Report Interactivity Problems [message #360846] |
Mon, 25 February 2008 19:36 |
Originally posted by: ryan.tidwell.level3.com
I'm running into a quirk (maybe it's a defect) with BIRT reports. When
I preview or deploy a report with interactivity on a bar chart, the area
that picks up mouse clicks does not overlap with the bar that I am
wanting to click on, making my reports with drill-through capability
almost impossible to use. Is there a fix for this?
-Ryan Tidwell
Re: Report Interactivity Problems [message #360904 is a reply to message #360853] |
Wed, 27 February 2008 19:17 |
Tianli,
I'm not doing anything special. I'm using all BIRT components out of
the box with no modification. I'm using 2d bar charts with depth, and
the area that responds to mouse clicks is offset to the left of the bar,
and is a different size than the bar. I've tried going to 2d charts
without depth, and I still get the same result. This problem shows up
in the designer and runtime. This is a hard problem to explain without
being able to see what's going on. I hope I'm being clear. I'll try to
put together some meaningful screenshots.
-Ryan
Tianli wrote:
> Hi Ryan
> I have tried your case, but can not reproduce it In both designer and
> runtime. Is there any special usage in your case?
> Tianli
> "Ryan Tidwell" <ryan.tidwell@level3.com> wrote in message
> news:fpv5cs$mml$1@build.eclipse.org...
>> I'm running into a quirk (maybe it's a defect) with BIRT reports. When I
>> that picks up mouse clicks does not overlap with the bar that I am wanting
>> to click on, making my reports with drill-through capability almost
>> -Ryan Tidwell
Re: Report Interactivity Problems [message #360905 is a reply to message #360853] |
Wed, 27 February 2008 19:40 |
Tianli,
I have a screen capture video that demonstrates the problems I've been
running into. Can I send this to you to take a look at?
-Ryan
Tianli wrote:
> Hi Ryan
> Tianli
>> -Ryan Tidwell
FUDForum. Page generated in 0.03682 seconds
