Re: Gallery Widget [message #37290 is a reply to message #37256] |
Sun, 15 July 2007 19:02  |
Nicolas Richeton Messages: 179 Registered: July 2009 |
Hi Volker,
Drap and drop is already supported, but only between other apps or
widget (for example, DND is used in sharemedia
http://www.sf.net/projects/sharemedia to copy items between libraries
and to create albums), but you cannot reorder a gallery by drag and drop
yet.
About the zoom on mouseover, I already thought of something like what
you can see on the current Cartier web site when you browse collections
(cartier.com) : the item under the mouse gets bigger and other items get
smaller. But no work has been done on this ATM.
I still need to write some documentation about the gallery widget,
especially about the group and item renderers. Basically, layout and
drawing and custom mouse handling are done by them, and the gallery
widget doesn't need to be modified to add features such as zoom. The
only thing to do is to write a new renderer.
You can add feature requests for zoom and dnd reordering on bugzilla if
you want to.
Thanks for your feedback.
Nicolas
Volker Renneberg a écrit :
> Hi!
> I do not know, whether this is the right place for a feature suggestion.
> Having a user friendly and easy to use UI is very important for building
> future applications. I like the gallery widget very much since it
> concentrates on presenting information in pictures. It reminds me of the
> Apple task line at the bottom of the screen. Having said that, is there any
> thought about implementing the following feature? If the mouse hovers over a
> picture in the gallery, its size will be increased (like in the Apple
> toolbar). I guess drag and drop will also be supported at some stage?!
> cheers
> Volker
> Volker Renneberg
Re: Gallery Widget [message #583486 is a reply to message #37256] |
Hi Volker,
yet.
you want to.
Nicolas
> Hi!
> cheers
> Volker
> Volker Renneberg
FUDForum. Page generated in 0.07788 seconds
