Re: bridge using registry url instead of repository url [message #36898 is a reply to message #36762] |
Mon, 12 November 2007 01:02 |
No real name Messages: 292 Registered: July 2009 |
I have committed a fix to the main branch of the OHF code in the CVS.
Please update from there. This fix may have some logic issues pending
(related to how the bridge manages the concept of a "defalut repository"
in it's support of both XDS.a and XDS.b) ... but try it for now. If
difficulties arise, please submit a new bug related to the repository
URL issues experienced.
- Sarah
Jesse Pangburn wrote:
> Hi Sarah,
> OK, it is submitted as Bug 209378
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=209378
> thank you!
> Jesse
> Sarah Knoop wrote:
>> Jesse,
>> Please submit this as a bug and we can look into it in more detail.
>> Please additionally submit your debug log as an attachment.
>> Thanks!
>> - Sarah
>>> Hi,
>>> I'm trying to test 11746 which is the XDS provide and registry
>>> transaction. However, it appears that the bridge is using the
>>> registry url instead of the repository url. The following is a
>>> relevant snippet from the bridge's log where it examines my
>>> rhioConfig.xml and displays the config info:
>>> mXdsRepositoryConfig=[{mesa=XdsRepositoryConfig ( XDS Type=[a]
>>> retrieveUrl=[null] provideRegisterUrl=[IheUri (
>>> mUnsecured=[http://129.6.24.109:9080/axis2/services/repositoryAonedoc]
>>> mSecured=[null] )] )}]
>>> mXdsRegistryConfig=[XdsRegistryConfig ( XDS Type=[a]
>>> nonStoredQueryUrl=[IheUri (
>>> mUnsecured=[http://129.6.24.109:9080/axis2/services/xdsregistrya]
>>> mSecured=[null] )] storedQueriesUrl=[IheUri (
>>> mUnsecured=[http://129.6.24.109:9080/axis2/services/xdsregistryb]
>>> mSecured=[null] )]
>>> And then there's the part where it logs where the transaction is
>>> actually being sent to (from a couple different sections of the log
>>> in case it was just one wrong print statement):
>>> [INFO ][2007-11-08T12:15:39.067-0800][ipse.ohf.ihe.xds.source.Sour ce]
>>> Submitting Provide and Register Document Set transaction to
>>> Repository: http://129.6.24.109:9080/axis2/services/xdsregistrya
>>> [DEBUG][2007-11-08T12:15:40.379-0800][httpclient.wire.header ]
>>> >> "POST /axis2/services/xdsregistrya HTTP/1.1[r][n]"
>>> You can see the url listed there is from the registry's
>>> nonStoredQueryUrl parameter, not from the repository url.
>>> Let me know if you agree this is a bug, and I'll submit one to the
>>> bugzilla.
>>> thanks,
>>> Jesse
Re: bridge using registry url instead of repository url [message #583017 is a reply to message #36762] |
- Sarah
> Hi Sarah,
> thank you!
> Jesse
> Sarah Knoop wrote:
>> Jesse,
>> Thanks!
>> - Sarah
>>> Hi,
>>> mSecured=[null] )]
>>> bugzilla.
>>> thanks,
>>> Jesse
FUDForum. Page generated in 0.03607 seconds
