Re: Connect just hangs [message #36653 is a reply to message #36505] |
Wed, 26 September 2007 20:46 |
Originally posted by: john.graham.sybase.com
Richard,
You might want to try DTP 1.5.1, due out at the end of this week. We've
made some changes in these areas, and it might cure your problem.
HTH,
John Graham
Eclipse Data Tools Platform PMC Chair
Richard Emerson wrote:
> Hi there
> I've recently installed DTP 1.5 in Eclipse 3.3. I set up a couple of JDBC
> driver definitions (jConnect3 and jTDS). In the Data Source Explorer, I
> define a new database connection.
> When I try to connect to the database, the 'Creating JDBC Connection'
> progress dialog opens, but the connection is never made and the dialog
> never goes away (choosing Cancel does not work).
> Pinging the database does the same. If I try to test the connection from
> the Connection Properties page, Eclipse hangs and I have to kill it.
> Here's what I've tried so far:
> - I can ping the DB box and telnet to the port.
> - A little test program to make the same connection (same URL, userid etc)
> using the same JDBC driver works fine and connects instantly.
> - Using a different JDBC driver doesn't seem to help.
> - Running Eclipse in a 1.5 JDK instead of 1.6 doesn't help.
> - I can't see anything relevant in the workspace .log file or in the
> Eclipse Error Log.
> - I haven't found reports of a similar problem on this newsgroup or
> elsewhere.
> I'm not sure what to do next to diagnose this problem - does anyone have
> any suggestions?
> Many thanks and regards,
> Richard
Re: Connect just hangs [message #587990 is a reply to message #36505] |
John Graham Messages: 183 Registered: July 2009 |
Richard,
HTH,
John Graham
> Hi there
> Eclipse Error Log.
> elsewhere.
> any suggestions?
> Richard
FUDForum. Page generated in 0.03142 seconds
