>>>> the xml structure and I was able to map the output columns. I was able
>>>>> to open the service in a browser, enter parameters and on clicking
>>>>> invoke it returned the xml response data set as expected. However
>>>>> clicking on preview results in the data set editor fails with a birt
>>>>> the steps you took to create the web service so it works with birt?
>>>>> Thanks in advance,
>>>>> Jim
Re: Web Service Data Sources [message #691054 is a reply to message #365472] |
Thu, 30 June 2011 15:56 |
deesha.singh Messages: 7 Registered: June 2011 |
Hello, I'm having a similar issue. I removed the dateTime parameters from my wsdl, made them strings instead. Now I'm getting a new error. I also can't get a preview to work, I generally get the same errors as when I'm running it on my server. Hopefully someone can help me, I have no idea how to fix this. Posting the stacktrace here (hope that's ok). It's saying no protocol, but I'm not sure what that means or what it relates to??
Thank you.
17:44:40,447 INFO [ReportManagerBean] Running report generation task
17:44:45,201 WARNING [ModelAdapter] handle type: org.eclipse.birt.report.model.api.OdaDataSetHandle
17:44:46,653 SEVERE [odaconsumer] Cannot execute statement.
org.eclipse.datatools.connectivity.oda.OdaException: no protocol:
at org.eclipse.datatools.enablement.oda.ws.util.RawMessageSender.getSOAPResponse(RawMessageSender.java:107)
at org.eclipse.datatools.enablement.oda.ws.impl.Query.getInputStream(Query.java:184)
at org.eclipse.datatools.enablement.oda.ws.impl.Query.initXMLQuery(Query.java:136)
at org.eclipse.datatools.enablement.oda.ws.impl.Query.executeQuery(Query.java:128)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doExecuteQuery(OdaQuery.java:464)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.executeQuery(OdaQuery.java:428)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:599)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:771)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:399)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1045)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:158)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init>(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1875)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:170)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:75)
at com.vls.reporting.ReportManagerBean.generateReport(ReportManagerBean.java:116)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:69)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor$InvocationContext.proceed(InvocationContextInterceptor.java:138)
at org.jboss.seam.intercept.EJBInvocationContext.proceed(EJBInvocationContext.java:44)
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:56)
at org.jboss.seam.transaction.RollbackInterceptor.aroundInvoke(RollbackInterceptor.java:28)
at org.jboss.seam.intercept.SeamInvocationContext.proceed(SeamInvocationContext.java:68)
at org.jboss.seam.core.MethodContextInterceptor.aroundInvoke(MethodContextInterceptor.java:44)
at org.jboss.seam.persistence.EntityManagerProxyInterceptor.aroundInvoke(EntityManagerProxyInterceptor.java:29)
at org.jboss.seam.persistence.HibernateSessionProxyInterceptor.aroundInvoke(HibernateSessionProxyInterceptor.java:30)
at org.jboss.seam.intercept.RootInterceptor.invoke(RootInterceptor.java:107)
at org.jboss.seam.intercept.SessionBeanInterceptor.aroundInvoke(SessionBeanInterceptor.java:50)
at sun.reflect.GeneratedMethodAccessor414.invoke(Unknown Source)
at org.jboss.ejb3.interceptors.aop.EJB3InterceptorInterceptor.invoke(EJB3InterceptorInterceptor.java:83)
at org.jboss.ejb3.interceptors.aop.EJB3InterceptorInterceptor.invoke(EJB3InterceptorInterceptor.java:70)
at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:59)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:59)
at sun.reflect.GeneratedMethodAccessor413.invoke(Unknown Source)
at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:72)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_3318565.invoke(InvocationContextInterceptor_z_fillMethod_3318565.java)
at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:88)
at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_3318565.invoke(InvocationContextInterceptor_z_setup_3318565.java)
at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
at org.jboss.ejb3.stateless.StatelessInstanceInterceptor.invoke(StatelessInstanceInterceptor.java:68)
