Home » Eclipse Projects » DSDP - Target Management » RSE:What is the use of RemoteSystemsTempFiles in workspace?
Re: RSE:What is the use of RemoteSystemsTempFiles in workspace? [message #36440 is a reply to message #36220] |
Mon, 29 June 2009 11:26 |
hemeihua Messages: 20 Registered: July 2009 |
Hello David,
Since it is a design decision,there is a problem in uploading a large
folder.
First I set maximum cached size 2048MB,then I upload a large
folder(1.02GB),but an internal error occurred.
Here is log information:
!ENTRY org.eclipse.core.jobs 4 2 2009-06-29 17:17:19.031
!MESSAGE An internal error occurred during: "Updating workspace".
!STACK 0
java.lang.OutOfMemoryError: Java heap space
at
org.eclipse.core.internal.jobs.DeadlockDetector.resizeGraph( DeadlockDetector.java:630)
at
org.eclipse.core.internal.jobs.DeadlockDetector.lockAcquired (DeadlockDetector.java:290)
at
org.eclipse.core.internal.jobs.LockManager.addLockThread(Loc kManager.java:124)
at
org.eclipse.core.internal.jobs.OrderedLock.setCurrentOperati onThread(OrderedLock.java:268)
at
org.eclipse.core.internal.jobs.OrderedLock.attempt(OrderedLo ck.java:123)
at
org.eclipse.core.internal.jobs.OrderedLock.createSemaphore(O rderedLock.java:142)
at
org.eclipse.core.internal.jobs.OrderedLock.acquire(OrderedLo ck.java:100)
at org.eclipse.core.internal.jobs.OrderedLock.acquire(OrderedLo ck.java:82)
at
org.eclipse.core.internal.resources.WorkManager.checkIn(Work Manager.java:118)
at
org.eclipse.core.internal.resources.Workspace.prepareOperati on(Workspace.java:1744)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1792)
at
org.eclipse.core.internal.events.NotificationManager$NotifyJ ob.run(NotificationManager.java:39)
!SESSION 2009-06-29 18:13:01.266
eclipse.buildId=I20070625-1500
java.version=1.6.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Framework arguments: -product org.eclipse.sdk.ide -pdelaunch
Command-line arguments: -product org.eclipse.sdk.ide -data
D:\FTP\ECLIPSE\rse_3.0.1\WS/../runtime-New_configuration -dev
file:D:/FTP/ECLIPSE/rse_3.0.1/WS/.metadata/.plugins/org.ecli pse.pde.core/New_configuration/dev.properties
-pdelaunch -os win32 -ws win32 -arch x86
Sometimes I do the same thing like above,another internal error occurred.
!ENTRY org.eclipse.core.jobs 4 2 2009-06-29 18:16:32.749
!MESSAGE An internal error occurred during: "Transfer Operation".
!STACK 0
at java.util.Arrays.copyOf(Arrays.java:2882)
at java.lang.String.<init>(String.java:179)
at java.io.Win32FileSystem.resolve(Win32FileSystem.java:241)
at java.io.File.<init>(File.java:312)
at
org.eclipse.rse.internal.services.local.files.LocalFileServi ce$LocalFileNameFilter.accept(LocalFileService.java:200)
at java.io.File.listFiles(File.java:1094)
at
org.eclipse.rse.internal.services.local.files.LocalFileServi ce.internalFetch(LocalFileService.java:737)
at
org.eclipse.rse.services.files.AbstractFileService.list(Abst ractFileService.java:103)
at
org.eclipse.rse.subsystems.files.core.servicesubsystem.FileS erviceSubSystem.internalList(FileServiceSubSystem.java:375)
at
org.eclipse.rse.subsystems.files.core.servicesubsystem.FileS erviceSubSystem.list(FileServiceSubSystem.java:567)
at
org.eclipse.rse.subsystems.files.core.subsystems.RemoteFileS ubSystem.list(RemoteFileSubSystem.java:975)
at
org.eclipse.rse.subsystems.files.core.subsystems.RemoteFileS ubSystem.list(RemoteFileSubSystem.java:950)
at
org.eclipse.rse.files.ui.resources.UniversalFileTransferUtil ity.downloadResourcesToWorkspaceMultiple(UniversalFileTransf erUtility.java:484)
at
org.eclipse.rse.files.ui.resources.UniversalFileTransferUtil ity.downloadResourcesToWorkspaceMultiple(UniversalFileTransf erUtility.java:489)
at
at
at
at
at
at
org.eclipse.rse.internal.files.ui.view.SystemViewRemoteFileA dapter.doDrag(SystemViewRemoteFileAdapter.java:1688)
at
org.eclipse.rse.internal.ui.view.SystemDNDTransferRunnable.t ransferRSEResources(SystemDNDTransferRunnable.java:192)
at
org.eclipse.rse.internal.ui.view.SystemDNDTransferRunnable.r unInWorkspace(SystemDNDTransferRunnable.java:606)
at
org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
To suppose that I uploaded the large folder(1.02GB) successfully, RSE FTP
will use more time than other ftp such as cuteftp to upload a file.
