Re: OHF bridge for IHE project [message #37034] |
Tue, 13 November 2007 16:59 |
Enayet,
The OHF folks are more likely to see your question if you use their
specific newsgroup. I've added it to the "to" list of the reply, so you
don't need to repost.
Enayet wrote:
> Hi, I have installed OHF bridge in order to successfully test the MESA
> tools. The IHE Techical team suggested me to downlaod that to move
> forward as we do not have middleware to open the UDP socket. I was
> able to verify the (WSDL/XML) by going to the URL without any problem
> but missing the information where to go from here as far as
> configuring the OHF to open the socket to send the log message to the
> IHE server.
> Please help me understand how to send the ATNA log message so that I
> can move forward to complete the MESA test.
> Thanks.
> BR,
> Enayet
Re: OHF bridge for IHE project [message #37136 is a reply to message #37034] |
Tue, 13 November 2007 20:51 |
Originally posted by: ekhan.emergisoft.com
Hi Ed,
My question is, how can I open the UDP socket to send the logging message
to the IHE server after installing the OHF bridge?
Re: OHF bridge for IHE project [message #37203 is a reply to message #37136] |
Thu, 15 November 2007 19:29 |
No real name Messages: 292 Registered: July 2009 |
Hi Enayet,
You have to make a webservice call to the bridge using one of the audit
message webservice API provided for you. The bridge will open the socket
for you.
As far as configuration, you have to run your bridge with a
rhioConfig.xml file that is conformant to our config model. In this
rhioConfig.xml file you will see structures that represent various
endpoints for your testing (registry, repository, audit server, etc).
For Auditing, you will have to set your MESA pc and port to be the
endpoint in this configuration.
Please let me know if I am not correctly understanding your question.
For more information, please consult the following resources:
* http://www.eclipse.org/ohf/components/bridge/install.php
* http://www.eclipse.org/ohf/components/bridge/using.php
* http://wiki.eclipse.org/IHE_Connectathon_2008
* http://wiki.eclipse.org/OHF_IHE_MAIN_BRANCH
We also advise first time users to grab the builds that we provide,
instead of from CVS. This will provide you with a rhioConfig.xml for you
to edit for your testing.
To download incremental Connecathon 2008 builds, please see:
http://www.eclipse.org/ohf/downloads/connectathon.php
To download stable, sanctioned builds - including major milestone
releases for 2008 Connectathon and final code from 2007 Connectathon -
please see:
http://www.eclipse.org/ohf/downloads/index.php
- Sarah
Enayet wrote:
> Hi Ed,
> message to the IHE server after installing the OHF bridge?
Re: OHF bridge for IHE project [message #583148 is a reply to message #37136] |
Hi Enayet,
for you.
please see:
- Sarah
Enayet wrote:
> Hi Ed,
FUDForum. Page generated in 0.04816 seconds