at org.jboss.aspects.tx.TxPolicy.invokeInCallerTx(TxPolicy.java:126)
at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:194)
at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
at org.jboss.ejb3.security.RoleBasedAuthorizationInterceptorv2.invoke(RoleBasedAuthorizationInterceptorv2.java:201)
at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:186)
at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:176)
at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:216)
at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:207)
at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:164)
at $Proxy725.generateReport(Unknown Source)
at org.jboss.seam.util.Reflections.invoke(Reflections.java:22)
at org.jboss.seam.intercept.RootInvocationContext.proceed(RootInvocationContext.java:32)
at org.jboss.seam.intercept.ClientSideInterceptor$1.proceed(ClientSideInterceptor.java:76)
at org.jboss.seam.intercept.ClientSideInterceptor.invoke(ClientSideInterceptor.java:54)
at org.javassist.tmp.java.lang.Object_$$_javassist_seam_17.generateReport(Object_$$_javassist_seam_17.java)
at com.vls.reports.ReportActionBean.generateReport(ReportActionBean.java:143)
at org.jboss.seam.core.BijectionInterceptor.aroundInvoke(BijectionInterceptor.java:77)
at org.jboss.seam.core.ConversationInterceptor.aroundInvoke(ConversationInterceptor.java:65)
at org.jboss.ejb3.entity.ExtendedPersistenceContextPropagationInterceptor.invoke(ExtendedPersistenceContextPropagationInterceptor.java:60)
at org.jboss.ejb3.stateful.StatefulInstanceInterceptor.invoke(StatefulInstanceInterceptor.java:81)
at $Proxy820.generateReport(Unknown Source)
at org.jboss.seam.ejb.RemoveInterceptor.aroundInvoke(RemoveInterceptor.java:43)
at org.javassist.tmp.java.lang.Object_$$_javassist_seam_16.generateReport(Object_$$_javassist_seam_16.java)
at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:335)
at org.jboss.el.util.ReflectionUtil.invokeMethod(ReflectionUtil.java:280)
at org.jboss.el.parser.AstMethodSuffix.getValue(AstMethodSuffix.java:59)
at org.jboss.el.parser.AstMethodSuffix.invoke(AstMethodSuffix.java:65)
at org.jboss.el.parser.AstValue.invoke(AstValue.java:96)
at org.jboss.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:276)
at com.sun.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:68)
at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:88)
at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
at javax.faces.component.UICommand.broadcast(UICommand.java:387)
at org.ajax4jsf.component.AjaxViewRoot.processEvents(AjaxViewRoot.java:329)
at org.ajax4jsf.component.AjaxViewRoot.broadcastEventsForPhase(AjaxViewRoot.java:304)
at org.ajax4jsf.component.AjaxViewRoot.processPhase(AjaxViewRoot.java:261)
at org.ajax4jsf.component.AjaxViewRoot.processApplication(AjaxViewRoot.java:474)
at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:82)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:100)
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:265)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:83)
at org.jboss.seam.web.IdentityFilter.doFilter(IdentityFilter.java:40)
at org.jboss.seam.servlet.SeamFilter$FilterChainImpl.doFilter(SeamFilter.java:69)
at org.jboss.seam.web.MultipartFilter.doFilter(MultipartFilter.java:90)
at org.jboss.seam.web.ExceptionFilter.doFilter(ExceptionFilter.java:64)
at org.jboss.seam.web.RedirectFilter.doFilter(RedirectFilter.java:45)
at org.ajax4jsf.webapp.BaseXMLFilter.doXmlFilter(BaseXMLFilter.java:206)
at org.ajax4jsf.webapp.BaseFilter.handleRequest(BaseFilter.java:290)
at org.ajax4jsf.webapp.BaseFilter.processUploadsAndHandleRequest(BaseFilter.java:388)
at org.ajax4jsf.webapp.BaseFilter.doFilter(BaseFilter.java:515)
at org.jboss.seam.web.Ajax4jsfFilter.doFilter(Ajax4jsfFilter.java:56)
at org.jboss.seam.web.LoggingFilter.doFilter(LoggingFilter.java:60)
at org.jboss.seam.web.HotDeployFilter.doFilter(HotDeployFilter.java:53)
at org.jboss.seam.servlet.SeamFilter.doFilter(SeamFilter.java:158)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:433)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:662)
[Updated on: Thu, 21 July 2011 12:28] Report message to a moderator
Re: Web Service Data Sources [message #691067 is a reply to message #691054] |
Thu, 30 June 2011 16:11 |
Is this a report that you could post and is the web service public?