So RSE FTP's efficiency of transmission is lower than other ftp.
How to deal with the internal error? How to enhance the transmission
efficiency of RSE FTP?
Thanks ahead of time.
hemeihua
Re: RSE:What is the use of RemoteSystemsTempFiles in workspace? [message #36659 is a reply to message #36440] |
Tue, 30 June 2009 15:51 |
David McKnight Messages: 244 Registered: July 2009 |
I'm not sure what you mean by "set maximum cached size"? Are you referring
to the value for the Remote Systems->File Cache preferences or something
else? Are you able to do the operation if you divide it up into a group of
smaller uploads?
"hemeihua " <he.meihua@zte.com.cn> wrote in message
news:8ba35d35cfafbd37b195c69f799fb5a5$1@www.eclipse.org...
> Hello David,
> folder.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> !SESSION 2009-06-29
> 18:13:01.266 -----------------------------------------------
> file:D:/FTP/ECLIPSE/rse_3.0.1/WS/.metadata/.plugins/org.ecli pse.pde.core/New_configuration/dev.properties -
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> hemeihua
Re: RSE:What is the use of RemoteSystemsTempFiles in workspace? [message #36829 is a reply to message #36760] |
Thu, 02 July 2009 14:56 |
Hi hemeihua,
In this particular scenario, I don't think setting the "maximum cached size"
will make any difference. The issue seems to be that when reading a very
large file, too much heap memory is being consumed.
One workaround for this may be the following:
In the eclipse.ini file, memory args for the JVM can be set. For example:
-Xms40m
-Xmx256m
You may be able to raise the max memory for Eclipse such that it will be
able to handle larger heap memory consumption.
Let me know whether this helps.
Dave
news:34b7be3ca14cf73334dc1ad8e7329a82$1@www.eclipse.org...
> Hello David,
> yes,"set maximum cached size" is referring to the value for the Remote
> Systems->File Cache preferences. I can upload a smaller file which size is
> about 100MB-600MB ,but can not upload a larger file(above 1GB) which can
> not been divided and an internal error occurred. How to deal with the
> internal error? To suppose that I uploaded a large file(1.02GB)
> successfully, RSE FTP will use more time than other ftp such as cuteftp to
> upload a file.
> How to enhance the transmission efficiency of RSE FTP?
> Have you any way to avoid copying file to RemoteSystemsTempFiles and
> directly copy a file from source to target folder?
> or
> is there a switch when opening a file for editing, RSE downloads to the
> RemoteSystemsTempFiles and when uploading or downloading a file, RSE copy
> a file from source to target folder directly, not pass through
> RemoteSystemsTempFiles?
> Best Regards,
> hemeihua
Re: RSE:What is the use of RemoteSystemsTempFiles in workspace? [message #37269 is a reply to message #36996] |
Wed, 08 July 2009 17:46 |
Hi Hemeihua,
I think your request may be the same as that described here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=216763
If so, you may want to add your comments there. If not, you may want to
open a separate enhancement request.
There are also a couple other ftp performance bugs here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=180965
https://bugs.eclipse.org/bugs/show_bug.cgi?id=198636
Dave
news:2ecedd3eef5ee98f03a06d4a52bfc2c6$1@www.eclipse.org...
> Hi David,
> The problem of OutOfMemoryError has solved,thanks!
> But I have the other question:
> RSE FTP will use more time than other FTP such as cuteftp to upload a
> file.
> or
> Best Regards,
> hemeihua
Re: RSE:What is the use of RemoteSystemsTempFiles in workspace? [message #581425 is a reply to message #36220] |
Hello David,
folder.
!STACK 0
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
hemeihua
Re: RSE:What is the use of RemoteSystemsTempFiles in workspace? [message #581528 is a reply to message #36440] |
smaller uploads?
> Hello David,
> folder.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !SESSION 2009-06-29
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> hemeihua
Re: RSE:What is the use of RemoteSystemsTempFiles in workspace? [message #581608 is a reply to message #36760] |
Hi hemeihua,
-Xms40m
-Xmx256m
Dave
> Hello David,
> upload a file.
> or
> Best Regards,
> hemeihua
Re: RSE:What is the use of RemoteSystemsTempFiles in workspace? [message #581896 is a reply to message #36996] |
Hi Hemeihua,
Dave
> Hi David,
> file.
> or
> Best Regards,
> hemeihua
Current Time: Thu Mar 28 20:35:58 GMT 2024
Powered by FUDForum. Page generated in 0.07159 seconds
