Home » Eclipse Projects » DTP » Adding CIMOM as a data source : Building DTP
Adding CIMOM as a data source : Building DTP [message #35525] |
Mon, 27 August 2007 12:04 |
Originally posted by: nyogita.novell.com
We are exploring the idea of having CIMOM as a data source type in BIRT.
Since this is extending the available data sources , we would need to
add this to org.eclipse.datatools.enablement.oda project.
However we are not successful in building DTP.
We have checked out build, connectivity, enablement, modelbase and
sqltools projects.[1.5 version]
We looked up http://wiki.eclipse.org/DTP_1.5.x_Build_Guidelines page.
Currently on running ant from the org.eclipse.datatools.build folder, we
get a build failed error, at
org.eclipse.datatools.build\org.eclipse.datatools.modelbase. build\build.xml:19:
The following error occurred while executing this line:
\org.eclipse.datatools.modelbase.sql\build.xml
(The system cannot find the path specified)
Since the modelbase.sql does not have a build.xml, are we missing
something here ?
What is the right way to build DTP ?
Yogita.
Re: Adding CIMOM as a data source : Building DTP [message #35662 is a reply to message #35525] |
Mon, 27 August 2007 20:01 |
Linda Chan Messages: 845 Registered: July 2009 |
Yogita,
To develop your own ODA extension plugin projects, it is not necessary to do
your own build of the DTP core components. Simply having the core DTP
plugins installed in your target platform would be sufficient to compile
your custom ODA plugins. It's similar to implementing any of the Eclipse
platform extension points. A zip file of the core DTP SDK plugins can be
downloaded from the DTP download web site:
http://www.eclipse.org/datatools/downloads.html
BTW, do you mean you are naming your custom ODA plugins for CIMOM with the
org.eclipse.datatools.enablement.oda namespace? Are you planning to
contribute the source to DTP? That's certainly welcome. It does however
require going thru Eclipse IP review and approval. In the meantime, you
might want to use your own namespace for the plugins. And rename them later
to the DTP enablement.oda namespace when ready to go thru the IP review
process.
Linda
DTP ODA Component Lead
"Yogita Naik" <nyogita@novell.com> wrote in message
news:faued2$8o5$1@build.eclipse.org...
> Since this is extending the available data sources , we would need to add
> something here ?
> Yogita.
Re: Adding CIMOM as a data source : Building DTP [message #35696 is a reply to message #35662] |
Tue, 28 August 2007 06:19 |
Thank you, Linda, for helping us with this.
Right now, we are just starting with the idea of having CIMOM as a data
source. The long term plan is to contribute the source to DTP, and then
we will certainly go thru the IP review and approval.
As you have mentioned, we will first use our own namespace for the
plugin and start with it.
Yogita.
Linda Chan wrote:
> Yogita,
> process.
> Linda
>> Hi,
>> something here ?
>> Thanks,
>> Yogita.
Re: Adding CIMOM as a data source : Building DTP [message #587686 is a reply to message #35525] |
Yogita,
process.
Linda
> something here ?
> Yogita.
Re: Adding CIMOM as a data source : Building DTP [message #587699 is a reply to message #35662] |
Yogita.
Linda Chan wrote:
> Yogita,
> process.
> Linda
>> Hi,
>> something here ?
>> Thanks,
>> Yogita.
Current Time: Tue Apr 23 16:31:09 GMT 2024
Powered by FUDForum. Page generated in 0.03699 seconds