Attached is an example Web Service report, although the web service is
public it is slow.
Jason
> relates to??
> Thank you.
> org.eclipse.datatools.connectivity.oda.OdaException: no protocol: at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> com.volvo.vls.reporting.ReportManagerBean.generateReport(ReportManagerBean.java:116)
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> com.volvo.vls.reports.ReportActionBean.generateReport(ReportActionBean.java:143)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Web Service Data Sources [message #691344 is a reply to message #691067] |
Fri, 01 July 2011 09:17 |
Hi Jason,
Thanks for the example. I think I've figured out the problem. I don't think my web service method is being found/called so I'm not sure if I have the annotations right? Would you mind looking at it for me?
None of this is public, so i'll attach the files for you below. For now, the method has nothing crazy in it, I just want to test that it works. Seems I've picked up a new error now, its the "cannot connect" one when I try the preview for the report.
Thanks a lot,
Deesha
[Updated on: Wed, 20 July 2011 14:07] Report message to a moderator
Re: Web Service Data Sources [message #691546 is a reply to message #691344] |
Fri, 01 July 2011 17:18 |
Deesha,
I did not see anything obvious. Any chance you can put a proxy in
between to log out the SOAP request response?
Jason
On 7/1/2011 5:17 AM, forums-noreply@eclipse.org wrote:
> Hi Jason,
> Thanks a lot,
> Deesha
Re: Web Service Data Sources [message #693946 is a reply to message #691546] |
Thu, 07 July 2011 14:17 |
Hi Jason,
Re the logging thing, I'm not sure I know how to do that at all, sorry.
I added the @WebMethod annotation and a few other things, now the error is different. i'll include the whole stacktrace here, it happens after the fonts are initialized..
This is getting really annoying, I can't get a report to generate properly.
Any idea what this could be?
Deesha
Re: Web Service Data Sources [message #694439 is a reply to message #694431] |
Fri, 08 July 2011 15:23 |
Deesha,
Does your web service require authentication credentials?
This may be the issue. You may have to use the custom class feature of
the web service. Take a look at the article here:
http://www.birt-exchange.org/org/devshare/designing-birt-reports/461-birt-web-service-oda-article/
Take a look at this thread as well.
http://www.birt-exchange.org/org/forum/index.php/topic/12013-basic-authentication/
Jason
On 7/8/2011 11:14 AM, Jason Weathersby wrote:
> Deesha,
> Can you open your browser and enter:
> http://localhost:8080/vls-web/services/BIRTServicePort?wsdl
> and take a screen shot and post it? Right now the datasource is defined
> to use the wsdl on the local file system. Can you change it to use
> Jason
> On 7/7/2011 10:17 AM, forums-noreply@eclipse.org wrote:
>> Hi Jason,
>> properly.
>> Deesha
Re: Web Service Data Sources [message #698922 is a reply to message #694439] |
Wed, 20 July 2011 13:30 |
Hi Jason,
I'm sorry, after days of banging my head against a wall i have a working web service. I've tested it with SoapUI and it works perfectly.
Birt problem: When creating the web service dataset, is there any reason why Birt would be able to see the input parameters, but when it gets to row mapping the
SOAP-ENV:Body has nothing inside it? So I can't do the row mapping??
I'll attach the wsdl, the bean and the an image of what I'm talking about.
Deesha
[Updated on: Wed, 20 July 2011 13:54] Report message to a moderator
Re: Web Service Data Sources [message #698984 is a reply to message #698922] |
Wed, 20 July 2011 15:18 |
Deesha
Can you post the SOAP request gui page from the dataset editor?
Did you use a dataset parameter(&?dsparm?&) or hardcode the parameter
value?
