| Recommended Editor for Java Emitter Templates? [message #36955] |
Sat, 10 June 2006 05:09  |
Originally posted by: botterwe.uni-koblenz.de
Hi *,
I'm looking for a good JET editor.
I've found JET-Editor
http://sourceforge.net/projects/jet-editor/
but it doesn't have many features and the project seems not to be very
active.
Now I'm considering emft.jeteditor as an alternative.
- What do I need to run it? Would it work with EMF 2.1.2?
- Do I have to install anything else than unpacking the
emft-jeteditor-runtime-1.0.0RC6.zip?
- Are there any "Getting Started" or "How-to-Install" docs I did overlook?
Thanks in advance
Goetz
| Re: Recommended Editor for Java Emitter Templates? [message #37056 is a reply to message #36955] |
Sat, 10 June 2006 16:08  |
Goetz,
As Ed said, the EMFT JET Editor should fit your needs, however just as a
precision it's not exately the same as
http://sourceforge.net/projects/jet-editor/, it's rather a subcomponent of
this other sourceforge project :
http://sourceforge.net/projects/merlingenerator/.
The features are limited to coloring, code completion and error highlighting
for java script statements inside JSP-like tags, and preview of the
generated code. It doesn't yet provide features like outline,
auto-completion/auto-insertion of tag, imports, etc. it doesnt provide any
refactorings. Those features are currently under investigation.
You'll find a getting started in the Eclipse Help once the EMFT jeteditor
plugin is installed.
I hope this helps,
Joel.
"Goetz Botterweck" <botterwe@uni-koblenz.de> wrote in message
news:e6e27r$ljt$1@utils.eclipse.org...
> Hi *,
> active.
> Thanks in advance
> Goetz
| Re: Recommended Editor for Java Emitter Templates? [message #580545 is a reply to message #36955] |
Sat, 10 June 2006 10:42  |
Goetz,
The JET Editor in EMFT is the one from source forge donated to Eclipse
by Joel. It is designed to work with Eclipse 3.2 and EMF 2.2. The
build for it was only made available a few weeks ago, so probably not
many folks have noticed it yet. I personally find it extremely useful
and use it for all my JET editing needs. What features are missing?
Just unzipping the build and running eclipse.exe -clean should be all
you need to do to run it. By default it's registered to open against
these file extensions: extensions="javajet,propertiesjet,xmljet"
Goetz Botterweck wrote:
> Hi *,
> active.
> overlook?
> Thanks in advance
> Goetz
| Re: Recommended Editor for Java Emitter Templates? [message #580588 is a reply to message #36955] |
Goetz,
I hope this helps,
Joel.
> Hi *,
> active.
> Thanks in advance
> Goetz
FUDForum. Page generated in 0.04723 seconds
