ATL Bundle issue [message #35289] |
Mon, 30 April 2007 10:40 |
Originally posted by: cicchetti.di.univaq.it
Hi all,
to renew my ATL installation I have downloaded the updated ATL bundle
and uncompressed it; at first all seemed to be ok. However, if I try to
switch workspace something wrong happens; for example, KM3 syntax
highlighting does not work any more. Maybe some property has been set by
means of a fixed path (i.e. c:\eclipse\workspace) instead of a variable
one. Can you suggest me what are the parameters to be manipulated to make
it to work?
Thank you very much.
Re: ATL Bundle issue [message #35330 is a reply to message #35289] |
Mon, 30 April 2007 11:17 |
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
The KM3 files are associated with the Textual Generic Editor (TGE).
It is possible that this file association is not kept when you change the workspace.
In the menu Window->Preferences->General->Editors->File Associations, you should have
*.km3 files associated with the Textual Generic Editor (TGE). If this is not done, you can
manually set this up.
Marcos.
Antonio Cicchetti wrote:
> Hi all,
> make it to work?
Re: ATL Bundle issue [message #35364 is a reply to message #35330] |
Mon, 30 April 2007 11:34 |
Hi Marcos,
thank you very much for your quick and detailed answer. It worked!
Antonio
FUDForum. Page generated in 0.02595 seconds