Jason
On 7/20/2011 9:30 AM, forums-noreply@eclipse.org wrote:
> Hi Jason,
> Regards,
> Deesha
Re: Web Service Data Sources [message #699442 is a reply to message #699252] |
Thu, 21 July 2011 14:35 |
Ok this created three dataset parameters when you clicked them. Did you
set values for the parameters using the dataset editor's parameter tab
while in the web service dataset?
Jason
On 7/21/2011 4:02 AM, forums-noreply@eclipse.org wrote:
> The wsdl was created using an xsd, and somehow BIRT just sees the input parameters but nothing else :/
> I didn't have to code anything into BIRT. The input parameters were just there, and i ticked them and it created the following request:
> <?xml version="1.0"?>
> <SOAP-ENV:Envelope
> xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
> <SOAP-ENV:Body>
> <m:VehicleWholesaleRequest xmlns:m="http://vls.com/VLS/Service/1.0">
> <m:startDate xsi:type="xsd:string">&?startDate?&</m:startDate>
> <m:endDate xsi:type="xsd:string">&?endDate?&</m:endDate>
> <m:market xsi:type="xsd:string">&?market?&</m:market>
> </m:VehicleWholesaleRequest>
> </SOAP-ENV:Body>
> I'm just wondering, should I create an external xml with the response format? Would that work? I think I can pick that out of SoapUI somehow..
> Regards,
> Deesha
Re: Web Service Data Sources [message #699443 is a reply to message #699356] |
Thu, 21 July 2011 14:38 |
Is js.jar in the classpath? What BIRT runtime version are you using?
Jason
On 7/21/2011 8:27 AM, forums-noreply@eclipse.org wrote:
> Also, what do you do if you get this error:
> 14:20:06,724 FATAL [ReportManagerBean] Reporting engine exception:Error
> happened while running the report
> 14:20:06,738 SEVERE [application] java.lang.Exception: Error happened
> javax.faces.el.EvaluationException: java.lang.Exception: Error happened
> at
> javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:102)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: java.lang.Exception: Error happened while running the report
> at
> com.vls.reporting.ReportManagerBean.generateReport(ReportManagerBean.java:119)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_10751758.invoke(InvocationContextInterceptor_z_fillMethod_10751758.java)
> at
> at
> at
> org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_10751758.invoke(InvocationContextInterceptor_z_setup_10751758.java)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at $Proxy533.generateReport(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> org.javassist.tmp.java.lang.Object_$$_javassist_seam_19.generateReport(Object_$$_javassist_seam_19.java)
> at
> com.vls.reports.ReportActionBean.generateReport(ReportActionBean.java:133)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at $Proxy632.generateReport(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.javassist.tmp.java.lang.Object_$$_javassist_seam_18.generateReport(Object_$$_javassist_seam_18.java)
> at
> at
> at
> at
> ... 53 more
> Caused by: java.lang.NoClassDefFoundError:
> org/mozilla/javascript/ScriptableObject
> at java.lang.ClassLoader.defineClass1(Native Method)
> at java.lang.ClassLoader.defineClassCond(ClassLoader.java:632)
> at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
> at
> org.jboss.classloader.spi.base.BaseClassLoader.access$200(BaseClassLoader.java:63)
> at
> org.jboss.classloader.spi.base.BaseClassLoader$2.run(BaseClassLoader.java:572)
> at
> org.jboss.classloader.spi.base.BaseClassLoader$2.run(BaseClassLoader.java:532)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.jboss.classloader.spi.base.BaseClassLoader.loadClassLocally(BaseClassLoader.java:530)
> at
> org.jboss.classloader.spi.base.BaseClassLoader.loadClassLocally(BaseClassLoader.java:507)
> at
> org.jboss.classloader.spi.base.BaseDelegateLoader.loadClass(BaseDelegateLoader.java:134)
> at
> org.jboss.classloader.spi.filter.FilteredDelegateLoader.loadClass(FilteredDelegateLoader.java:131)
> at
> org.jboss.classloader.spi.base.ClassLoadingTask$ThreadTask.run(ClassLoadingTask.java:452)
> at
> org.jboss.classloader.spi.base.ClassLoaderManager.nextTask(ClassLoaderManager.java:251)
> at
