RSE:How to set timeout to stop the connecting state? [message #36082] |
Tue, 23 June 2009 06:20 |
hemeihua Messages: 20 Registered: July 2009 |
I creat a FTP connection with the specified port such as 8092 which has
been used by other applications,and connect the FTP connection,but can not
open a Socket connected to a remote host at the specified port(8092) by
indirectly call {@link org.apache.commons.net.SocketClient$connect(String
hostname, int port)},and keep on connecting state for ever.
Here is my configuration:
- Windows XP PC running Eclipse 3.3.0 with plugin RSE (RSE-SDK-3.0.1.zip)
Here are my code:
/*creat a FTP connection with the specified port such as 8092*/
public IHost creatFTPConnection(String siteName, String ip, int port ){
IHost ftpSite = null;
IRSESystemType systemType =
RSECorePlugin.getTheCoreRegistry().getSystemTypeById(RSE_SYS TEM_TYPE_ID);
ISubSystemConfigurator[] configurators = getSubSystemConfigurators();
String[] defaultProfileNames =
sr.getSystemProfileManager().getActiveSystemProfileNames();
String aliasName = decorateAliasName(siteName);
if(defaultProfileNames.length > 0){
try {
ftpSite = sr.createHost(defaultProfileNames[0], systemType, aliasName,
ip,
"", "", 0,configurators);
} catch (Exception e) {
e.printStackTrace();
if(ftpSite != null){
ISubSystem[] subsystems = ftpSite.getSubSystems();
for (int i = 0; i < subsystems.length; i++){
ISubSystem subsystem = subsystems[i];
subsystem.getConnectorService().setPort(port);//port=8092
return ftpSite;
/*to connect the FTP connection with the specified port such as 8092*/
public class ConnectAllJob extends Job
private IHost fFtpSite, fTabDate;
private Viewer fViewer;
public ConnectAllJob(IHost site,IHost data, Viewer v )
super(SystemResources.ACTION_CONNECT_ALL_LABEL);
fFtpSite = site;
fTabDate = data;
fViewer = v;
public IStatus run(IProgressMonitor monitor)
List failedSystems = new ArrayList();
try
//forced instantiation of all subsystems
ISubSystem[] subsystems = fTabDate.getSubSystems();
IConnectorService system = subsystem.getConnectorService();
if (!subsystem.isConnected()
subsystem.getSubSystemConfiguration().supportsSubSystemConne ct()
&& !failedSystems.contains(system))
try
subsystem.connect(monitor, false);
catch (SystemMessageException e) {
//TODO should we collect all messages and just show one dialog with
a MultiStatus?
failedSystems.add(system);
SystemMessageDialog.displayMessage(e);
if ((e instanceof InterruptedException) || (e
instanceof OperationCanceledException)) {
// if the user was prompted for password and cancelled
// or if the connect was interrupted for some other
reason
// we don't attempt to connect the other subsystems
break;
SystemBasePlugin.logError(
e.getLocalizedMessage()!=null ? e.getLocalizedMessage() :
e.getClass().getName(),
e);
SystemMessageDialog.displayErrorMessage(getShell(), e.getMessage());
catch (Exception exc)
} // msg already shown
if (failedSystems.size() > 0)
return Status.CANCEL_STATUS;
How to set timeout to stop the connecting state or what is the best way to
handle this problem?
Somebody can help me?
Best Regards,
hemeihua
FUDForum. Page generated in 0.02172 seconds