> org.jboss.classloader.spi.base.ClassLoaderManager.process(ClassLoaderManager.java:150)
> at
> org.jboss.classloader.spi.base.BaseClassLoaderDomain.loadClass(BaseClassLoaderDomain.java:265)
> at
> org.jboss.classloader.spi.base.BaseClassLoaderDomain.loadClass(BaseClassLoaderDomain.java:1119)
> at
> org.jboss.classloader.spi.base.BaseClassLoader.loadClassFromDomain(BaseClassLoader.java:798)
> at
> org.jboss.classloader.spi.base.BaseClassLoader.loadClass(BaseClassLoader.java:441)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
> at
> org.eclipse.birt.core.framework.osgi.OSGILauncher$ChildFirstURLClassLoader.loadClass(OSGILauncher.java:688)
> at
> org.eclipse.osgi.internal.loader.SystemBundleLoader.findLocalClass(SystemBundleLoader.java:115)
> at
> org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:454)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:398)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:105)
> at
> org.eclipse.birt.core.internal.function.impl.FunctionProviderImpl.getWrapperedCategories(FunctionProviderImpl.java:405)
> at
> org.eclipse.birt.core.internal.function.impl.FunctionProviderImpl.registerScriptFunction(FunctionProviderImpl.java:120)
> at
> org.eclipse.birt.core.script.functionservice.impl.FunctionProvider.registerScriptFunction(FunctionProvider.java:76)
> at
> org.eclipse.birt.core.script.CoreJavaScriptInitializer.initialize(CoreJavaScriptInitializer.java:26)
> at
> org.eclipse.birt.report.engine.javascript.JavascriptEngine.initWrapFactory(JavascriptEngine.java:161)
> at
> org.eclipse.birt.report.engine.javascript.JavascriptEngine.<init>(JavascriptEngine.java:131)
> at
> org.eclipse.birt.report.engine.javascript.JavascriptEngineFactory.createScriptEngine(JavascriptEngineFactory.java:98)
> at
> org.eclipse.birt.core.script.ScriptContext.createEngine(ScriptContext.java:238)
> at
> org.eclipse.birt.core.script.ScriptContext.getScriptEngine(ScriptContext.java:227)
> at
> org.eclipse.birt.report.engine.adapter.ModelDteApiAdapter.<init>(ModelDteApiAdapter.java:176)
> at
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.<init>(AbstractDataEngine.java:107)
> at
> org.eclipse.birt.report.engine.data.dte.DteDataEngine.<init>(DteDataEngine.java:85)
> at
> org.eclipse.birt.report.engine.data.DataEngineFactory.createDataEngine(DataEngineFactory.java:100)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.openDataEngine(ExecutionContext.java:843)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.getDataEngine(ExecutionContext.java:865)
> at
> org.eclipse.birt.report.engine.executor.ReportExecutor.execute(ReportExecutor.java:123)
> at
> org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportExecutor.execute(WrappedReportExecutor.java:60)
> at
> org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplciateReportExecutor.execute(SuppressDuplciateReportExecutor.java:42)
> at
> at
> org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportExecutor.execute(LocalizedReportExecutor.java:61)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:168)
> at
> at
> com.vls.reporting.ReportManagerBean.generateReport(ReportManagerBean.java:112)
> ... 238 more
> Caused by: java.lang.ClassNotFoundException:
> org.mozilla.javascript.ScriptableObject
> at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
> at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
> at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
> at java.lang.Class.forName0(Native Method)
> at java.lang.Class.forName(Class.java:247)
> at
> org.jboss.classloader.spi.base.BaseClassLoaderDomain.loadClass(BaseClassLoaderDomain.java:292)
> at
> at
> at
> ... 289 more
> 14:20:06,745 WARNING [lifecycle] #{reportAction.generateReport()}:
> javax.faces.FacesException: #{reportAction.generateReport()}:
> at
> com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:118)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: javax.faces.el.EvaluationException: java.lang.Exception:
> at
> at
> ... 52 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Current Time: Thu Apr 25 00:57:58 GMT 2024
Powered by FUDForum. Page generated in 0.05265 seconds
